<-- Back to: Lighting System
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights * 23 watt Type 1073ᴳ * North America can also use 27 watt Type 1156ᴳ e.g. Wagner 1156 * Japan * 21 watt (other countries)
2. Exterior dual element, two bottom contacts
Dual-filament bulb * Front park & T/S -- See Front Combination Lamp * Rear Tail & Stop -- See Tail Lights
23/8 watt Type 1034ᴳ * Japan * North America (can also use 27/8W Type 1157) 12/5 watt * other countries
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
26945-H4600 (not sure if this lamp only, or whole unit) * Type 3175ᴳ e.g. Wagner 12100
6. Dome Lamp
10 watt (room lamp) 26736-89902ᴳ * Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w * Type SV8 SV8 5168ᴳ 10 watt * SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the larger unit (Type 3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
7. Instrument Panel Lamp
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
* Cluster Gauge illumination bulbs, warning bulbs * SQUARE METER ONLY: + two dash T/S bulbs
7. WEDGE HOLDER & BULB
26261-89902 1.7W bulb (ROUND GAUGE B110)
26711-89902 2.7W bulb (ROUND GAUGE B120)
26261-89900 3.4W bulb (SQUARE GAUGE)
Twist-lock holder (7 used in round dash). These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base.
Nissan 26260-89900ᴳ Wedge Socket $3.28 USD each [twist-in type] * Type V-2 Instrument Panel socketᴳ T10 cluster plug lamp for 1/2" or 13m hole * 7 or 8 for bar meter dash * 7 for B110 round gauge dash * 8 for B120 round gauge dash
USA * #26261-89902 1.7 watt bulb (ROUND GAUGE) 2.7 watt Type 161 is often specified by aftermarket JPN B110 * #26261-89900 BULB-12V, 3.4W SQUARE METER 7 * #26261-89902 BULB-12V, 1.7W ROUND METER 7 JPN B120 SQUARE METER * #26261-89900 -7803 12V-3.4W 8 ROUND METER * #26261-89902 BULB 12V-2.7W 6 * #26711-89900 BULB 12V-1.7W 2 * #26261-01G00 BULB 12V-1.4W 8910- F/EXH TEMP * #26711-89900 BULB 12V-1.7W 8910- F/BRAKE WARNING
T10 glass with T5/W5W base * Type 194 1.0 watt * Type 161ᴳ 2.7 watt Type 161 specs * Type 158ᴳ 3.4 watt * Type 159 6 volt
CAUTION: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
Bar Cluster Gauge uses 7 or 8 lamps including the T/S bulbs
8. Exterior Lamp
Side-marker lamp 6 watt (flashing, non-North America) 8 watt (North America, non-flashing) * Wagner 97 * Sylvania 97 (9.32 watt nominal)
License Lamp 7.5 watt Coupe, Van 26715-89901 Ichikho 10 watt Sedan, except North America 7.5 watt Sedan USA * B29.012.625ᴳ (7.5w) or [Toshiba A12V8W 6 7]
Reverse Light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
BULBS FOR DASH T/S INDICATORS * #26261-89900 BULB 3.4 watt (SQUARE GAUGE) * #26711-89900 BULB 1.7 watt (ROUND GAUGE) can use 1.9 watt Type 1445ᴳ e.g.Wagner 1445 1.9W G3-1/2 (7/16" globe) BA9S, 22.7 mm long 1445 specs
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Headlight unit 12V-50/40W Directional 12V-21/5W Parking 12V-21/5W Side Flasher 12V-6W License Plate Sedan 12V-10W Wagon, Van 12V-7.5W Rear Combo Tail 12V-21/5W Stop (brake) 12V-21/5W Turn Signal 12V-21W Back-up 12V-21W Meter (bar type) illumination 12V-3.4W IGN warning 12V-3.4W T/S 12V-3.4W BEAM 12V-3.4W OIL 12V-3.4W Clock 12V-3.4W Room light 12V-10W
Rectangle Meter specs (1974 B120)
Head Lamp 26705-04101 Sealed beam unit (Koito) 26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early 26717-89920 BULB (12V-23/7W) 26261-89900 BULB (12V-3W)
Front Combination Lamp - Late 26717-89900 BULB (12V-23) [P21W] 26261-89920 BULB (12V-8/3.4W) [P21/5W???] * or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
| Spec. | SAE No. | Nissan/Ichiko | |
