Transmission Case Part Numbers
From Datsun 1200 Club
Categories: Transmission | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference:
56-Series Transmission
F5C56
5-speed Transmission Case
 1972 B110 Parts Catalog C-231
TRANSMISSION (5 SPEED)
  32010-H7251 TRANSMISSION ASS'Y (17/5)
1 08120-85510 BOLT-hex 6
2 08915-23810 WASHER-lock 6
3 08111-02062 BOLT-hex 3
TRANSMISSION CASE (5 SPEED)
4 32100-H7230 CASE COMP.-transmission
  32219-G1000   BEARING-needle counter shaft
5 32102-18000   PLUG-welch T/M case 2
6 00931-10810   PLUG-filler
7 32110-H1000 COVER ASS'Y-front transmission
8 32113-H3100 SEAL-oil, front cover
9 32112-18000 RING-O, front cover
As required:
 10 32208-18001 SHIMG-adjusting from cover (t=0.2)
 11 32208-18002 SHIMG-adjusting from cover (t=0.1)
 12 32208-18003 SHIMG-adjusting from cover (t=0.3)
13 08120-82510 BOLT-fix front cover 3
14 08915-13810 WASHER-spring 3
15 32130-H7230 EXTENSION ASS'Y-rear
16   32136-G1001 SEAL-oil, rear extension
17*32150-H5000 RETAINER-oil
18 38322-H7201 BREATHER ASS'Y
19 32140-24900 BUSH-return spring
20 32351-H7200 BEARING-needle extension rear
21 08120-80510 BOLT-hex, fix rear extension 3
22 08120-80110 BOLT-hex, fix rear extension
23 08120-85510 BOLT-hex, fix rear extension 4
24 08915-23810 WASHER-spring 8
25 32137-H7200 PLATE ASS'Y-adapter
26   32133-18000 PIN-dowel, rear extension 2
27 08931-44210 PLUG-drain
28 32155-H7200 GASKET-plate coppes
29 32005-21000 SWITCH ASS'Y-reverse lamp
30 32703-15400 PINION ASS'Y-speedometer (17T)
31 32707-18000 SLEEVE ASS'Y-speedometer pinion
32 32709-18000   RING-O, speedometer pinion
33 32710-18000   RING-O, speedometer pinion
34 32708-18000   WASHER-speedometer pinion
35 32712-18000 PIN-retaining speedometer pinion
36 08915-13610 WASHER-spring 2
37 08110-61410 BOLT-fix speedometer 2
38-44 See CLUTCH WITHDRAWAL LEVER parts
not shown in catalog:
  45 30543-H1000 BOOT-rubber, mission case
  46 08120-85510 BOLT-hex 6 [part #1]
  47 08915-23810 WASHER-spring 6 [part #2]
48 30422-18000 COVER-dust, clutch
49 08360-61014 BOLT-hex, dust cover 3
5-speed Transmission Gear
18146.jpgAlbum click to view
TRANSMISSION GEAR (5 SPEED)
 1 32282-H7200 GEAR ASS'Y-reverse idle
 2 32281-H7200 SHAFT-reverse, idle
 3 32283-H7200 BEARING-needle reverse idle (2)
 4 32285-H7201 SPACER-needle bearing
 5 32293-73200 PING-retaining
 6 32284-H7201 WASHER-thrust reverse idler
 7 32213-H7200 GEAR-counter
 8 32220-H7200 GEAR-1st counter
 9 32221-H7201 RING-snap counter 1st
10 32223-H7200 BEARING-ball, counter shaft
as required
   11 32224-H7200 WASHER-thrust counter bearing (t=2.30~2.35)
   12 32224-H7201 WASHER-thrust counter bearing (t=2.35~2.40)
   13 32224-H7202 WASHER-thrust counter bearing (t=2.40~2.45)
   14 32224-H7203 WASHER-thrust counter bearing (t=2.45~2.50)
   15 32224-H7204 WASHER-thrust counter bearing (t=2.50~2.55)
   16 32224-H7205 WASHER-thrust counter bearing (t=2.55~2.60)
17 32200-H7200 GEAR ASS'Y-main drive
18 32611-H7200   RING-synchro
19 32612-H7200   BLOCK-thrust
20 32613-H7200   BLOCK-anchor
21 32614-H7200   BAND-brake 22 (2)
22 32616-H7200   CIR CLIP
