Piston
Revision as of 01:25, 31 August 2025; view current revision
Category: Engine Mechanical
The Datsun 1200 A12 engine came with slightly dished pistons for approximately 9.0:1 compression ratio. Standard bore size for the A10, A12 and early A13 block is 73mm (2.874 in). Pistons are cast for quietness, and lightness. Nissan Competition does not recommend forged pistons for street use as they are not as close tolerance as the cast pistons (forged pistons are noiser due to larger tolerances required). The A12GX engine used the same dished pistons, except for the "high gas" version which used flattop pistons from the Datsun 1000 Coupe motor.
Pistons are connected to the crankshaft via the Connecting Rods.
b77306283bokekoni1964-img600x449-1.jpg b77306283bokekoni1964-img600x449-11.jpg
Datsun 1200 (A12) pistons are modern design of the lightweight slipper type -- unlike the earlier 1200 Bluebird/pickup 60hp engine which used old-design heavy alloy pistons.
light piston from A12
11574.jpgAlbum 11574
heavy piston from older Datsun
Piston Pin Diameter x Length  to fit Connecting Rods
A10/A12: 17.45 mm x 65.5 mm
A14/A15/A12A: 19.00 mm x 63 mm
Pin Height (Compression Height)
A10/A12/A13/A14: 32.5 mm
A15: 30 mm
Piston length
A12/A13: 67.40 mm
A14: 67.5 mm
A15: 65.00 mm
CLEARANCE, Piston to cylinder wall
cast (stock pistons):
 A12:     0.0009-0.0017"
 A14/A15: 0.0010-0.0018"
forged: Use manufacturer's suggestion
 typical: 0.0050-0.0070"
CLEARANCE, Piston to valve
* See POST discussion
20677_57942d4967c3c.jpgPost 480071
GX Pistons
A12GX Engine came with two kinds of pistons:
  • dished for low-gas (regular octane) engine
  • flat-top for high-gas (high octane) engine
11573.jpgAlbum 11573 11574.jpgAlbum 11574 11572.jpgAlbum 11572
high-gas GX flat-tops
174_67b163d71eed7.jpgPost 498788
A10 Pistons
With KB10 flat-top pistons
30517.jpgAlbum 30517 30519.jpgAlbum 30519 30516.jpgAlbum 30516
Piston Comparisons/Potential Swaps
Also see:
* Justy Piston Swap for 1607cc A15 engine
* Bored And Stroked for performance oversize pistons
KB10 and 1200GX Engine - flattop
1mm oversize
A12 STD and 1200GX low-gas
1.0mm oversize A12
A14 Cosworth pistons
305_501ffdd726af7.jpgPost 414840 305_501ffdfd3c44b.jpgPost 414840
A14 early
A14 76mm Piston
8191.jpgAlbum 8191
A14 early quench head - deep dish
A14 late model for quench head
A14 76.85mm Tomei Piston
20521.jpgAlbum 20521
A15 Piston (small dish - early A15)
A15 Pistons (late A15 H98 quench type vs round-port A15)
4712.jpgAlbum 4712
A15 late model
A14 79mm from Matsuoka
DSC_0253.jpg DSC_0252.jpg 174_5acea0031f099.jpgPost 488063 DSC_0250.jpg 174_5acea00f1f0aa.jpgPost 488063 DSC_0246.jpg DSC_0239.jpg DSC_0242.jpg DSC_0243-1.jpg DSC_0244.jpg DSC_0245.jpg DSC_0240-1.jpg DSC_0241-1.jpg
High Quality Cast Pistons
See POST Jmac's comments on strong cast pistons
Forged Pistons
The downside of forged pistons is noise and wear. But they do hold up to massive stress, so good for turbocharged engines or high-RPM racing engine. Also, super high-compression (dome-top pistons) are available in forged.
quote: Nissan Competition does not recommend forged pistons for street use.
