<-- back to Doors
Door cards (door interior trim panels) — which Nissan calls "door finishers" — for Datsun 1200 were available in different styles.
Contents[hide] |
Door cardsᵂ (or an American English, door panels) are the interior door covering. Sometimes called the door lining. Not to be confused with the door sheet metal.
Coupe door panels will fit on a 2dr sedan with some very minor mods. The panel may sit a bit higher than the original panel but basically it's just a matter of enlarging the window winder hole. Oh, and it's harder to fit but it works.
Early Truck door cards are the same as 4-dr sedan.
The factory visqueenᵂ protects the door cards from moisture. The original door panels are made out of fiberboardᵂ, the doors have polyethylene sheet applied with sealer before the door cards are fitted.
The black bead of rubber sealant is similar to RTV but stickier, thicker and never gets hard. Automotive grade.
Details
Ute Mid-model (1978-1989) Brown
Ute Late-model (1989-)
Gray
Do not confuse with B210 door cards, such as this early KB210 | late B211 Sedan
Patterns
STD/DX
GL/GX
#Sedan/Van/Truck simple ribbed design, shorter than door
#Sedan 1972 facelift swoosh design
#Coupe chrome enclosure
#Coupe 1972 facelift spear design
#PB110 sedan Sunny Excellent embossed crest
#PB110 coupe Sunny Excellent GL/GX double sweep with kicking plate
Australia local content (sedans) wide ribbed with single chrome
South Africa 1970s wide-ribbed with dual chrome strips
South Africa B140 1990s
Removal & Installation
To remove the door card:
- Coupe: unscrew the door lock pull knob
- using a table knife or putty knife, slip between card and door until a clip is located. then gently pull clip out of door
clip locations (sedan/van/truck front door)
CLIPS 3/door front door sedan/wagon/ute 4/door coupe
To install:
- re-align/center the #clips on the back of this finisher panel
- insert panel into door
- Coupe: place card over top of door (centered over the lock pull), then push down
- Sedan: fit card into upper channel
- flex card into bottom channel
- preliminarily line up clips with holes (get the clips started into the caps)
- gently — with the palm of your hand — pushing panel over each clip. Push fully into the clip cap receptables
Coupe
Coupe finishers cover the entire door (sedan finishers do not cover the top of the door)
FINISHER ASS'Y-door 80900 RH 80901 LH
JAPAN & North America 80900-H1800 RH BLACK #1742 80900-H1801 RH YELLOW 黄 (DX for JAPAN)
North American 1973 flame resistant 80900-H7101 RH BEIGE,LH-20 COUPE 0772- 80900-H7102 RH BLACK,LG-13 COUPE 0173- 80900-H7100 RH BLUE COUPE 0772-
Body Side Finisher 76900-H1800 DX/GL Black 76900-H1801 DX/GL Yellow
Coupe 1973
1973 North America (Fire-resistant material) 76900-H7000 BLUE 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Coupe PB110
Datsun PB110 Sunny Excellent 1400
Coupe DX * Same as B110 above (choice of black or yellow) PB110 Colors#Interior![]()
GL/GX double sweep with kicking plate 80900-H2600 RH BLACK PB110 80900-H2601 RH BROWN PB110 GX 80900-H2602 RH BLUE PB110 GL
Coupe 1972
80900-H4000 Black 89000-H4001 Yellow
Facelift finishers have a swoosh design
s
Body Side Finisher 76900-H4000 Black 76900-H4001 DX Yellow
Sedan
4-door 80900-H1000 STD black 5-rib style 80900-H1100 DX/GL/GX black chrome insert 80900-H1101 DX yellow
DX/GL/GX with chrome accent insert
Rear Door Finisher 82900-H1000 STD Black 82900-H1100 DX/GL/GX Black 82900-H1101 DX Yellow
Sedan 2-door
2-door 80900-H1200 STD black 80900-H1300 DX/GL black Japan 80900-H1301 DX yellow (USA: 1270-) 80900-H1900 DX black North America
Body Side Finisher 76900-H1200 STD Black #1742 76900-H1300 DX/GL Black 76900-H1301 DX/GL Yellow
Sedan 2-door 1973
North American 1973 flame resistant 80900-H7000 BLUE,LB-211 0772- 80900-H7001 BEIGE,LH-20 0772- 80900-H7002 BLACK,LG-13 0173-
80900-H1900 2-door North America
1973 North America 76900-H7000 BLUE,LB-211 0772- 76900-H7001 BEIGE,LH-20 0772- 76900-H7002 BLACK,LG-13 0173-
Body Side Finisher 76901-H1300 DX/GL, Black
Rear Side card has a distinctive upward sweep
Sedan PB110
Kicking Plate on bottom of door 80911-H2900 Sedan PB110 Sedan DX * Same as B110 DX above (choice of black or yellow)
GL/GX 80900-H2900 RH BLACK PB110 80900-H2901 RH BROWN PB110 GX 80900-H2902 RH BLUE PB110 GL
Sedan 1972
4-door 80900-H3100 1972 STD black 80900-H3200 1972 DX black 80900-H3201 1972 DX yellow
2-door 80900-H3600 1972 STD black 80900-H3700 1972 DX black 80900-H3701 1972 DX yellow
Truck
Sunny Truck door finishers came in two patterns:
- 1971 sedan STD simple 5-rib pattern
- 1972-1994 sedan facelift spear pattern
FINISHER ASS'Y-door 80900-H1000 -7111 BLACK same as early sedan 80900-H3100 7112-7803 BLACK same as 1972 sedan 80900-G1060 7804-7907 DARK BROWN 80900-G1660 7908-8104 BROWN 80900-G1901 8105-8910 BROWN 80900-95W00 9810- GRAY
Dec 1971 - Apr 1978: Facelift Black
7804-7907 DARK BROWN spear pattern
7908-8104 BROWN sweep pattern
8105-8109 BROWN
8110-8910 BROWN with pocket (driver's side only)
Door Pocket
80801 POCKET-DOOR 80912-G1900 BROWN RH 8110-8910 80912-95W00 GRAY RH 8910-
ドア ポケット
Van
Wagon used the same front door cards as sedan. In the used the Sedan Standard card, except for Deluxe van which used a specific finisher panel.
DOOR FINISHER H10 Van-Standard, Van-P H11 Van Deluxe H15 Van Deluxe Rear Door
Additionally, interior finishing panels were used in the rear cargo area.
H14 back door (tailgate) H14 trunk side trim
Tailgate finisher 90903-H1400
trunk side trim 84911-H1400 RH
trunk side trim 84912-H1400 LH goes here
Van 1972
For the 1972 JDM Facelift, the door cards were updated.
H31 Front & Rear Door Standard, P H32 Front Door Deluxe black H36 2-door Van (new model for 1972) H44 Front Door Deluxe green H4400 Rear Door Deluxe black H4401 Rear Door Deluxe green H45 Front Body Side Trim 2-door Van
Rear trunk side & tailgate finishers remained the same as 1971.
Clips
Clips to hold the finishers in place and tubules to fit into the door sheet metal.
80919-89900 CLIP-door finisher 80929-32200 CAP-door finisher clip
These B310 plastic units can be used when the fibreboard is too torn to work with the metal clips
Custom
Roll-cage simulating interior door panel. Color matched.
Fibreglass
Bprojects carbon fibre
ドア フィニッシャー