23 32203-18000 BEARING-main driver gear
24 32205-18000 WASHER-thrust, main drive gear
25 32204-18000 RING-snap, main drive gear
26 32230-H7200 GEAR ASS'Y-1st, main shaft
27 32611-H7200   RING-synchronizer
28 32617-H7200   BLOCK-thrust 1st
29 32613-H7200   BLOCK-anchor
30 32614-H7200   BAND-brake
31 32616-H7200   CIR CLIP
32 32253-18000 BUSH-main shaft
33 32264-24900 BEARING-needle main shaft
34 32245-H7200 GEAR-reverse main shaft
35 32250-H7200	GEAR ASS'Y-2nd main shaft
36 32611-H7200   RING-synchronizer
37 32612-H7200   BLOCK-thrust
38 32613-H7200   BLOCK-anchor
39 32614-H7200   BAND-brake (2)
40 32616-H7200   CIR CLIP
41 32253-18000 BUSH-main shaft
42 32256-24900 BEARING-needle main shaft
43 32260-H7200 GEAR ASS'Y-3rd main shaft
44 32611-H7200   RING-synchronizer
45 32612-H7200   BLOCK-thrust
46 32613-H7200   BLOCK-anchor
47 32614-H7200   BAND-brake 25 (2)
48 32616-H7200   CIR CLIP
49 32264-24900   BEARING-needle
50 32270-H7200 GEAR ASS'Y-4th main shaft
51 32611-H7200   RING-synchronizer
52 32612-H7200   BLOCK-thrust
53 32613-H7200   BLOCK-anchor
54 32614-H7200   BAND-brake (2)
55 32616-H7200   CIR CLIP
56 32264-24900 BEARING-needle
57 32241-H7200 SHAFT-main
58 32605-H7200 HUB-synchronizer 2nd & 3rd, 4th & 5th (2)
59 32606-H7200 SLEEVE-coupling (2)
60 32604-H7200 HUB-synchronizer 1st & reverse
61 32265-18000 WASHER-thrust synchronizer hub
62 32720-14600 BALL-steel
63 32272-18000 BEARING-pilot main shaft
64 32246-G1000 WASHER-thrust, main shaft
65 32273-G1000 BEARING-ball, main shaft
66 32248-H7200 WASHER-thrust, main shaft
67 32354-H7201 NUT-hex
5-speed Transmission Control
TRANSMISSION CONTROL (5 speed)
 1 32816-H7200 ROD-fork, reverse & 1st
 2 32819-H7200 FORK-shift, reverse & 1st
 3 32293-73200 PIN-retaining fork 4 x 21
 4 32801-H7200 ROD-fork, 2nd & 3rd
 5 32805-H7200 FORK-shift, 2nd & 3rd
 6 32813-H7200 BRACKET-rod fork 2nd & 3rd
 7 32293-73200 PIN-retaining fork 4 x 21 (2)
 8 32809-H7200 ROD-fork, 4th & 5th
 9 32805-H7200 FORK-shift
10 32382-H7200 BRACKET-rod, fork 4th & 5th
11 32293-73200 PIN-retaining, for 4 x 21 (2)
12 32829-26760 BALL-checking
13 32829-26760 PLUNGER-interlock (2)
14 32830-18000 SPRING-checking ball (3)
15 32154-H7200 SPACER-checking spring
16 32834-H7200 PLUG-checking ball (3)
17 32892-H7200 ROD-striking
18 32896-H7200 LEVER-striking
19 32917-H7200 PIN-lock
20 08915-13610 WASHER-lock
21 08915-53610 WASHER-plain
22 08911-20610 NUT-hex
23 32850-H7200 GUIDE ASS'Y-striking rod
24   *32845-24900 PIN-ret, striking rod (2)
25 32857-14600 CAP-ring O
26 32858-14600 RING O, striking rod
27 32846-24900 RING-E 7S
28 32847-24901 PING-stopper control arm
29 32848-24900 RING O, control arm
30 00933-32800 PLUG-expansion
31 32851-24900 PLUNGER-return spring
32 32852-24901 SPRING-return
33 32856-24901 SPRING-reverse check
34 32853-E9300 PLUG-return
CONTROL LEVER & KNOB (5 SPEED)
35 32841-H1011 LEVER-control
36 32854-24900 RING E 9S
37 32849-H1010 PIN-control arm
38 32855-H1010 BUSH-control lever 2
39 32861-24900 BUSH-control lever head
40 32862-24900 BOOT-rubber, control lever
41 32865-H7200 KNOB-control lever
F4W56L Case
4-Speed Light-Duty to March 1973
