Some manual transmissions were fitted with an electrical Neutral Switch to signal when the gearbox is not in gear. All Automatic Transmissions are fitted with a an Inhibitor Switch which also signals when the automatic is in Neutral.
Also see: * Top Switch * Reverse Switch
Neutral Switch was first used in 1973 USA models.
Neutral Switch was used for:
* EGR (some years e.g. 1990 1200, 1975 B210) * Fuel Shut-Off System on B310 * Starter interlock on automatic cars * Throttle Opener used the Inhibitor Switch to detect neutral * TCVAS spark control used the Top Switch to detect neutral
Neutral Switch is near top of 4-speed 56-Series Transmission
Reverse Switch is on bottom or side (not near the top)
Reverse Switch
See main article: Reverse Lamp Switch
Reverse Switch is located on the shifter extension of tail housing very near the top of the housing.
Top Switch
Top Switch is used by the TCVAS system.
See main article: Top Switch
Also See: * Inhibitor Switch for automatics * 63-Series_Transmission#Switches
32130, 32006
32005-21101 SWITCH ASSY-REVERSE LAMP 32006-G6200 NEUTRAL POSITION SWITCH
B310 USA A12 56-series 4-speed * 32005-H5000 SWITCH COMP-REVERSE LAMP <> 32005-K1201 <> 32005-K1202 * 32006-K2400 SWITCH COMP-NEUTRAL <> 32006-K2401 CAL 0879- * 32006-K2000 SWITCH COMP-4TH <> 32006-D0120 <> 32006-D0102 A14/A15 60-series 4-speed * Reverse same as 56-series 4-speed * Neutral same as 56-series CAL 0879- CAN * SWITCH COMP-TOP (0879-) - same as 56-series FED, CAN A14/A15 FS5W60L & FS5W60A 32005-K1000 SWITCH COMP-REVERSE LAMP <> 32005-K1001 <> 32005-K1002 32005-H5000 SWITCH COMP-REVERSE LAMP <> 32005-K1201 <> 32005-K1202 32006-D0102 SWITCH COMP-TOP <> 32006-D0120 32006-K2000 SWITCH COMP-TOP 32130-H9000 32130-H9010 32130-H9705 32006-K2400 SWITCH COMP-NEUTRAL <> 32006-K2401 CAL COUPE
NOTE: Sometimes misspelled as 'Nuetral Switch'
