R31
Revision as of 10:23, 4 November 2012; view current revision
Category: Nissan Vehicles
Nissan Skyline model R31 was built in Japan 8508-9005. It was fitted with a Four Cylinder CA engine, or six-cylinder RB engines, or a Diesel. Australia-built R31 1986-1990 was sold as Skyline (six-cylinder) or Pintara (four-cylinder). Some parts can be use, or modfied for use, on a a Datsun 1200.
Engine
JAPAN
F CA18S
H RB20E/RB20ET SOHC
R RB20DE/RB20DET DOHC
S RD28 diesel
AUSTRALIA
Skyline: Holden RB30E
Pintara: CA20E (NAPSX)
SOUTH AFRICA built
CA20S
RB20E
RB30E
Wheels
R31 Pintara 15x6 rims
R31 Skyline 14" steelies. See [[Wheels#Skyline R31 spare steel wheels |Skyline R31 spare steel wheels ]]
Front Brakes
R31 on B10
Strut
Diff
JAPAN R31
H190: CA18S Sedan, Hardtop, Wagon
CA200: Wagon RB20T [4.11, 8601-]
R200: RB20, RD28 Sedan, Hardtop [IRS]
AUS R31 Borg Warner
BW78: Pintara, has rear disc brakes
 10-bolt octagonal cover
 25-spline axles
AUS
Series II Silhouette LSD
Rear Discs - see R31 Australia
R31 Skyline
R31 Handbrake Lever in 1200
Swapping into 1200
You can swap a narrowed axle into a 1200.
R31 axle narrowed and installed in 1200
Leaf Spring pads
CA200
JAPAN R31 Wagon with RB20T SOHC Turbo 1986-1990
* (build dates 8601-9005)
CA200: Wagon RB20T [4.11 (CA41), 8601-]
* Drum brakes
* 5-link with coil springs
* 4-lug, 28-spline(?) axles
CASE-DIFFERENTIAL
* 2-pinion
* M12 ring gear bolts
* Fits: CA41,CA43,CA46,CA48,RC35,RC37,RC39,RC41,RC43,RC46
38421-12S00 8601-8708
38420-P9400 8708 <2> 38420-12S10
CA41 37/9=4.111
38100-F3400 8601-8604
38100-F3401 8604- $677 USD
SHAFT ASSY-REAR AXLE
38162-42L00
* R31 with CA18S
* R31 Wagon
* C32 some
* GC22 Vanette 8605 2WD
DRUM-BRAKE,REAR
43206-U4800
43010 CASE ASSY-REAR AXLE
43005-84S55 HOUSING W/GEAR <2> 43005-84S56
38423 GEAR-SIDE
38423-C6100
* (G)C22,D22,E23,E24,F22,F23,R31,WD21,160,250,
Alternative for swaps: GC22 Vanette - CA200 w/LSD
