Front Combination Lamp
Revision as of 00:36, 9 November 2025; view current revision
<-- back to Lighting_System
All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But the specific type varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Datsun 1200 was fitted with four or five different Front Combination Lamps, depending on the year and country. USA and Japan got all-Red, while other countries got Orange+White lamps.
Australia      Indicators (orange) + Clear Parking Lamp
Japan      I   Indicators (orange) + Orange small Lamp
North America  Indicators (orange) + Orange large Running Lamp
ANZAC/Europe - dual color lens
20749.jpgAlbum 20749
Japan/USA - single color lens
20752.jpgAlbum 20752
Body Style
11526.jpgAlbum 11526 2003.jpgAlbum 2003 14018.jpgAlbum 14018 14437.jpgAlbum 14437
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use the standard 1200 single-reflector lens (same as Coupe/Sedan/Van).
1970-1973 - single reflector
1974+ dual reflector (starting September 1973)
The dual-relector lamp uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector. Interchange 1200 with B210: Probable, but requires wiring connector change. This likely uses the same casting molds as EUR/AUS lenses just in a single color.
Bulbs
Main: Bulbs
Japan single-reflector
26717-89920 inner 23/8 watt
26261-89900 outer (small) 3 watt
Japan dual-reflector
26717-89900 inner 23 watt
26715-89920 outer 8/3.4 watt
North America single-bulb
26717-89920 23/8 watt
Wiring Differences
Connectors
1200 bullet connectors (B110 or B120)
B210 multi-connector
20750.jpgAlbum 20750
2-wire Versus 3-wire
3-wire bullet connectors - Japan
2-wire bullet connectors - North America
18092.jpgAlbum 18092
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housings are different so that you cannot simply swap lenses.
Europe, Australia (two-color)
4220.jpgAlbum 4220 2094.jpgAlbum 2094 17257.jpgAlbum 17257 17217.jpgAlbum 17217
Japan, America (single-color, but differ slightly)
2003.jpgAlbum 2003 19862.jpgAlbum 19862 21151.jpgAlbum 21151
Japan - Single Reflector (early) 3-wire Large + small bulb
20754.jpgAlbum 20754
Japan - Twin Reflector (late model) 3-wire 2-large-bulb
20757.jpgAlbum 20757
USA - 2-wire 1-bulb
H16 Export
Two-color lenses for export 1200s except North America: Europe and Australia
17217.jpgAlbum 17217 30037.jpgAlbum 30037
13093.jpgAlbum 13093 17257.jpgAlbum 17257
marked 'IKI 3002L' and 'IKI 3002R'
30640.jpgAlbum 30640 20751.jpgAlbum 20751
26121-H1600 LENS-FRONT COMB
26126-H1600 LENS-FRONT COMB
30641.jpgAlbum 30641 30642.jpgAlbum 30642
H10 Japan Car
19862.jpgAlbum 19862 28374.jpgAlbum 28374
Orange, single reflector, 3-wire, 1-1/2 bulb
20752.jpgAlbum 20752 20754.jpgAlbum 20754
  • 26120-H1010 LAMP ASS'Y-front combination (R.H.)
    • 23/7W bulb
    • 3W bulb
  • 26121-H1010 LENS (R.H.)
  • 26123-H1010 PACKING (R.H.)
    20712.jpgAlbum 20712
28375.jpgAlbum 28375
28373.jpgAlbum 28373
IKI 8008 (?) MADE IN JAPAN
21417.jpgAlbum 21417
サニーB110 フロントレンズ フロントウインカーレンズ フロントマーカー
G10 Japan Sunny Truck
From September 1973 3-wire, 2-reflector, 2-bulb Orange
20757.jpgAlbum 20757 20755.jpgAlbum 20755
  • 26120-G1000 LAMP ASSY-FRONT COMBINATION, RH
    • 23W bulb
    • 8/3.4W bulb
  • 26121-H5000 LENS, RH
  • 26123-H5000 PACKING, RH -8910
  • 26123-G1000 PACKING, RH 8910-
  • 08310-44020 SCREW (2 per side)
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector. Interchange 1200 with B210: Probable, but requires wiring connector change.
