Rocker cover
Revision as of 07:15, 11 November 2023; view current revision
Category: Engine Mechanical
The Rocker Cover covers the top of the Cylinder Head including the Rocker arms and valvesprings. The rocker cover is painted Datsun Blue, which is a darker blue than the air cleaner. The rocker cover is also known as a valve cover or tappet cover.
6547.jpgblue
See also: Oil cap
[hide]
Installation
They are prone to leaking like most stamped steel covers. Biggest problem is over tightening. They should be finger tight and retightened at least every oil change.
  • Hammer the flange flat before installing the gasket.
  • Remove all traces of old gasket and sealer.
  • Do not use sealer. Clean & flat will prevent leaks.
The black rubber gasket lasts forever. The cork gaskets tend to tear on removal of the cover.
Tighten all the valve cover screws finger tight. Then go around and re-tighten finger tight. After the engine warms up, finger tighten one last time. Instead of using a wrench which will overrtighten, use a Phillips screwdriver. Use thumb & finger to tighten; using the palm or fist to reef on the screwdriver will tighten too much and distort the metal flange.
Loctite Threadlocker Blue might help. I've never used it ... but the screws do get loose.
B10 (A10 engine): Black 'Datsun' label on top
19102.jpgAlbum 19102 27232.jpgAlbum 27232
B110: Embossed 'Datsun', two threaded bosses for fuel rail, offset clip for throttle cable
B110 GX, center clip for throttle cable:
8355.jpgAlbum 8355
B210 early 'Datsun' H5001: no threaded bosses, two clips for vacuum advance hose
25533.jpgAlbum 25533
LATE B210
H7201 A14S.Van
H7800 A12S.Van
26217.jpgAlbum 26217
H8200 A12S.Sedan+Coupe
H8400 A14T
??? 'Datsun' - no bosses or clips
H84 A14T Nissan right-angle vent
26386.jpgAlbum 26386
Nissan 1
Nissan 2
B210 A14: No threaded bosses on side (fuel rail does not bolt to rocker cover)
B310: Embossed 'Nissan'
13264-H7800 B120 7510-7907
13264-W8501 B120 7908-8910
13264-95W00 B120 8910-
Gold Top for A14E and A15E EGI engines - Factory EFI
23979.jpgAlbum 23979
Nissan cover, front vent
EFI Cover
Gold Top EGI fuel injection tappet cover
* rear vent (early A14E)
* front vent (late A14E + A15E)
EFI front vent
A15E/Late A14E cover with front vent 13264-H9201 7910-
Late A14 with front vent (B310 round headlight models)
Image032-11.jpg 25773.jpgAlbum 25773 13822_5555d83295022.jpgPost 467924 25774.jpgAlbum 25774 25775.jpgAlbum 25775
EFI rear vent
Early A14E cover with rear vent 13264-H9200 -7909
22796.jpgAlbum 22796
GX Cover
For the twin-carb 1200GX Engine#Rocker Cover:
  • fuel-rail mounting brackets are in different place
  • choke cable bracket is in different place
A12T Cover
B210 A12T twin carb
  • Red paint (B210) instead of blue (B110)
  • No rail brackets (B210)
Breather
Main: PCV
Gasket
The same valve cover gasket (packing) fits all A10/A12/A13/A14/A15 engines. Nissan made several specification of material but the shape and dimensions are the same. The black rubber type is generally reusable, while the cork type often breaks.
