320
Revision as of 20:37, 13 April 2025; view current revision
Category: Nissan Vehicles
Introduced August 1961, the Datsun 320 light truck was commonly called the "1200" due to having 1200 badges. This denoted the size of the E1 engine, and not the model name (320) or market name (which was "Datsun" in the Japan domestic market). The 320 truck is closely related to the Bluebird 310 sedan and is unrelated to the Sunny family of subcompact vehicles like the B110 Datsun 1200.
13597.jpgAlbum 13597
[hide]
The 320 Datsun 1200 was sold in Japan as the Datsun Truck, Nissan's eighth Datsun light truck model series. It was followed on by the 520 series in 1965 (marketed in North America as a 1966 model). The first Datsun truck to make 60 HP was the 1961 model 221, but "Datsun 1200" badges were not added until the Datsun 320.
The size is very similar to the B110. Length and width are nearly identical, but it is much taller due to its 1950's design.
Top speed: 105 kph (non-USA models)
Weight: 955 kg
Wheelbase: 2470 mm
Bed: 6' x 4'8"
Load Rating:
 -U: 500 lbs (1/4 ton)
 -N: 1000 lbs (1/2 ton)
 -P: 2000 lbs (1 ton)
For 1964 and 1965 there was a ute (coupe utility) version, the #N320/NL320.
Datsun 320 Pickup with custom flat-tray
1181.jpgAlbum 1181
1964 320 on display at Kona Nissan
IMG_6726.thumb.JPG.1ba6f2821e4e6c86e5cd397f9360a55c.JPG IMG_6728.thumb.JPG.73db67584ab0ea9af1e8409abaf1d626.JPG IMG_6727.thumb.JPG.a18d4d4e2758aaf75f3ad91f83982904.JPG IMG_6729.thumb.JPG.8f24e8ee63cf9aac69b9e56d986c04cb.JPG
The first Datsun 1200
Serial Numbers
Numbers are on:
  • the data plate to top center of the firewall
  • stamped on the frame near the left side front tire
1961/1962/1963 are (L-)320-year digit-serial
e.g. L-320-2-01505B
1964/1965 are year-(L) 320-serial
e.g. 4-L 320-60214
320 export models for USA had:
  • the year stamped on the chassis plate, unlike later Datsuns which had a special build plate on the door jamb.
  • The chassis plate may have a year stamp that differs from the Car Number year digit
  • NL serial numbers appear to start with Car Number "60xxx"
USA 320
Engine
The E1 "1200" engine displaced 1.2 liter (1189 cc). The E1 was produced from 1958 through the late 1960s. Those installed in 320 pickups were rated at 60HP. This was an older engine design modified from the 1950s Austin engine.
Main: E1
Engine stamp 'E1'
15625_4f2e310396432.pngPost 397108 15625_4f2e30f9b89ca.pngPost 397108
Engine Swaps
#J15 Swap
The Datsun J13 will bolt right up to the stock 320 transmission, the only piece you will most likely have to swap is the bellhousing adapter plate. This is the plate that is between the flywheel and the block. The E1 and the J13 have the same block bolt pattern, so the plate from the E1 will go right up to the J13 and then you can bolt up the J13 to the 320 4 speed. You may have to use the E1 flywheel and starter.
Year Comparison
1962 320 - round indicators outside the grille
18348.jpgAlbum 18348
1963 320 - D mark in center of grille
1964 - wide grille, rectanguloid parking lamps
1965 - wide grille, round indicators in the grille
Grille Comparo
1955 120 brochure
1956 122
1957 123 - round parking lamps
1958 124 - no parking lamps on front
1958 220 - small parking lamps on front, fender-top blinkers
1959 125 - round parking lamps
1959 221 early - truck grille (nine slot)
1959 U221 Double Cab Pickup
400px-Datsun_Pickup_220_001.JPGWIKI click for photo
1959 221 late - sedan grille
1960 126
1960 222 - no change to grille (front of bed side comes down below tires)
1961 223
1962 320
600x450-kurumaerabi_store_113191_0_1_1306139291464.jpg 18348.jpgAlbum 18348
320 Truck
新鋭 55 馬力 (State-of-the-art 55 hp) "The Machine" Datsun Truck
11956.jpgAlbum 11956 15093.jpgAlbum 15093 15617.jpgAlbum 15617
737_4def372332839.jpgPost 371182
10360_5015368452fa1.jpgPost 414145 10360_501536d59b4ab.jpgPost 414145 10360_501536ef36590.jpgPost 414145 10360_50153a196acc6.jpgPost 414145 10360_501cb3e186c0b.jpgPost 414145 10360_501cb3ee3c23f.jpgPost 414145 10360_501cb3f91c49e.jpgPost 414145 10360_501cb4054d4cb.jpgPost 414145 10360_501cb40f4aa67.jpgPost 414145
320 Pickup
Datsun U320 double-seat Pickup (ットサン ダブル シート ピックアップ) was officially marketed as the "Pickup" in the Japan domestic market, and sometimes called the "double cab".
