Wheel Spacers
From Datsun 1200 Club
Category: Wheel And Tire
Got rims with too much positive offset? Using wheel spacers may fix it. Or have rims with a different bolt pattern? Conversion spacers can fit 5-lug or other rims to the Datsun 1200.
Hub-centric means they center on the hub. Datsun 1200 uses 71mm hub registration diameter - so 66 mm hubcentric for S13 won't fit, unless the center hole of the spacer is drilled out larger.
Have them machined to 71mm center hole
16008_50fe6b92f0e0b.jpgPost 428278
For example, +30 wide wheels fit the rear fine, but need a +15 spacer on the front.
4130.jpg 7314.jpg 9342.jpg 9360.jpg 9361.jpg 9424.jpg 9425.jpg 10102.jpg 10654.jpg
Sources
http://ebay.com - search for:
 4x114.3 M12x1.25 wheel spacers
or
 4-on-4.5 4-lug wheel spacers
Autobarn
GKTech
Simple Spacers
Thin spacers do not have studs, they simply fit between the hub and the wheel -- the the stock studs go through them.
Except for the thinnest 1/4" (6 mm ) spacers, longer studs are needed. Stock are M12 x 1.25 32mm long. Knurl Diameter: 13.00mm
Longer 55 mm versions (which are really long)
* NISMO 40222-A0220 [2" long/51mm]
* For B110 front, 510 front
* Knurl Diameter: 12.90mm
These match the NISMO but are shorter: length 45.5mm
* 40222-15C01 GC22 Van $2.12 USD each
For more choices, see Wheel Studs.
13552.jpg caution
Bolt-On
Bolt on spacers need to have M12 x 1.25 studs.
4104.jpgAlbum click to view 20890.jpgAlbum click to view 13733.jpgAlbum click to view
Weds Gear 15mm spacers
th_weds_gear_wheel_spacers-315mm.jpg th_weds_gear_wheel_spacers-1.jpg th_weds_gear_wheel_spacers-2.jpg
PCD Conversions
Pitch Circle Diameter (also known as Bolt Circle) for Datsun 1200 is 4.5 inch (metric equivalent: 114.3 mm). Bolt-on spacers with a different external PCD allow you to bolt on different wheels.
4/114.3 to 5/114.3
100 PCD rims on 1200
3Rotor convertor plates
4x100 to 4x114.3
19195.jpgAlbum 19195
Discussions
Fitting TRX rims to my Datsun 1200
fitting r31 steelies fitment help
Need Advice on Spacers for +38 offset
4-lug
Bolt pattern: 4.5 inch circle (114.3 mm PCD)
Hub hole: 71mm
Nissan Competition
Sports Options Catalog
3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Wheel_Spacers"
This page has been accessed 15,606 times. This page was last modified 06:17, 7 November 2017. Content is available under Datsun 1200 Club.