20150607210844987.jpg 20150607210845063.jpg 20150607210845129.jpg 20150607210845196.jpg 20150607210845262.jpg 20150607210845329.jpg 20150607210845479.jpg 21940.jpgAlbum 21940 21941.jpgAlbum 21941
H19 North America
18092.jpgAlbum 18092 11720.jpgAlbum 11720
2-wire, single-bulb, single-reflector, orange
  • 26120-H1901 ASSY-LAMP,FRONT COMBINATION R.H
  • 26120-H7000 ASSY-LAMP,FRONT COMBINATION R.H 0772-
  • 26121-H1000 LENS RH AMBER(ICHIKHO)
  • 26121-H1901 LENS RH AMBER(ICHIKHO)
  • 26123-H1000 PACKING RH(ICHIKHO)
  • 26717-89920 BULB 12V-23-8W(ICHIKHO)
  • 08310-44020 SCREW TO FIX LENS(ICHIKHO) (M4X0.7)
North America
H25 Sunny Excellent
The PB110 Sunny Excellent 1400 front lamp is for indicators only. It has a single element for the Turn Signals.
South Africa
The B140 bakkie has the front combination lamp in the front bumper.
26051.jpgAlbum 26051
484381754_2.jpg 16945.jpgAlbum 16945
It looks similar to the Datsun 1000 late sedan lamp.
Prior to the 1400, South Africa sold the standard B120
17621.jpgAlbum 17621
G08 Cherry Cab
From C20 Nissan Cherry Cab チェリーキャブ
400px-Nissan_Cherry_Cab_Truck.jpgWIKI click for photo
G0800 outwardly looks the same as H19 (Single-bulb, two wire, bullet connectors)
Variations
  • one reflector Orange (B110 Japan, USA)
    20752.jpgAlbum click to view
  • two reflector Orange (B120, B210)
    20755.jpgAlbum click to view
  • two reflector Orange-White (Australia)
    20756.jpgAlbum click to view
  • B110 - Bayonet connector wires
  •  ??? - square connector
  • B210 - Multi-pin connector
  • Centered single-reflector (Japan, USA)
  • Offset single-reflector (source: ???)
    20753.jpgAlbum click to view
20749.jpgAlbum click to view 20750.jpgAlbum click to view 20756.jpgAlbum click to view
B210 uses same twin-reflector lenses as 1974-up Sunny Truck, but uses a different connector -- a rectangle-shape multi-connector
20703.jpgAlbum 20703 9305.jpgAlbum 9305 20750.jpgAlbum 20750 20756.jpgAlbum 20756
Australia/Europe 120Y
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the 1200 unit is more rounded.
23008.jpgAlbum 23008
For Japan & USA (all orange), the position of the reflector differs:
510 Offset Reflector | 1200 Centered Reflector
20753.jpgAlbum 20753 20752.jpgAlbum 20752
Clear Lenses
20381.jpgAlbum 20381
Get the right kind of aftermarket lenses for your lamp assembly
  • Euro/Aussie
  • Japan single-reflector
  • Japan dual-reflector
  • USA single-bulb, single-reflector
1849.jpgAlbum 1849 20378.jpgAlbum 20378 24440.jpgAlbum 24440 25580.jpgAlbum 25580 25581.jpgAlbum 25581
Gasket
25614.jpgAlbum 25614 25615.jpgAlbum 25615
ウインカー パッキンゴム
Lens
JAPAN all-orange
26121-H1000 1-reflector lens -7308 ICHIKO 市光 <> 26121-H1010 KOITO
26121-H5000 2-reflector lens 7309- [same as B210]
AUS/EUR orange & white
NORTH AMERICA all-orange
26121-H1000 <> 26121-H1901
Assembly
JAPAN all-orange, dual bulb, 3 male bullet wires
26120-H1000 single reflector -7308 small & large bulbs <> 26120-H1010 KOITO
26120-G1000 dual reflector, two large bulbs 7309-
NORTH AMERICA all-orange, single bulb, 2 male bullet wires
26120-H1900 <> 26120-H1901 <> 26120-H7000
Japan B210
multi-pin connector, 2-reflector, 2-bulb Orange
  • 26120-H5000 LAMP ASS'Y-front combination lamp (R.H.)
    • 23W bulb
    • 8/3.4W bulb
  • 01411-00101 SCREW