Main Forum: POST Are forged pistons really worth it
ARIAS forged pistons a12 +040 with floating pins, teflon buttons
7484.jpgAlbum 7484 7483.jpgAlbum 7483 7485.jpgAlbum 7485
Arias forged pistons with press wrist pins and rings $175 each (2008)
8172.jpgAlbum 8172
Venolia forged flattops
16493.jpgAlbum 16493
Kameari A14+3mm (79 mm)
KAMEARI_A14-79_a.jpg KAMEARI_A14-79_b.jpg KAMEARI_A14-79_c.jpg KAMEARI_A14-79_d.jpg KAMEARI_A14-79_e.jpg
Wiseco
13014.jpgAlbum 13014
Cosworth A12 dome-top pistons (for stock 73mm bore)
305_501ea92e15d1b.jpgPost 414746
Cosworth A12+040 pistons (74mm)
305_501ea94aac121.jpgPost 414746
Suppliers
  • Datratsᴬᴿᶜᴴᴵⱽᴱ (Australia) is listing A14 oversize Tomei forged pistons
  • JE Pistons custom order
  • JP Pistons (Australia) custom order pistons
  • Malvern Racingᴬᴿᶜᴴᴵⱽᴱ
    JE and Wiseco forged pistons
  • HP engineeringᴬᴿᶜᴴᴵⱽᴱ (Rhode Island). Phone 401-789-6700
    A12 std. Cosworth race pistons with pins (19mm)
    A12 +0.040 Cosworth race pistons with pins (17mm).
    Nissan Competition no longer carries these.
  • Nissan
    76mm race pistons sold by Nissan under the number 12010-A14STD. These are used in the A12A engine when it is bored close to its maximum +0.040 inch overbore.
  • PAECO (closed) These folke are real nice people lots of A-series goodies, custom order pistons, and a great price for the hi perf valve spring, pushrod and lifters, and some nice cam grinds .You can request a catalog via E-mail. Custom order $460/set
  • Peter Zekert - click to see current available pistons
  • Ross Racing pistons (California) $359 without wrist pins and domed for $391 also sans pins
  • Wiseco You name it, we make the piston!
  • Venoliaᴬᴿᶜᴴᴵⱽᴱ (part number 10400 for standard pistons, $67 each in 2008). They told me on the phone a while back that they would make me any piston I wanted for about $86.00 each but they may be more by now
PISTON RINGS
A12A +0.040" over (1.0 mm oversize) is the same as stock A14 pistons
12010 Piston with Pin
12033 Ring Set
1200
12010-H1001/H1011 PISTON SET-with pin A12 regular, A12 GX-low
* 1.6mm dish
12010-18021/H2301 PISTON SET-with pin A12 GX-high
12033-B3040 RING SET-piston A12 all
SET-RING PISTON STD - 73mm bore
12033-H1002
12033-B3040 ^12033-H1002
ITM Part # 51283.STD RPB Standard size Alternate # 021-1335
Interchange:
* B110 1970-1973
* B210 1974 A13
* 410, 411 Sedan & Wagon, 1200cc, 1300cc 1964-1968
* 520, 521 J13 Pick-up Truck, 1300cc 1965-1969
** Replaces Nissan 12033-H6200, 12033-19100, 12033-B3040
SET-PISTON WITH PIN STD (4) A12 (Source: USA catalog)
12010-H1001
12010-H1061
12010-H1011 0672- <> 12010-H1001
SET-PISTON WITH PIN 0.25 OVER SIZE (4) A12
12010-H1003
SET-PISTON WITH PIN 0.50 OVER SIZE (4) A12
12010-H1004
12010-H1065 0672- <> 12010-H1014
12010-H1014 0672- <> 12010-H1004
SET-PISTON WITH PIN 0.75 OVER SIZE (4) A12
12010-H1005
SET-PISTON WITH PIN 1.00 OVER SIZE [0.040"](4) A12
12010-H1006
12010-H1066 0672- <> 12010-H1016
12010-H1016 0672- <> 12010-H1006
SET-PISTON WITH PIN 1.25 OVER SIZE (4) A12
12010-H1007
SET-PISTON WITH PIN 1.50 OVER SIZE (4) A12
12010-H1008
Nissan Competition Parts
NOTE: 99996- part numbers are Nissan Competition
Nissan Competition Catalog
A12/A13 FACTORY CAST FLAT-TOP PISTONS
12010-H2361 73MM/2.874" PISTON
12010-H2310 73MM/2.874" PISTON
* Similar to 12010-12361 except for valve reliefs
  for increased piston-to-valve clearance
12010-12364 73.5/2.894" PISTON
12010-H2366 74mm/2.913" PISTON
12010-H2366 pistons (4) +1.00 mm over size
Cylinder wall thickness should be checked by sonic testing when increasing initial bore size in excess of 1 mm/.03937". Standard bore size for the A12 or A13 block is 73mm/2.874".
