A14 Engine
Revision as of 17:56, 14 March 2009; view current revision
Category: Engine Mechanical
The Nissan A14 engine is a 1.4 liter (1397 cc) engine produced from the 1975 Model year through 2007, produced in various ratings from 50 Horsepower to 85 hp. It the most common A-series engine available in the United States, although in most other markets it is relatively rare. Like the previous 1974 A13 Engine, the A14 is a "tall-block" variant, but the bore was increased to 76 mm, up from 73 mm of the previous A12 and A13 engines. A Hitachi Twin Carb "GX" version of this engine (A14T) was available in some markets.
Also see: Overview of Nissan A engine on wikipedia
  • Being introducedd after 1974, this engine has the features of the A-series Engine Redesign.
  • New A14s are still available from Nissan commercial business (e.g. forklift engine) and in the B140 Nissan LDV Bakkie (Sunny Truck).
  • A14 stamped on pad below Spark Plug #4 and 'A14' cast above fuel pump
OR
  • A14 stamped on pad above fuel pump
  • Notice how the block extends above the timing cover by about 1 inch
Applications
  • 1975-1978 Nissan Sunny B210 (140Y or B-210)
  • 1979-1982 Nissan Sunny B310 (Datsun 140Y or "Datsun 210")
  • 1977-1982 Nissan Pulsar N10 ("Datsun 310")
  • 2007 Nissan LDV 1400 (model B140). See Nissan Sunny.
  • Datsun Forklift models (including turbocharged variant)
A fuel injected version (A14E) was offered in Asian markets in the B310.
Details
  • Engine block has extra mounting boss on left side (now 3 bolts for mounting accessory)
  • A-series Cylinder Heads with medium-oval ports of 28 x 34mm
    • Smaller than the A12GX Engine's monster 30 x 34.5 ports
    • Larger than the 1974 A13's 28 x 30 small-oval ports
  • New four-bolt water outlet (thermostat housing) instead of former 2-bolt design
  • Longer conrod
  • New larger conrod small-end piston pin (now 19mm, 1.6 mm larger)
  • New large valves (larger than A12GX)
    • Intake valve:
  • 3mm larger bore: Now 74 mm
    • requiring new head gasket with large bore
  • 3-belt crankshaft pulley (for Water pump, Air Pump, and Aircon)
  • Heavier flywheel increased by 2.2 lbs (1 kg) for smoother idling
    • 3mm thicker
  • Rubber Engine Mounts now stiffer 1092 lb/in, up from 1008 for 1974 A13.
  • Stronger, light Starter (80mm), starting wih 7404 vehicles
  • Distributor improved by moving condensor inside the housing
  • 3-bolt exhaust pipe-to-exhaust manifold connector
    • stainless front tube (USA only?)
    • aluminized pre-Muffler (USA only?)
HP Ratings
12225.jpg 1979 B310 Chassis plate
  • 65HP - lo-po (economy) A14 Engine. This engine got 47 MPG in the Coupe with 5-speed tranmission. The engine has round exhaust post rather than the usual oval-shaped A14 style.
274.jpg 1481.jpg 1487.jpg 1561.jpg 1562.jpg 2404.jpg 2538.jpg 2542.jpg 2546.jpg 2547.jpg 3240.jpg 3241.jpg 6109.jpg 8359.jpg 8360.jpg 8968.jpg 11420.jpg 13708.jpg 13709.jpg 18666.jpg 16259.jpg 16268.jpg 18665.jpg 18667.jpg
