License Lamp
Revision as of 08:49, 22 November 2025; view current revision
<-- back to Lighting_System
Each body style (sedan, coupe, wagon) uses a different kind of number plate lamp. Truck uses the coupe type.
The type of lamp corresponds with the bumper type.
#Coupe lamps are above plate, under the bumper
#Truck/Ute lamps are above plate
#Sedan in bumper top edge
#Sedan side-lit 1973 USA
#Wagon/Van above number plate in tailgate
Sedan
Sedan light fits into the top of the bumper, and illuminates the number plate from below.
16172.jpgAlbum 16172
26510-H1000 LAMP ASS'Y-licence
* 10W bulb
* 26511-H1000 LENS
* 26512-H1000 COVER
* 08310-41420 SCREW (2)
* 26513-H1000 PACKING
H10 Assembly 6510-H1000
20725.jpgAlbum 20725 29752.jpgAlbum 29752 29754.jpgAlbum 29754 29753.jpgAlbum 29753
Cover frame is marked "IKI 6001 JAPAN"
20726.jpgAlbum 20726
26511-H1000 LENS is clear. Marked 'SAE L70 IKI 6001 JAPAN'
29751.jpgAlbum 29751 29750.jpgAlbum 29750
L70 = License Plate Lamp, 1970 specification SAE J759
27140.jpgAlbum 27140
Green wire/White stripe with the typical B110 bullet connector. See Lamp Wiring
27141.jpgAlbum 27141
South Africa (510-style bumper)
17111.jpgAlbum 17111
The lamp assembly fits into the top edge of the rear bumper
11174.jpgAlbum 11174 29755.jpgAlbum 29755 12928.jpgAlbum 12928
Sedan Update
For USA market, the rear number plate light changed in 1973 to meet higher government standards of illuminating the plate. Coupe license lamps already were bright enough, so only the sedan was updated.
Early license plate lamp (on top of bumper):
2120.jpgAlbum 2120
Late license plate lamp (dual lamps on either side of plate):
1427.jpgAlbum 1427
Coupe
Lamp type #H18 is used coupe & ute
20727.jpg#Go To
Two are used on each coupe, hidden under the bumper, one above each license plate bolt. You can see the holes in this photo:
14005.jpgAlbum 14005 5287.jpgAlbum 5287
Coupe lamps are not normally visible until turned on, because they are up under the bumper.
Pickup
Datsun 1200 ute uses same license lamp as the #Coupe.
Type #H18 lamp
20724.jpg#Go To
Placement: Like the coupe they are hidden from normal view, except instead of the bumper, they are under the Lower Rear Panel.
20728.jpgAlbum 20728 23214.jpgAlbum 23214 10819.jpgAlbum 10819
H18
Type H18 lamps are used by #Coupe and #Truck
20724.jpgAlbum 20724 20727.jpgAlbum 20727
26510-H1800
Marked "SAE L 69", "IKI 6003" and "JAPAN" and "E4 455"
26510-H1800 LAMP ASSY-LICENSE (市光 ICHIKO) 2
26715-89901 7.5W bulb
26511-H1800 LENS-LICENSE LAMP
26513-H1801 PACKING-LENS
Lens needs cleaning?
20722.jpgAlbum 20722 20723.jpgAlbum 20723
27144.jpgAlbum 27144
174_5d59abf0d8ed7.jpgPost 492302 174_5d59abf8e38a6.jpgPost 492302 174_5d59ac015110a.jpgPost 492302 174_5d59ac0bddafa.jpgPost 492302 174_5d59ac131785e.jpgPost 492302 174_5d59ac1ecb58e.jpgPost 492302 174_5d59ac3157083.jpgPost 492302 174_5d59ac38d575f.jpgPost 492302 174_5d59ac41b70db.jpgPost 492302 174_5d59ac72ec2d1.jpgPost 492302
Wagon
VB110 uses a single large chrome license lamp just above the number plate and doubles as the tailgate lift handle
174_5d8159050dcc3.jpgPost 492625 174_5d8158f8e4031.jpgPost 492625
26510-H1400 LAMP ASS'Y-license
* 26517-H1400 PACKING
26511-H1400 LENS (2)
* 26513-H1400 PACKING (2)
* 7.5W bulb (2)
116-01xb.jpg 31307.jpgAlbum 31307
ライセンス 灯 ナンバー
ライセンス ランプ
638.jpgAlbum 638 4489_49e6ef4cca9d9.jpgPost 251089
It has twin lamps, one on either side of the gate hand-hold. Each lamp has a single wire with bullet connector
31308.jpgAlbum 31308 31309.jpgAlbum 31309 31310.jpgAlbum 31310
