Tachometer
Revision as of 10:57, 12 February 2016; view current revision
Categories: Body Electrical System | Options
Optional for the Datsun 1200 was an 8,000 RPM Kanto-Seiki tachometer. It was usually housed in the round-gauge instrument panel to the left of the Speedometer. It may also be placed in the optional floor Console.
[hide]
USA 1972 Owners manual (see pages 8-9 for Tacho information):
The tachometer is electrically operated and indicates engine speed calibrated in hundreds of revolutions per minute (rpm). two color zones are on its face. For normal driving, your vehicle should be driven in the yellow or non-color sectors.
2129.jpg PB110 2209.jpg Options 5703.jpg 50.JPG S1 5153.jpg Ute 6595.jpg SSS 8985.jpg B140
Location
Parts Catalog shows GL came with a Clock in the dash, and the GX came with an 8,000 RPM tachometer in the dash, while the clock was moved to the floor Console. Tachometer was optional on DX or GL round dash models.
Dash
PB110
Tacho in dash, blank plate in Console
7730.jpg album
Tacho in dash, Clock in Console
Console
Specials Datsun 1200 SSS and Datsun 1200 S1 placed the tachometer in the floor console. It is preferable to have the Tachometer at eye-level, however these models came with square-gauge dashes.
SSS
S1
See main article: Tachometer Wiring
NO tachometer is listed for Sunny Truck, but only a Clock. Even so it is common to see tachometers installed in 1200 Trucks, as they fit the same.
24855-H1800 1200 TACHOMETER 8000 RPM [6400 redline]
1691.jpg 1690.jpg 26335.jpg 26333.jpg 26334.jpg th_24855-H1800.jpg th_24855-H1800_.jpg th_24855-H1800-.jpg
24855-H2300 1200 TACHOMETER 8000 RPM GX
24855-H1075 1200 FACTORY RACE TACHOMETER Calibrated to 10,000 RPM with adjustable redline needle. Installation same as 24855-H1800
24855-H3100 1972 B110 8000 RPM [Facelift] (Except GX)
24855-H3400 1972 B110 GX 8000 RPM [Facelift 6800 redline]
620 Tachometer
The Datsun 620 truck tachometers fits Datsun 1200 and looks very similar. But 620 models have 7000 rpm yellow line for L20B engine (1200 tach has 6400 rpm redline).
1976-1979 620 Tachometer [7000 redline]
full
620 in Japan did not have a factory tachometer option.
1972-1975 early 620 USA
* 24840-B6400 KIT-TACHOMETER OP -0775
* 24054-B6400 ASSY-CABLE,TACHOMETER
1976-1979 late 620 USA
* 24855-B8000 ASSY-TACHOMETER OP 0875-
* tachometer wiring is built into every 1976-1979 620
The later Tachometer Wiring is different. It is a typical tap connection, instead of the Datsun 1200 'passthru' induction wiring.
Comparison
Early 1200 Tachometer has wiring loop:
Late 1200 Tachometer/620 Tachometer has no wiring loop:
These two types are wired completely different. See Tachometer Wiring.
Facelift
See 1972 minor facelift
Bprojects
Bprojects Sunny Truck tachometer, looks like genuine.
6500 RPM redline
full
full
Green to Illumination
Black to Earth
Red to I/G 12V
Yellow/red to ignition coil - (minus)
full
full
12,000 RPM Tachometer
Kanto Seiki 12,000 RPM unit, perhaps for mechanical tach drive
Mechanical Drive
Datsun Competition offered a mechanical tachometer.
See main article: Tach Drive
Aftermarket Tachometers
669.JPG dash top 1451.jpg console
226.jpg 236.jpg 268.jpg on column
308.JPG 1411.jpg1548.jpg 1801.jpg 1886.jpg 1978.jpg 2028.jpg 2041.jpg under dash 2531.jpg
2729.jpg 2837.jpg 2912.jpg 3791.jpg Silvia tacho
3940.jpg 4164.jpg three tachos
4181.jpg 4485.jpg 4599.jpg 4600.jpg 6598.jpg 5033.jpg 5041.jpg 5043.jpg 5243.jpg 5244.jpg 5539.jpg 5640.jpg 5748.jpg 6279.jpg 6703.jpg 6842.jpg silvia
7373.jpg 7566.jpg 7703.jpg 7769.jpg 8208.jpg 8860.jpg 8872.jpg 9848.jpg 9940.jpg 10710.jpg 10711.jpg 10747.jpg 10960.jpg 10157.jpg 11126.jpg 12631.jpg 12715.jpg 12373.jpg 12404.jpg 12472.jpg 12473.jpg 12479.jpg 12480.jpg 12534.jpg 13092.jpg 13119.jpg 13275.jpg 13276.jpg
226.jpg 601.jpg 864.jpg 957.jpg 958.jpg 1087.jpg 1132.jpg 1411.jpg 1537.jpg 1548.jpg 1690.jpg 1691.jpg 1801.jpg 1886.jpg 1978.jpg 2028.jpg 2041.jpg 2129.jpg 2192.jpg 2209.jpg 2708.jpg 2729.jpg 3235.jpg 3940.jpg 5043.jpg 5153.jpg 6347.jpg 6595.jpg 6598.jpg 7769.jpg 8764.jpg 8840.jpg 8882.jpg 9732.jpg 9997.jpg 10710.jpg 10761.jpg 12133.jpg 12134.jpg 12631.jpg 12715.jpg 13119.jpg 13689.jpg 13883.jpg 13937.jpg 13938.jpg 14194.jpg 14968.jpg 15275.jpg 15705.jpg 16721.jpg 17843.jpg
rev counter tacho tach rpm gauge タコメータ