B110
13270-18001 PACKING-ROCKER COVER - NLA
GASKET-ROCKER COVER
* 13270-18000/13270-18001 B10, B110, B120, B210 to '74-5
* 13270-H1000 B210 from '74-6, B310 all, B120 - 7803 センタク シヨウ アイチキカイ
* 13270-H1010 B310 [alternate supplier], B120 7804- センタク シヨウ イシノガスケツト
AFTERMARKET
* BECK/ARNLEY Part # 0360669
* FEL-PRO Part # VS26049R (rubber type, black) RockAuto.com $1
* FEL-PRO Part # VS26049C (cork type)
* MAHLE VS30018 (cork-rubber mix)
* MCCORD VS138
* APEX AVC522
Cork - FelPro VS26049C
Nissan Group gasket
174_654f25a144e40.jpgPost 498029
Customizing
Polishing
6687.jpgAlbum 6687
Chrome Plated
1868.jpgAlbum 1868 3172.jpgAlbum 3172
Painting
crinkle finish
2602_61a073ee1c7bc.jpgPost 496255
1961.jpgAlbum 1961 2537.jpgAlbum 2537 3242.jpgAlbum 3242 3275.jpgAlbum 3275
Candy Apple green
13383.jpgAlbum 13383
flat paint (non-shiny)
5252.jpgAlbum 5252
Color matched
25953.jpgAlbum 25953 881.jpgAlbum 881
Carbon Fiber
Autostyle
http://auto-style.jp
25621.jpgAlbum 25621
Zero Queue Racing/09 Racing dry carbon cylinder head cover.
Dry carbon head cover for A-type engine
Blow-by mounting base is M14x1.5
Etc. your favorite Earl I can be installed
L-series oil cap for engine is available
Anyway light dry carbon steel
Autoclave molding
CF Skin
Standard rocker cover with Carbon Fiber pattern applied (Water Transfer Printing).
hydroprint@xtra.co.nz or call Shane on 021689599
25619.jpgAlbum 25619 25620.jpgAlbum 25620
Alloy Covers
Aluminum light-alloy covers were never shipped on a Datsun 1200, but newer engine covers and aftermarket covers are available.
See also: Oil cap
See also: #Gasket
B110
13264-H1000 ASSY-COVER VALVE ROCKER - NLA
13264-H7000 ASSY-COVER,VALVE ROCKER 0772- NLA
08915-13610 WASHER-LOCK FIXING ROCKER COVER 6 $1.06
08360-61612 SCREW-MACHINE FIXING ROCKER COVER 6 > 08310-61612 $0.65
A-series COVER ASS'Y-valve rocker
* 13264-18001 B10
* 13264-18002 B10 from engine A10-173620
* 13264-18003 B10
* 13264-H0100 B10
* 13264-H1000 'Datsun' B110 exc. GX
* 13264-H2300 B110 GX
* 13264-H7800 'Datsun' B120 7510-7907
* 13264-W8501 'Nissan' B120 7908-8910
* 13264-95W00 'Nissan' B120 8910-
* 13264-H5001 'Datsun' B210 A12S
* 13264-H5702 B210 A12T
* 13264-H7200 B210 A14S Van
* 13264-H7800 B210 Van
* 13264-H8200 B210 A12S Sedan, Coupe
* 13264-H8400 B210 A14T
* 13264-H7800 B310 Van to 7909
* 13264-W8501 B310 Van from 7910
* 13264-H8500 B310 A12S, A14S Sedan, Coupe
* 13264-H9200 B310 A14E to 7909
* 13264-H9201 B310 A14E 7910-8010, A15E 8011-
* 13264-G3400 B310 A13S, A15S 8011-
B10 Japan 1966-1970
ASS'Y-COVER-valve rocker
13264-18001 <> 13264-18002          [angle-vented cover?]
13264-18002 from engine A10-173620
13264-18003 < 13264-H0100
13264-H0100                         [straight-up vented cover?]
180 air cleaner v,s,k
154 air cleaner truck
180 hose to rocker cover ? how can this connect to two different-shaped vents
BLOCK 18000, 18001, 257 Coupe
A10 engine
17129.jpgAlbum 17129 19102.jpgAlbum 19102
B210 JAPAN 1976-1977
COVER ASSY-VALVE ROCKER
13264-H7201 A14S except V
13264-H7800 V
13264-H8200 A12S.S,K
13264-H8400 A14T
B310 USA
13264-H7201 B310 A12A USA -0780
13264-H9500 B310 A12A USA 0880-
13264-H7201 A14 FED (KFU), A14 CAN
13264-H7260 A14,A15 FED (EXC KFU) A14,A15 CAL
13264-H9500 A14,A15 USA 0880- 13264-H7260
ロッカー カバー タペット カバー ヘッド カバー
