R31
Revision as of 11:07, 4 November 2012; view current revision
Category: Nissan Vehicles
Nissan Skyline model R31 was built in Japan 8508-9005. It was fitted with a Four Cylinder CA engine, or six-cylinder RB engines, or a Diesel. Australia-built R31 1986-1990 was sold as Skyline (six-cylinder) or Pintara (four-cylinder). Some parts can be use, or modfied for use, on a a Datsun 1200.
Engine
JAPAN
F CA18S
H RB20E/RB20ET SOHC
R RB20DE/RB20DET DOHC
S RD28 diesel
AUSTRALIA
Skyline: Holden RB30E
Pintara: CA20E (NAPSX)
SOUTH AFRICA built
CA20S
RB20E
RB30E
Wheels
R31 Pintara 15x6 rims
R31 Skyline 14" steelies. See [[Wheels#Skyline R31 spare steel wheels |Skyline R31 spare steel wheels ]]
Front Brakes
R31 on B10
Strut
Diff
JAPAN R31
H190: CA18S Sedan, Hardtop, Wagon
CA200: Wagon RB20T [4.11, 8601-]
R200: RB20, RD28 Sedan, Hardtop [IRS]
AUS R31 Borg Warner
* 9-bolt octagonal cover
* has rear disc brakes with finned calipers
BW78: Pintara, 25-spline axles
BW78: Skyline, 28-spline axles
AUS
Series II Silhouette LSD
Rear Discs - see R31 Australia
R31 Skyline
R31 Handbrake Lever in 1200
R31 Skyline: 28-spline axles
R31 Pintara: 25-spline axles
Silhouette had 4-pinion LSD
Mini-spool
Swap Notes
R31 axle narrowed and installed in 1200
R31 into B310
Creating Leaf Spring pads
Lowering Spring Pads
Handbrake cable considerations
11823.jpg 11919.jpg 12753.jpg 12754.jpg 12755.jpg 12864.jpg 12865.jpg 12864.jpg
R32 into 120Y
CA200
JAPAN R31 Wagon with RB20T SOHC Turbo 1986-1990
* (build dates 8601-9005)
CA200: Wagon RB20T [4.11 (CA41), 8601-]
* Drum brakes
* 5-link with coil springs
* 4-lug, 28-spline(?) axles
CASE-DIFFERENTIAL
* 2-pinion
* M12 ring gear bolts
* Fits: CA41,CA43,CA46,CA48,RC35,RC37,RC39,RC41,RC43,RC46
38421-12S00 8601-8708
38420-P9400 8708 <2> 38420-12S10
CA41 37/9=4.111
38100-F3400 8601-8604
38100-F3401 8604- $677 USD
SHAFT ASSY-REAR AXLE
38162-42L00
* R31 with CA18S
* R31 Wagon
* C32 some
* GC22 Vanette 8605 2WD
DRUM-BRAKE,REAR
43206-U4800
43010 CASE ASSY-REAR AXLE
43005-84S55 HOUSING W/GEAR <2> 43005-84S56
38423 GEAR-SIDE
38423-C6100
* (G)C22,D22,E23,E24,F22,F23,R31,WD21,160,250,
Alternative for swaps: GC22 Vanette - CA200 w/LSD