NOTE: In the catalog, the diagram (shown above) does not match the numeric list
1 32100-H1630 CASE-TRANSMISSION 4 SPEED 1070- 2 32100-H1600
1 32101-H3900 CASE-TRANSMISSION 4 SPEED 0671-
1 32100-H3930 ASSY-CASE,TRANSMISSION 4 SPEED 0172- 2 32101-H3900
1 32100-H1600 CASE-TRANSMISSION 4 SPEED
2 32102-18000 PLUG-WELCH TRANSMISSION CASE 4 SPEED
3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED
3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0172-
4 00931-10810 PLUG-FILLER 4 SPEED
5 32110-H1000 ASSY-COVER FRONT T/M CASE 4 SPEED
6 32113-13200 SEAL-OIL FRONT COVER 4 SPEED
6 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0971- 2 32113-13200
7 32112-18000 RING-'O' FRONT COVER 4 SPEED
8 32208-18002 SHIM-ADJUST FRONT COVER T=0.1MM (0) 4 SPEED
8 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3MM (0) 4 SPEED 1071-
8 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2MM (0) 4 SPEED
8 32208-18000 SHIM-ADJUSTING FRONT COVER T=0.5MM (0) 4 SPEED
9 08120-82510 BOLT (3) 4 SPEED
10 08915-13810 WASHER-LOCK (3) 4 SPEED
11 32130-H3900 ASSY-EXTENSION REAR 4 SPEED 0172-0972 22 32130-H1010
11 32130-H6230 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0273- 0 32130-H3930
11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1072- 2 32130-H3901
11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0172- 2 32130-H3900
11 32130-H1030 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1070- 2 32130-H1010
11 32130-H1010 ASSY-EXTENSION REAR 4 SPEED 2 32130-H0110
11 32130-H0110 ASSY-EXTENSION REAR 4 SPEED
11 32130-H3901 ASSY-EXTENSION REAR 4 SPEED 1072-0173 30 32130-H3900
12 32132-18000 BUSH-REAR EXTENSION 4 SPEED
13 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 1072- 0 32136-H3100
13 32136-18001 SEAL-OIL REAR EXTENSION 4 SPEED
13 32136-H3100 SEAL-OIL REAR EXTENSION 4 SPEED 1071-0972 22 32136-18001
14 38322-N0100 ASSY-BREATHER 4 SPEED 1070- 2 38322-A0900
14 38322-A0900 ASSY-BREATHER 4 SPEED
15 32140-24900 BUSH-RETURN SPRING 4 SPEED
16 00931-10810 PLUG-FILLER 4 SPEED
17 08120-85510 BOLT (8) 4 SPEED
18 08915-23810 WASHER-LOCK (8) 4 SPEED
19 08915-43810 WASHER-PLAIN 4 SPEED
20 32137-H1010 ASSY-PLATE ADAPTER 4 SPEED
21 32133-18000 PIN-DOWEL REAR EXTENSION 4 SPEED
22 32141-24900 BUSH-STRIKING ROD 4 SPEED
23 32005-21100 COMP-SWITCH REVERSE LAMP 4 SPEED
23 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED -673 32 32005-21100
23 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773- 2 32005-21101
24 32005-H5000 COMP-SWITCHI,4 TH 4 SPEED 0773- 2 32005-21101
24 32005-21100 COMP.-SWITCH,4 TH 4 SPEED 0671-
24 32005-21101 COMP-SWITCH,4 TH 4 SPEED -673 32 32005-21100
25 32006-H6000 COMP-SWITCH,NEUTRAL 4 SPEED 0773- 2 32006-H3900
25 32006-H3900 COMP.-SWITCH,NEUTRAL 4 SPEED 0172-0673 3
26 08120-85510 BOLT FIXING TRANSMISSION (6) 4 SPEED
27 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED
28 24210-89957 CLIP 4 SPEED 2 24210-89922
29 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED SEDAN COUPE
30 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED
31 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED
32 32710-18000 RING-'O' SPEEDOMETER PINION 4 SPEED
33 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED
34 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED
35 08915-13610 WASHER-LOCK (2) 4 SPEED
36 08110-61410 BOLT (2) 4 SPEED
37 30422-18000 COVER-DUST CLUCH HOUSING 4 SPEED
38 08110-61010 BOLT (3) 4 SPEED
39 08915-13610 WASHER-LOCK (3) 4 SPEED
1973 LB110 USA Parts Catalog, page 50-1
F4W56A Case
4-Speed Heavy-Duty from April 1973
1 32100-H6210 CASE-TRANSMISSION 4 SPEED 0473- 2 32005-21101
2 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0473-
3 00931-10810 PLUG-FILLER 4 SPEED 0473-
4 32110-H1000 ASSY-COVER FRONT TRANSMISSION 4 SPEED 0473-
5 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0473-
6 32112-18000 RING-'O' FRONT COVER 4 SPEED 0473-
7 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3 (0) 4 SPEED 0473-
7 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2 (0) 4 SPEED 0473-
7 32208-18002 SHIM-ADJUSTING FRONT COVER T=0.1 (0) 4 SPEED 0473-
8 08120-82510 BOLT-FIX FRONT COVER (3) 4 SPEED 0473-
9 08915-13810 WASHER-SPRING (3) 4 SPEED 0473-
10 32130-H6200 ASSY-EXTENSION REAR 4 SPEED 0473-
11 32132-18000 BUSH-REAR EXTENSION 4 SPEED 0473-
12 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 0473-
13 38322-A0900 ASSY-BREATHER 4 SPEED 0473-
13 38322-N0100 ASSY-BREATHER 4 SPEED 0473- 2 38322-A0900
14 32140-24900 BUSH-RETURN SPRING 4 SPEED 0473-
15 00931-10810 PLUG-FILLER 4 SPEED 0473-
16 08120-85510 BOLT (8) 4 SPEED 0473-
17 08915-23810 WASHER-LOCK (8) 4 SPEED 0473-
18 08915-43810 WASHER-PLAIN 4 SPEED 0473-
19 32137-G1100 ASSY-PLATE ADAPTER 4 SPEED 0473-
20 32133-18000 PIN-DOWEL REAR EXTENSION (2) 4 SPEED 0473-
21 32141-24900 BUSH-STRIKING ROD 4 SPEED 0473-
22 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 3
22 32005-K1214 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 32005-21101,32005-H5000
22 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773-
23 32006-H6000 COMP-SWITCH 4TH LAMP 4 SPEED 0473-
24 08120-85510 BOLT-FIXING TRANSMISSION (6) 4 SPEED 0473-
25 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED 0473-
26 24210-89957 CLIP 4 SPEED 0473-
27 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 32702-15400
27 32703-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 2 32702-15400
28 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED 0473-
29 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED 0473-
30 32710-18000 RING-"O" SPEEDOMETER SLEEVE 4 SPEED 0473-
31 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED 0473-
32 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED 0473-
33 08915-13610 WASHER-LOCK (2) 4 SPEED 0473-
34 08110-61410 BOLT-FIX SPEEDOMETER (2) 4 SPEED 0473-
35 30422-H5010 COVER-DUST CLUTCH HOUSING 4 SPEED 0473-
36 08111-01614 BOLT-HEX DUST COVER (3) 4 SPEED 0473-
37 32719-18000 BUSH-SLEEVE SPEEDOMETER 4 SPEED 0473-
1973 LB110 USA Parts Catalog, page 50A-1
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Transmission_Case_Part_Numbers"
This page has been accessed 10,031 times. This page was last modified 05:31, 26 March 2019. Content is available under Datsun 1200 Club.
