Lowering the car makes it handle transitions better. And it looks cool. One way to lower the rear is to add another spring to your rear leaf spring pack and reverse one onto the top of the pack, while flipping it. This should lower and stiffen the rear end slightly.
Also see: Lowering
Flipping the middle leaf makes the stiffer spring pack and lessens the spring camber so the vehicle sits lower.
A vice or G-clamps (C-Clamps) does a good job. Use a rod through the bolt hole of all the leaves to make sure they stay straight and you can get the bolt back through when your done.
We accept no responsibility for damage to your self, others personally or property. YOU take the risk of working on your car and should follow all safe and accepted work practices.
Flipped Overload (not sure what this would do)
How-To
To flip the rear leaf springs:
- up the car, take off the wheels
- Unbolt the U bolts from the rear axle, spring pack and then un bolt the front 3 mounts for the leaves. Unbolt the rear bolts and remove the spring pack
- Now using G clamps, compress the spring pack and unbolt the center locating bolt. Then slowly undo G clamps releasing the spring pack to individual leaves
- Bend the leaf-retainers out of the way, just enough to clear the leaves. These hold the leafs from moving side to side.
- Flip the 2nd bottom spring onto the top of the pack and added another longer 2nd bottom leaf. In a ute pack flip the 2nd longest one on the top should lower it a bit over one inch. If using sedan leaves just flip middle one on the top.
- Using a long screw driver through the center locating holes, loosely repacking them then doing them up tight and slowly with the G clamps again till completely compressed. USe the screw driver tho keep the leaves aligned. Once compressed, re insert the center securing bolt and tighten.
- Using a hard plastic mallet, smack the side-retainers back into place.
- Re-installation is reverse procedure of removal
