<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Truck Fuel Tank
Early
To February 1973
Applied Model Codes
148 designed for Datsun 520 light truck
156 designed for Bluebird 410 1200 2-door DP410-R
158 designed for R411 with R-engine
180 designed for Datsun B10 introduction (1966)
H10 designed for 1200 STD
H14 designed for 1200 Van
G10 designed for B120 Standard 3-speed
FUEL TANK (up to '73-2) 1 17201-G1000 TANK ASS'Y-fuel 2 17373-14801 PLATE-lock 3 17342-18000 O RING 4 25060-G1000 GAUGE-fuel tank 5 17312-14800ᴳ PACKING-drain 17312-H1000ᴳ <> 17312-14800 6 08931-44210ᴳ PLUG 17310-H1000ᴳ <> 08931-44210 7 17251-G1000 CAP ASS'Y-filler 17251-G1001 <> 17251-G1000 8 17264-18000ᴳ PACKING 9 17220-G1000 TUBE-filler, upper 10 17221-H1000 PACKING 11 17222-H1000 NECK-filler 12 08310-40812 SCREW 3 13 17229-G1000 HOSE-filler 17229-G1001 > 17229-G1000 17229-G1052 HOSE ASS'Y-filler, with clamp <> 17229-G1001 14 17228-H1400 GROMMET 15 08723-15600 CLAMP-hose 2 08723-15800 > 08723-15600 16 17325-G1000 HOSE-ventilation (ℓ=560mm) 17 24250-G1000 GROMMET 18 17326-G1000 COLLAR-ventilation hose 19 08723-12600 CLAMP-hose 2 20 17501-G1001 TUBE-fuel(up to '71-9) 17501-G1003 TUBE-fuel(from '71-10) 21 17515-H1006 HOSE-fuel, with clamp (ℓ=75mm) (Op.) 17515-H1008 HOSE-fuel, with clamp (ℓ=75 mm) (Op.) > 17515-H1006 22 17515-G1001 HOSE-fuel, with clamp (ℓ=220mm) (Op.) 08742-20020 HOSE-fuel (6.0x13.5x2,2200) 23 08723-11400 CLAMP 2 24 08110-81610 BOLT 4 25 08915-43810 WASHER-plain 4 26 08915-13810 WASHER-lock 4 27 17810-G1000 PLATE ASS'Y-fuel hose protector (R.H.) (op.)
EVAPO
From March 1973
FUEL TANK
(from '73-3)
1 17201-G1400 TANK ASS'Y-fuel
5 17312-H1000 PACKING-drain
6 08931-H1000 PLUG
7 17251-H1901 CAP ASS'Y-filler
8 17264-18000 PACKING
17251-H1902 CAP ASS'Y-filler, with packing <> 17251-H1901 + 17264-18000
9 17220-G1401 TUBE-filler, upper
11 08310-40812 SCREW 3
12 17229-G1052 HSOE ASS'Y-filler, with clamp
13 08723-15300 CLAMP-hose 2
15 17325-G1400 HOSE-vent (ℓ=540mm)
16 24250-G1000 GROMMET
17 17326-G1000 COLLAR-vent hose
18 08723-12600 CLAMP-hose 4
19 17350-G1402 TANK ASS'Y-reservoir
20 17355-G1401 BRACKET ASS'Y-reservoir tank
21 17361-G1400 TUBE-evapo
22 17524-M1500 HOSE-fuel, with clamp (ℓ=90 mm) (Op.)
23 17515-G1400 HOSE-fuel, with clamp (ℓ=880 mm) (Op.) L-all
17515-G1003 HOSE-fuel, with clamp (ℓ=800 mm) (Op.) S-all
24 06112-1200P GROMMET 5
25 17364-G1400 CONNECTOR-3way (up to '73-5) (Op.)
17364-G1401 CONNECTOR-3way (from '73-6) (Op.) > 17364-G1400
17364-G1402 CONNECTOR-3way (from '73-8) (Op.) > 17364-G1401
26 17515-H1821 HOSE-fuel, with clamp (ℓ=120 mm) (Op.)
27 17515-G1406 HOSE-fuel, with clamp (ℓ=65 mm) (Op.)