| Headlight unit | 50/40W | 6012ᴳ | 26705-04201 |
| Front Combo Light Direction and Parking | 23/8W | 1034* | 26717-89920 |
| Side marker | 8W | 67ᴳ | 26715-89902 |
| License plate | 7.5W | 89ᴳ | 26715-89901 |
| Rear Combo Light Tail Stop (brake) Turn signal Back-up light | 23/8W 23/8W 23W 23W | 1034* 1034* 1073^ 1073 | 26717-89920 26717-89900 |
| Wiper Knob (1973) | 3.4W | 158ᴳ | ? |
| Heater control (1973) | 3.4W | 57ᴳ | ? |
| Meter (round gauge) illumination | 1.7W | 161ᴳ | 26711-89900ᴳ |
| IGN warning | 1.7W | 161 | 26711-89900 |
| Turn Signal | 26713-89900ᴳ | ||
| BEAM | 1.7W | 161 | 26711-89900 |
| OIL warning | 1.7W | 161 | 26711-89900 |
| BRAKE warning | 1.7W | 161 | 26711-89900 |
| Room light | 10W | n/a | 26736-89902ᴳ |
^ 1156ᴳ can replace type 1073ᴳ
Portugal
Opticas 12V-50/40W 12V-21/5W Luz de mudança de direcção o de presença 12V-6W Luzes laterais de mudança de direcção 12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras 12V-5W luz de presença 12V-21W luz de stop (travões) 12V-21W luz de mudança de direcção 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos 12V-3W Luz avisadora da ignicão 12V-3W Luz indicadora dos máximos 12V-3W Luz avisadora da pressao do óleo 12V-10W Luz interior 12V-3W Luz de iluminação do relogió
Nissan Part Numbers
26261-01G00
Nissan 26261-01G00ᴳ BULB 8910- 12V-1.4W F/EXH TEMP Nissan 26260-95W00ᴳ SOCKET ASSY-BULB 8910- F/EXH TEMP
26261-89900
Nissan 26261-89900ᴳ BULB 3.4 watt [F/SQUARE METER]
Nissan-Toshiba 158pᴳ 3.4W
Type 158 specs 14V-3.36W Miniature Wedge T3-1/4 Glass (25.8mm MOL 10mm diameter) W2.1x9.5d Base
#9. Instrument Panel Turn Signal #7. Instrument Panel Lamp Meter Part Numbers SQUARE GAUGE DASH * JPN B110 bar meter * JPN B120 -7803 TURN SIGNAL (2) * JPN B120 8910- BRAKE WARNING (1) * Many 2000s era Nissan Cargo Lamp, Marker Lamp, Tail Lamp, etc
26261-89902
Nissan 26261-89902ᴳ BULB 12V-2.7W
#7. Instrument Panel Lamp Meter Part Numbers B120 ROUND GAUGE DASH
26705-04101
26705-04101ᴳ Sealed beam unit (Koito)
Headlight Part Numbers * JPN B120 -8910 (except Okinawa -8503)
26705-08700
26705-08700ᴳ Sealed beam unit (Koito)
26705-04201
26705-04201ᴳ UNIT-SEALED BEAM (ICHIKHO) <> #26705-89925 (ICHIKHO) * 12V-50/40W
Headlight Part Numbers * USA B110
26705-89905
26705-89905ᴳ UNIT-SEALED BEAM (KOITO) * 12V-50/40W
26705-89920
26705-89920ᴳ HEAD LAMP UNIT IKI
26705-89925
26705-89925ᴳ UNIT-SEALED BEAM (ICHIKHO) <> #26705-04201 (ICHIKHO) * 12V-50/40W
Headlight Part Numbers * USA B110 * JPN HEAD LAMP UNIT IKI F/OKINAWA -8503
26705-C9920
26705-C9920ᴳ HEAD LAMP UNIT [square type]
Headlight Part Numbers * JPN B120 8910-
26711-89900
Nissan 26711-89900ᴳ BULB 12V-1.7W * G10 glass with BA9S base (10MM Globe with 9mm Bayonet mount)![]()
#9. Instrument Panel Turn Signal qty 2 Meter Part Numbers round guage * USA B110 * JPN B110 * JPN B120 7804-
26717-89900
26717-89900ᴳ
26715-89901
26715-89901ᴳ BULB 12V-7.5W (ICHIKO) * 12V-7.5W
License Lamp Part Numbers * USA B110 Sedan, Coupe * JPN B120 Truck * JPN B110 Coupe * JPN B110 Van 1970-1971
26715-89902
26715-89902ᴳ * 12V-8W * USA B110 front & rear Side Lighting Parts Numbers
26717-89920
26717-89920ᴳ BULB 12V-23/8W (ICHIKHO) * 12V-23/8W
Front Combination Lamp Part Numbers Direction and Parking * USA B110 * JPN B110 * JPN B120 -7308
Sedan Rear Combination Lamp Part Numbers Coupe Rear Combination Lamp Part Numbers Truck Rear Combination Lamp Part Numbers Van Rear Combination Lamp Part Numbers * USA B110 * JPN B110 * JPN B120 Truck
26736-89902
26736-89902ᴳ
Room Lamp Part Numbers * USA B110 * ? JPN except Truck, Van ?