PISTON RING SET
12033-H6200 RING SET FOR 12010-H2361 STD
12033-H6200 RING SET FOR 12010-H2310 STD
12035-H6200 RING SET FOR 12010-H2364 +0.5
12037-H6200 RING SET FOR 12010-H2366 +1.0
ARIAS FORGED RACING PISTONS
All of the forged pistons are of the dome-top design. Modifications must be made to the spark plug side of the combustion chamber for proper clearance. The compression ratio will vary depending on the swept volume of the engine and amount of material removed from the cylinder head. Piston-to-wall clearance for forged pistons should be approximately.005" to .007". All forged pistons use a full-floating .750" pin retained by Teflon buttons. For this reason the A12 and A12A pistons require the use of the A12A connecting rod (12100-H8500). Also, the A13 and A14 pistons require the use of the A14 connecting rod (12100-H7200). Because of the full-floating pin the small end of the rod should be sized with a clearance of .0006" to .0009". End gap for the top ring should be .012" to .015". The second ring should have an end gap of .010" to .013". Clearance on the oil scraper ring is not critical. Forged pistons are not recommended for street use
PART NO. DESCRIPTION QTY REQ.
99996-H1017 73MM/2.874" A12/A13 PISTON          4
 99996-H1027 RING SET FOR 99996-H1017           1
 99996-H1022 REPLACEMENT PIN FOR 99996-H1017    4
 99996-H1123 REPLACEMENT BUTTON FOR 99996-H1017 8
99996-H1011 74MM/2.913" A12/A13 PISTON          4
 99996-H1021 RING SET FOR 99996-H1011           1
 99996-H1022 REPLACEMENT PIN FOR 99996-H1011    4
 99996-H1127 REPLACEMENT BUTTON FOR 99996-H1011 8
99996-H1060 76MM/2.992" A12A/A14 PISTON         4
 99996-H1065 RING SET FOR 99996-H1060           1
 99996-H1022 REPLACEMENT PIN FOR 99996-H1060    4
 99996-H1124 REPLACEMENT BUTTON FOR 99996-H1060 1
99996-H1061 76.75MM/3.022" A14 PISTON           4
 99996-H1067 RING SET FOR 99996-H1061
 * This ring set is designed for 77mm/3.032" pistons,
   therefore, some sizing will be necessary to achieve
   the proper end gap.
 99996-H1022 REPLACEMENT PIN FOR 99996-H1061    4
 99996-H1023 REPLACEMENT BUTTON FOR 99996-H1061 8
99996-H1062 77MM/3.032" A14 PISTON              4
 99996-H1067 RING SET FOR 99996-H1062           1
 99996-H1022 REPLACEMENT PIN FOR 99996-H1062    4
 99996-H1126 REPLACEMENT BUTTON FOR 99996-H1062 8
COSWORTH FORGED RACING PISTONS
The only exception to the information provided in the above paragraph <for Arias pistons> is that the Cosworth piston still utilizes circlips to retain the full floating piston pin.
