Convert your A engine to EFI.
Manifold and Injector
Rather than fabricate a custom manifold, use the stock one that's already on your A12! The photo here show the intake unbolted from the exhaust, but you can do it while it's still together.
Parts needed:
- Stock A12 intake manifold
- #Throttle Body (40mm) from a Hyundai Excel/Accent X3 SOHC
- #Fuel pressure regulator from a circa 1997 Misubishi Lancer
- 3-5mm thick alloy plate for the adapter
- Fuel Injector (365cc for stock A12)
- Buy a brass Tee 1/4"
- Drill each end to 14mm opening for the push-in type injector and the push-in type regulator
- leave center T threaded, and screw in a barbed line fitting (for fuel supply hose)
- Drill the manifold PCV opening with 14mm drill bit (for push-in type injector)
The injector assembly can be secured to the manifold with simple copper wire tie, or positively bolted on using custom brackets (see injector mounting).
Pressure Regulator/Injector assembly installed
You can use the stock 1200 air cleaner
A seal between the throttle body and air cleaner can be fabricated, maybe using rubber hose cemented to the air cleaner bottom
Throttle Body
The X3 Excel Throttle Body is dime-a-dozen and easy to adapt. The 1995-1999 Hyundai Excel X3 (Accent in USA) SOHC engine is the source. Don't forget to get the wiring harness connectors and a couple of inches of wiring for the attached TPS.
From the wreckers, get the throttle body with TPS attached.
New TPS is as inexpensive as $22 rockauto.com. New Throttle Body (mixing body) is $183 from Hyundai, so buy a used one for $30 or so at the wreckers.
Hyundai X3 (Accent/Excel/Verna)
Fabricate the adapter out of aluminum sheet, using a stock gasket as a pattern
Smooth Throttle Bore to better match the manifold. Use a round file or a rotary grinder
Drill new holes in the Throttle Body flange and bolt it on
Remove throttle bracket from Datsun carburetor
After cutting, bolt to the Throttle Body
Fabricate throttle cable bracket from a short length of tubing and a strip of sheet metal
Fuel Pressure Regulator
Fuel Pressure regulator from a 1997-2001 Misubishi Lancer 1.5 engine, $15 used
Search $35 RockAuto.com 51 psi BECK/ARNLEY 1580463 {#MD311979) STANDARD MOTOR PRODUCTS PR247 AIRTEX / WELLS 5G1265 Denso MD 311979![]()
Mitsubishi Lancer/Colt/Mirage 1997-2001
Sensors
With MegaSquirt you won't need the Datsun airflow meter. Instead, Megasquirt will calculate the air mass using a MAP sensor and and IAT sensor.
- MAP sensor is built into Megasquirt. Connect vacuum hose to manifold
- Obtain GM IAT sensor from a Chevrolet or Holden. Drill hole in your air cleaner and hot-glue the IAT in place. Or use JB-weld. Threaded bungs are available if you want to get really fancy. You can also place the sensor in a air-cleaner-to-throttle body pipe/hose. Alternatively you can drill the throttle body and tap it (3/8 NPT) to accept the sensor (see post)
* MegaManual * GM IAT Sensor 12146312 $10 RockAuto.com* GM sensor connector 12162193 $5 RockAuto.com
Fuel System
Use a external EFI fuel pump, connected to the stock fuel line coming from the tank. We have selected a 51-psi system, so need a pump capable of high-pressure.
* Carter P74015 $70 rockauto.com * Airtex E8228 Universal $79 Amazon.com
Pump can be placed in engine compartment or back by the tank
Run a regular low-pressure fuel line from the regular back to the the tank, and Tee it in to the filler hose. If you keep the tank above 1/4 full no extra baffles or surge tank are needed. If you want, add a $50 Surge Tank.
From the fuel pump output to the fuel rail, use EFI-rated fuel hose and EFI hose clamps. Use a 280ZX-style fuel filter.
280ZX EFI fuel filter $3 RockAuto.com
The fuel pump is wired up with a relay -- you don't want the high current to go through your ignition switch. As cheap as $10 for a used Nissan relay.
See: Electric_Fuel_Pump#Wiring
Ignition and Distributor
The ECU can take the RPM signal direct from your existing points-based distributor. It's also compatible with electronic ignition distributors.
Wire up the MegaSquirt harness
- 12V
- earth/ground
- fuel pump relay
- injectors
- IAT signal & ground/earth
- Tach signal (coil negative terminal)
For full details, see http://www.megamanual.com/mtabcon.htm#wire
ECU
Buy MegaSquirt II fully assembled about $400 USD or $500 AUD off eBay.
ECU Configuration
Download at http://www.diyautotune.com/softwarelinks.htm
- Mac
- Windows
- Linux
You have a choice:
- TunerStudio free version (most popular software for MegaSquirt)
- Free version supports all MegaSquirt features
- SuperTunix open source
In the software configure:
CONSTANTS Required Fuel * displacement 1171cc (A12) * # of cyl 4 * injector flow rate 365 * desired AFR 13 Injector open time 1.0ms batt V correction .20 PWM current limit 1000% PWM time threshold 25.4 Fast Idle Threshold Barometric Correction: Off Control Algorithm: Alpha-N (TPS) Injections per Engine Cycle: 2 squirts Injector Staging: simultaneous Injector Port Type: throttle body Engine Type: even fire
VE TABLE
Generate a new table based on your peak horsepower and torque figures ('Settings/VE Table/Tools/VE Specific/Generate VETable').
ENRICHMENTS EGO Step (%): 0 Warmup enrichment -40F 180% -20F 150% 0F 140% 20F 135% 40F 130% 60F 125% 80F 118% 100F 110% 130F 103% 160F 100%
Afterstart Enrichment: between 25-45%for 100 to 250 cycles,
Software Tuning
Start your engine and let idle. Go to http://www.megamanual.com/v22manual/mtune.htm
And start tuning.
A big help in turning is to fit an Air Fuel Ratio Gauge. MegaSquirt 2 can directly read the wideband output of the wideband controller, but more importantly you can see the A/F Ratio on the gauge.
See Main Article: Oxygen_Sensor#Air_Fuel_Ratio_Gauge
The paid version of TunerStudio has a software auto-tuner which is supposed to be great, but it still requires some work (it's not totally automatic).
Cost
* $400 ECU with wiring * $ 0 Stock A12 intake manifold * $ 30 Throttle Body * $ 15 Fuel pressure regulator * $ 5 3mm thick alloy plate * $ 7 Fuel Injector * $ 20 new IAT Sensor & connector * $ 79 new 60psi fuel pump * $ 15 fuel hose & clamps (for front-mount pump) * $ 3 high-pressure fuel filter * $ 10 Nissan relay * $ 5 fuel pump wires * $ 3 fuse * $ 20 oil pressure safety switch * $ 6 1/8 BSPT-to-1/8 NPT adapter * $ 6 fuel filler hose Tee * $ 10 generic air hose ------ $ 632 TOTAL not including tax & shipping
Tuning: * $181 new A/F gauge, wideband controller & sensor or * $? engineer & dyno time