28 17515-G1002 HOSE-fuel, with clamp (ℓ=580 mm) (Op.) S-all
29 17515-G1004 HOSE-fuel, with clamp (ℓ=500 mm) (Op.) L-all
30 17367-G1400 CONNECTOR-2way (up to '73-5)
17367-G1401 CONNECTOR-2way (from '73-6) > 17367-G1400
17367-G1402 CONNECTOR-2way (from '73-8) > 17367-G1402
31 17325-G1002 HOSE-fuel (ℓ=270 mm) S-all
17325-G1003 HOSE-fuel (ℓ=270 mm) (from '73-8) S-all > 17325-G1002
32 17325-G1401 HOSE-fuel (ℓ=360 mm) L-all
17325-G1402 HOSE-fuel (ℓ=360 mm)(from '73-8) L-all > 17325-G1401
33 17515-G1401 HOSE-fuel, with clamp (ℓ=760 mm) (Op.) L-all
34 17213-G1400 ORIFICE-fuel
35 17368-G1400 COLLAR-hose 1 S-all, 2 L-all
fixing reservior tank
08360-61414 SCREW 1
08915-53610 WASHER-plain 2
08360-61814 SCREW 2
FUEL PIPING 36 17515-H1008 HOSE-fuel, with clamp (ℓ=75 mm) (Op.) 37 17501-G1400 TUBE-fuel 38 17515-G1001 HOSE-fuel, with clamp (ℓ=220 mm) (Op.) 39 08110-81625 BOLT-wiht lock & plain washer 4 40 17810-G1000 PLATE ASS'Y-fuel hose protector (R.H.) 41 08510-61612 SCREW 5 42 08915-43610 WASHER-plain 5 (注) *印部品についてな下記の部品にてサービス。。。 08742-22020 HOSE-fuel (6.0 x 13.5 x 2.200) 43 08723-11400 CLAMP 14
Late
From October 1975
(N-7907) B 08510-61623 08518-51612 SCREW (7908-)
17201 TANK ASSY-FUEL
17201-G1401 7510-7803 <2,2> 17201-G1402
17201-G1402 7804-7907 <2,2> 17201-G1403
17201-G1403 7908-8111 <2,0> 17201-G1405
17201-G1405 8111-8910
17202-95W00 8910-
08110-81625 BOLT
17201A PLUG-DRAIN
17310-H1000 7510-7803 <0,0> 01125-00025
01125-00025 7804-7907 <0,2> 01125-00062
01125-00062 7908-
17201B PACKING-DRAIN PLUG
17312-H1000 -7804
17312-S0160 7804-
17220F GROMMET-FILLER TUBE
17228-H1400 GROMMET
17222 NECK ASSY-FILLER
17220-G1402
08310-40812 SCREW
17223 HOSE-FILLER
17229-G1002
08723-15800 CLAMP
17251 CAP ASSY-FILLER
17251-H1902 -8503
17251-U7402 8504-
17271 COVER
17810-G1000 -7907
17811-G1000 7908-
08510-61623 SCREW
08510-61623 SCREW -7907
17321 HOSE-BREATHER
17325-G1003 -8910 SB
17325-G1402 -8910 LB
17324-G1000 8910- SB
17324-G1400 8910- LB
08723-12600 CLAMP
17322 HOSE-BREATHER A(L=120)
A8742-20020 -8910 L=120
17515-H1821 8910-
17323 CONNECTOR-HOSE,FILLER
17367-G1402
17325 HOSE-VENTILATION
17325-G1400
08723-12600 CLAMP
17325N HOSE-VENTILATION
17328-G1000 7608- SB L=800
17328-G1400 7608- LB
08723-11400 CLAMP -7607
08723-11100 CLAMP 7608-
17326A PROTECTOR
17326-G1000
17326B PROTECTOR
17368-G1400
17326C PROTECTOR
17327-G1000 -8910 SB
17327-G1400 -8910 LB
08723-12600 CLAMP
08723-11400 CLAMP
17515-G1401 8910-
17333 HOSE-EMISSION CONTROL A(L=65)
A8742-20020 -8910 L=65
17515-G1406 8910-
08723-11400 CLAMP
17333M TUBE-BREATHER
17213-G1400
17334 HOSE-BREATHER
A8742-20020 -8910 A(L=580)
17515-G1002 8910- SB
17515-G1404 8910- LB
08723-11400 CLAMP
17342 SEAL-0 RING, FUEL GAUGE
17342-18000 -8910
17342-18000 8910-
17343 PLATE-LOCK,FUEL GAUGE
17343-14801 -8503
17343-14800 8504-
17350 TANK ASSY-RESERVE
17350-G1403
08360-61428 SCREW
08723-11400 CLAMP
17350A SCREW
01436-00111 2 7904-8503
08915-53610 WASHER -7903
08915-5362A WASHER 8504-
08360-61814 SCREW -7903
08360-6182B SCREW -8504-
17351 CONNECTOR-3 WAY
17364-G1402
17361 GROMMET
24250-89949
17362 GROMMET
06112-1200P B -8910 4
01651-00261 A
06112-1200P B 8910- 4
17501X HOSE-FUEL
A8742-20020 -8910 L=760 08740-76021
17526-95W00 8910-
17501Z HOSE-FUEL
* 08740-20021 8910- L=200 S/#A8742-20020
08723-1142A CLAMP
(17508) C17-02
17510X HOSE-RETURN
* 08740-25021 8910- L-250 S/#A8742-20020
08723-11400 CLAMP
25060 GAUGE ASSY-TANK UNIT
25060-G1000 -8111
25060-G1010 8112-
1997 B120 Parts Catalog C-415
