Datsun 1200s came with different types of seats, depending on the market. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Operation
sedan - fixed, with recliner OPTION sedan GL, GX - x-pattern cloth coupe - recliner, x-pattern cloth truck - fixed, no recliner
Coupe Seats - sporty trim, but light with very little padding
Sedan Seats - flatter, with a bit more padding
Danish two-tone seat option
Japan STD, Deluxe - vinyl, black or yellow GL - fabric insert GX - plaid fabric insert B110 GX-5 - hi-back seat, black KPB110 GX - hi-back seat OPTION with ovoid recliner control * laterally-padded seats KPB110 GL - laterally-padded seats B210 - low-back seats with small headrest KB210/KPB210 - hi-back seats with round recliner control KPB210 GLL/GXL - low-back seats with small headrest B120 1978-1989 hiback seats, BROWN B120 1989-1994 hiback seats, Black with GREY inserts
Hiback seats - factory fitted to GX-5
full
GL seat
Headrests
Location
Front seat risers A seat cross member B inside seat bracket C outside seat bracket album
Also see: Coin Tray
Sunny Truck
Many B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replaced with an adjustable seat rail.
1971-1978 Black low-back seats 1978-1989 Brown hi-back seats 1989-1994 Gray hi-back seats
-7803 Early Datsun 1200 utes * sedan seat bottom * Truck unfinished back * fixed (non-reclining) * thin headrest ** 87700-G1001 Head Restaint Assy OPTION ALL(assist)
7803-8910 - Brown * High-back seat (no external headrest)
8910- Gray
Coupe, Sedan seats fit in ute, no problem, even though they are a little thicker than truck seats
Catalytic Converter Seats
later seats have passenger side lower mount -- to clear the catalyst bulge in the floor.
1976-1978 B-210 pictured here (1989-up Sunny Truck is similar)
Stock Seats
USA models:
- 1973 models had blue or beige seats. Black was available (again) on from 0173
- 1971-1972 models:
- Coupe: Black, Beige or (optional) Yellow
- Sedan: Black, Yellow, Gray
- Reclining seats standard on coupe
- Sedan had folding non-reclining seats with (optional) reclining seats
- Sedan had some sort of optional front seats
Standard, Deluxe and Reclining Seats
Aussie-Market
STD
1200 Coupe seats (custom fabric) in Datsun 1000
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to sedan seats with a slim-profile headrest.
Bench Seat
120Y bakkie and 140Y bakkie (B140) came with a 3-passenger bench seat
Also see: B140_Model_Changes#Bench_Seat
Parts
- 86982-A0600 Eyelet 'A' Seat Back $1.12
- 86983-A0600 Eyelet 'B' Seat Back $0.85
- 87550-H1603 Slide-seat LH $44.33
- 87500-H1603 Slide-seat RH
- 87400-M3000 Hinge-recline RH $179.58
- 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
- 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
- 74961-H1100 TRIM-seat riser (R.H.) DX, GL
- 74962-H1100 TRIM-seat riser (L.H.) DX, GL
TRIM-SEAT RISER, RH
- 74961-H1100 7510-7803 BLACK
- 74961-G1060 7804-8910 DARK BROWN
- 74967-95W00 8910- GRAY
TRIM-SEAT RISER, LH
- 74962-G1000 -7803 BLACK
- 74962-G1060 7804-8910 DARK BROWN
- 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
- 66919-H1001 -7803 BLACK
- 66919-H1001 is superseded by 01553-00291 $0.80 USD
- 66919-G1060 7804-8910 DARK BROWN
- 96815-B0700 8910-
TRIM CLIP is also used by the Kick Panel and coupe rear interior panels
Datsun 1000 Seats
Headrests
See main article: Headrests
Alternative Seats
S14 seats
Corolla Laser Prelude Covers Daihatsu Buff's EFI Honda? MOMO
Recaro Seats
Recaro is the premium automobile seat company.
Upholstery
See main article : Upholstery
Custom Upholstery
Racing Seats
Forza seats - The 1200 rails line up perfectly, although need to drill new holes for the rear bolts and fit a couple of spacers.
Seat Rails
See main article: Seat Rails
Adapting Seats
NOTE: When bolting in seats, use high-strength bolts (10.8 spec), so that in a minor accident the bolts do not break.
B210* seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
Seat Slide (aka Seat Rail)
* early B210 seats fit B110 directly * late B210 seats have a non-flat bottom
If you don't have the B110 rails, you can adapt B210 or B310 slides:
Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Chassis Brackets - for flat seat runners
Account and pictures of how to adapt Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
See Main Article: Rear Seat
Australia Legalities
See Also
* Seat Photo Index