99996-H1170 76MM/2.992" A12A/A14 PISTON 4
99996-H1175 RING SET FOR 99996-H1170    1
Other A12
B310 JPN
12010-H1061 Van 1.3mm dish
C20 Vanette
12010-18011 [flattop]
12010-18021 > 12010-18011
A12A
A12A 75mm bore 1237cc
B310 JPN (S,K "A12", replaced by A13 8011)
12010-H8511 JPN -7901 2.4mm offset dish <2,0> 12010-H8521
12010-H8521 JPN 7910-8010
12010-H9012 USA 0879-0780,CAN ALL YEARS <> 12010-H9022 <> 12010-H9001
12010-H9502 USA 0880- <> 12010-H9512
A13 Tall Block
same dimensions as A12 except
* smaller 0.7mm dish
* 32.65 compression height
USA B210 model year 1974 (from July 1973 to Oct 1974)
12010-H6201 SET-PISTON WITH PIN STD
12010-H6211 SET-PISTON WITH PIN STD <> 12010-H6201
L61-4374 A13 +030" oversize
A13 Short Deck
New A13 engine 1981-1982. 76mm bore, same as A14, but with A12 type crank.
12010-H8661 B310 JPN
H866     designed for B310 2-dr sedan 1300 GL
Aftermarket +0.5 overbore pistons (76.5mm flattops)
18364.jpgAlbum 18364
A14
Factory A14 pistons came in several versions with differing piston dishes, including offset dish
19508.jpgAlbum 19508 174_5c885620573c5.jpgPost click for topic
A15 vs A14 differs in pin height
174_5c885410c2472.jpgPost click for topic
DISH TYPES
02 centered dish
10 centered dish, bevel edges
65 offset dish
Dish: Small vs Large (large used with wedge chambers on FU Engine)
19795.jpgAlbum 19795
Late high-Quench offset dish
19796.jpgAlbum 19796
H72 5.37 mm dish
12010-H7284 STD
* STD GFU EARLY 1276-0777
* STD CAN 0877-
H75 JAPAN B210
* 12010-H7511 3.3mm dish
H76 4.08 mm dish
12010-H7684 STD
* STD GFU LATE 0877-
H87 Offset Dish 4mm
* 12010-H8702 A14 B310 FED 0880-
H89
H92 EFI piston (flattop?)
USA B210 A14 (See A-series Engine Changes)
SET-PISTON WITH PIN
NON-GFU EXCEPT CAN 1978
12010-H7211 STD <> 12010-H7711 <> Sealed Power 12158P 1mm bevel dish
* H721x B210 -0977
*       F10
* H771x B210 1077- <> 12010-H7211 <> Sealed Power 12146P
B310 USA
12010-H7284 A14 CAN
12010-H7684 A14 KFU -0779 4.2mm bevel dish
12010-H7685 A14 FED 0879-0780 <> Sealed Power 12147P
                CAL
12010-H8702 A14 FED 0880- 4mm dish
B310 JPN A14
12010-H7511 V.-7909 3.3mm dish
  12010-H7514 +0.5 oversize
  12010-H7516 +1.0 oversize
12010-H7685 V.7910- 3.3mm dish
  12010-H7687 +0.5 oversize
  12010-H7689 +1.0 oversize
12010-H8911 S,K+AT <2,0> 12010-H8931 7mm offset dish
  12010-H8914 +0.5 oversize
  12010-H8916 +1.0 oversize
12010-H8931 S,K.7910-8010 7mm dish
  12010-H8934 +0.5 oversize
  12010-H8936 +1.0 oversize
12010-H9211 A14E -7909 <2,0> 12010-H9221
   12010-H9214 +0.5 oversize
   12010-H9216 +1.0 oversize
12010-H9221 A14E 7910-8010 7mm dish
   12010-H9224 +0.5 oversize
   12010-H9226 +1.0 oversize
A10 JPN with A14
12010-H7511 -7803, Van 7804-7906 <2,0> 12010-H7685
12010-H7685 Van 7907-
