There is no page titled ":Pickups". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Engine Swaps (25633 bytes)
156: ... inexpensive coming out of Nissan Navara/Hardbody pickups. - Rear Axle Swaps (25587 bytes)
413: ...atsun Roadsters, 1600 wagons, 320/520/620/720/D21 pickups and other Datsuns. - Emission Controls (28391 bytes)
135: ...ll USA models, and later Japan and Australia 1200 pickups were required to control the amount of gasoline v... - Ignition Switch (12532 bytes)
77: ... for USA 1200s, JDM GL and GX, and newer JDM 1200 pickups - PB110 (13860 bytes)
11: * There were no Excellent 2-dr sedans, wagons or pickups - Datsun B10 (13852 bytes)
99: ...f the heavy body-on-frame construction of the 320 pickups. - Trayback Utes (2462 bytes)
1: [[B120|Datsun 1200 pickups]] -- being [[Coupe Utility|Coupe Utilities]] (ute... - B120 (15832 bytes)
197: ...They are commonly called '''Camionetas''' (little pickups) and also nicknamed '''Picopita''' (micro pickup)...
200: ...óviles de Ecuador) assembled CKD LHD Nissan 1200 Pickups in an in-country assembly plant from 1987-1999. T... - Console (9887 bytes)
12: * [[B120]] Pickups as standard equipment (except STD models) - L-series Engine Swap (21327 bytes)
231: ...B (610) sump is slightly more rearward. Sumps and pickups can be interchanged, but the blocks may need to b... - Borg Warner Differential (6981 bytes)
126: ...ng, about as strong as the [[H190]] in the Datsun pickups. - Ddgonzal's Sunny Truck (21199 bytes)
171: ...able]], so no clutch cylinder is needed. LHD 1200 pickups I expect will have a clutch cylinder system. - Datsun History (23876 bytes)
310: ...sun''' name used as a model name in Japan for D21 pickups (known as Navara or Harbody in other countries). - Canby (11736 bytes)
23: Along with Z-cars, wagons, Pickups and Roadsters, These Datsun Sunnys were spotted: - KA Engine Swap (19582 bytes)
1: ...ly available and inexpensive coming out of Nissan pickups and Nissan 240SX (USA silvia S13 & S14). It will ...
144: * Nissan pickups: RWD - Axle Shaft (14409 bytes)
140: * Nissan D21,D21U,D22 Hardbody/Datsun pickups 1986-2000 - Sedan Grille (5922 bytes)
3: ... fitted with a stainless metal grille. Early 1200 Pickups (1971-1978) use this too. The 1972 JDM [[Facelift... - Finn JAE (4160 bytes)
16: pickups, 1200s, B310, others - Sales (876 bytes)
31: = Pickups = - Electric Fuel Pump (6998 bytes)
29: Stock on newer Nissan Patrol and Datsun 720 pickups:
