There is no page titled ":Voltmeter". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 18 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Emission Controls (28473 bytes)
251: ...er to the switch with wires into the cabin. Use a voltmeter to read the voltage while driving. It should swit... - Wiring (8463 bytes)
6: ...ticle. You don't want to burn something up! Use a voltmeter or test light to confirm the circuit behavior. - B-210 Electronic Distributor Swap (12611 bytes)
74: ... a about 750 ohms resistance. And using an analog voltmeter, should waver while cranking. - Alternator (7571 bytes)
72: ...ernator should output 13.5v to 15v at 1200 RPM. A voltmeter is the only tool needed for testing. - Wiring Diagram (7077 bytes)
1: ...ticle. You don't want to burn something up! Use a voltmeter or test light to confirm the circuit behavior. Th... - Matchbox Testing (6372 bytes)
17: ...malfunctions. One of the tests requires an analog voltmeter, so old-fashioned meter is good.
37: # Connect Voltmeter directly to battery terminals (NOT THE CABLE ENDS...
45: # Connect Voltmeter to battery cable ends at battery
46: # Observe Voltmeter while cranking engine for approximately 15 second...
72: # connect Voltmeter (20V scale) between distributor case and the "B" ... - Wiper Wiring (4105 bytes)
47: # Use voltmeter, put NEG cable to battery NEG terminal - Electric Parts List (1844 bytes)
50: ...ccar.com/forums/showthread.php?p=172136 Gauges]: Voltmeter, etc. - CHW Electric 1200 (15181 bytes)
55: ...s going on in your mobile power station. One is a voltmeter for an indication of the batteries' charge state ...
65: ...um!|7962}}<br><i>Extra instrumentation includes a voltmeter and ammeter</i></p> - Alternator diagnoses (8198 bytes)
1: ...nator]] should output 13.5v to 15v at 1200 RPM. A voltmeter is the only tool needed for testing. Further, he ... - Starter Testing (4349 bytes)
9: ...only needs 3 things, which you can measure with a voltmeter or test light:
57: ...ff the starter. It is the small B/Y wire. Connect voltmeter to this wire, and other lead of the VM to the bat...
59: **** The voltmeter stays at 0 when key is turned to START. This indi... - IR Alternator Conversion Wiring (7659 bytes)
69: You can double-check all this with a voltmeter. - B210 Gauges (13538 bytes)
63: ...lock was standard on GX, optional for the others. Voltmeter replaced the AMP gauge for B211 (after 1975 Octob...
110: == Voltmeter ==
113: 25030-H5600 Voltmeter Round type
114: 25030-H5100 Voltmeter Square type
118: [[Sunny_Genuine_Option_Parts#Voltmeter|OPTION voltmeter]] for all Coupes. Standard on GX coupe and sedan - DATSUN Sunny Coupe 1600/1400 1200 (6085 bytes)
63: * voltmeter ((Sedan GX, Coupe) - B210 Option Parts (45877 bytes)
44: ...288;     19 [[#Voltmeter]]
317: = Voltmeter =
322: {{Translate|電圧計|Voltmeter}}
462: ...are set to match the instrument's meter. The tach-voltmeter is a tachometer with a volt meter built-in. By sw... - Brown PB210 (4095 bytes)
25: [[Voltmeter]] - DATSUN Sunny Excellent 1600 (3217 bytes)
64: * voltmeter ((Sedan GX, Coupe) - Sunny Genuine Option Parts (37388 bytes)
162: Tach-Voltmeter, Tachometer, Oil+Ammeter, Oil+Volt Gauges
165: ...#12479;ー|[[B210_Gauges#Tach-Voltmeter|TACH-VOLTMETER]]}}
168: A tachometer and voltmeter in one set. For the square meter car. Attach it t...
184: ...3;圧計|[[B210_Gauges#Auxiliary_Meters|VOLTMETER, AMMETER, OIL PRESSURE GAUGE]]}}
187: Voltmeter (round type)