12010-H8911 S,K.7804-7811 <2,0> 12010-H8921
12010-H8921 S,K.7812-7901 <2,0> 12010-H8931
12010-H8931 S,K.7902-
021-6086-STD 76mm
25806.jpgAlbum 25806 25805.jpgAlbum 25805 25804.jpgAlbum 25804
A15
12010-H9718 A15 B310 CAN 0879-
12010-H9704 A15 B310 FED -0779 [2.8mm centered dish]
12010-H9714 A15 B310 FED 0879-0780 [5.4mmm centered dish]
                     CAL -9780
                     CAN 0879-
                     150Y 1979-1982
12010-H9802 A15 CAL 0880- [6.5mm offset dish]
12010-G3421 A15S JPN 8011- [Offset dish]
12010-H9261 A15E JPN 8011- [Offset dish]
Offset-dish pistons were used with the 1981-1982 models along with the H89 cylinder head and the H95 head
24811.jpgAlbum 24811 18872.jpgAlbum 18872
centered-dish pistons were used through 1979-1980
16063_59a26c3295da3.jpgPost 485923
North America
Late A15 -- offset dish pistons
7630.jpgAlbum 7630
B310
PISTON SET-WITH PIN
STANDARD
12010-H9714 A15 CAL	-0780
12010-H9704 A15 FED	-0779
12010-H9714 A15 FED	0879-0780
12010-H9802 A15 FED	0880-
12010-H9714 A15 CAN	0879-
+0.5 mm oversize
12010-H9804 (0.50 O.S.) A15 USA	0880-
12010-H9716 (0.50 O.S.) A15 CAL	-0780
12010-H9706 (0.50 O.S.) A15 FED	-0780
12010-H9716 (0.50 O.S.) A15 CAN	0879-0378
+1.0 mm oversize
12010-H9806 (1.00 O.S.) A15 USA	0880-
12010-H9718 (1.00 O.S.) A15 CAL	-0780
12010-H9708 (1.00 O.S.) A15 FED	-0780
12010-H9920 (1.00 O.S.) A15 FED(MAN)	-0780
12010-H9718 (1.00 O.S.) A15 CAN	0879-
N10
12010-H9802 A15 STD
12010-H9804 A15 +0.5
12010-H9806 A15 +1.0
E15 Piston
E15 engine (1983-up SOHC) piston share similar dimensions to A15, but uses a different kind of dish. Possibly they might work in A15 engine.
Bore: 76 mm (same as A15)
Compression Height: 32.5 mm (same as A15)
Piston Pin: 19 mm (same as A15)
174_56de2b1b60f38.jpgPost 477018
E1 Piston
Old-tech E1 engine piston with full skirts may be used in the A12 engine, but it is heavier, and not certified for 6400 RPM use (the stock A12 redline).
1958-1964 Blubird 211/311/312/410
E1 engine (1189 cc) 73 mm flat-top
* AE 17482
* Kolbenschmidt 91 071 600
AE brand 17482 +0.75 mm pistons placed in Nissan box
26398.jpgAlbum 26398 AE_17482a.jpg AE_17482b.jpg AE_17482c.jpg AE_17482d.jpg AE_17482e.jpg
The Nissan box belong to the modern slipper-skirt pistons
12010-H1016 PISTON SET-with pin (1.00 over size) (Reg Gas)
* (from '72-6) ALL (exc. GX-H)
Using T-slot like early Datsun B10 (A10 engine) pistons.
24385.jpgAlbum 24385
Kolbenschmidt listing
Rings
Damage
Detonation (too much spark advance) causes broken ring lands.
19359.jpgAlbum 19359 8065.jpgAlbum 8065 8066.jpgAlbum 8066
Broken piston
9793.jpgAlbum 9793
Evidence of detonation can be seen in the combustion chamber:
19347.jpgAlbum 19347
Piston top disintegrated
1730.jpgAlbum 1730
Rod pulled the center out of the piston
17120.jpgAlbum 17120