U3205.jpgRatsun
Datsun JDM brochure
平日は商業車、休日は乗用車 Commercial vehicles on weekdays, passenger cars on holidays
featuring the #N320, the U320 and the #V320
Errol's 1965 U320
2667.jpgAlbum 2667 2668.jpgAlbum 2668 2669.jpgAlbum 2669 2670.jpgAlbum 2670
Ratsun: wayneo's U320
DSC00333.JPG.cccf3b98b4775fa8319e96f5fde609c7.JPG DSC00332.JPG.2c3d44e86ac57f161f669d02e1b51ca8.JPG DSC00334.JPG.fc0bc5eed93f8fa38827108a79e13a09.JPG DSC00335.JPG.e8cc93c9845ea61fb65f7710d48efa12.JPG
320 Van
V320 is called the "Van" in Japan, but "Wagon" in some countries.
13042_4b9a3af59a6d0.jpgPost 307950
320 Sports
Coupe Utility versions of the 320 truck made 1963-1965. It was marketed as "Sports Pickup" in USA and "Pick-up" in Australia.
 N320 (Right-hand drive)
NL320 (Left-hand drive)
Mouse_at_Work_26_March_2017.jpg 9018.jpgAlbum 9018 8210.jpgAlbum 8210
The N320 has a one-piece body with integral tray/bed, but sites atop a full-frame chassis. So, the N(L)320 is not a unibody like the B120 Datsun 1200 Pickup.
Approximately 1000 were sold 1963-1965 by Nissan Motor Company in U.S.A., who advertised it as the Datsun "Sports Pickup"
https://datsun320.com
Discussion: POST Datsun 1200 N320 Ute
N320_1.jpg N320_2.jpg N320_3.jpg N320_4.jpg N320_5.jpg N320_6.jpg N320_7.jpg N320_8.jpg
Brochures
LIGHT VAN (V320) / SINGLE-SEAT pickup (N320) / double-seat PICKUP (U320)
zz1.thumb.jpg.42275ae5c3dc96f3b8267f08bedf90c7.jpgRatsun
Dimensions
As expected, the double-cab Pickup (#U320)) is the longest, 75mm (3 inches) longer than the regular 320 Truck
Dimensions and weight,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Item\ModeltruckLight Vanpickup
Model320V320U320
Overall length (mm)4,1254,1454,275
Overall width (mm)1,5151,4971,497
Overall height (mm)1,6101,5451,545
Ground clearance (mm)200184183
Luggage compartment length (mm)1,8501,555
940
880
Luggage compartment width (mm)1,4271,1801,245
Luggage compartment height (mm)4069051,545
Vehicle weight (kg)9551,0201,000
Maximum loading capacity (n./kg)2/1,0002/500
5/300
5/400
Gross vehicle weight (kg)2,0651,630
1,595
1,675
Sales
North America
320 Pickup - ~8232 sold 1961-1965
320 Sport Truck - ~1000 sold 1963-1965
Pendles
15634.jpgAlbum 15634 15628.jpgAlbum 15628
Bench Seat is narrower than Datsun 1200 ute
15627.jpgAlbum 15627
15626.jpgAlbum 15626
flat-tray conversion 320
15635.jpgAlbum 15635 15629.jpgAlbum 15629 15630.jpgAlbum 15630 15617.jpgAlbum 15617
J15 1500 engine swapped for the old E1 "1200" engine
15633.jpgAlbum 15633 15632.jpgAlbum 15632 15631.jpgAlbum 15631
