The Hitachi D4R electronic distributors are used by the early E-series engines. These can these be modified to work in A-series engines. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior High-Energy Ignition Unit![]()
Compare to older Exterior Matchbox (Hitachi D4K)![]()
Variations
D4R80
22162-15M01 CAP ASSY-DISTRIBUTOR N10 E15S USA, N12 E16S USA, B11 E15S+E16S 22157-H9560 ROTOR-HEAD 22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-21M00, 22136-D4700 PLATE ASSY-BREAKER 22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00 SHAFT ASSY [weight & spring shaft] 22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
D4R82
Appears to be very similar to D4R80.
0882-0588 B11 E15S+E16S USA, 0285-0986 N12 E16S USA
0882-0986 N12 USA DISTRIBUTOR ASSY * 22100-32M01,22100-32M01 HITACHI D4R82-24 * 22100-32M03,22100-32M04 HITACHI D4R82-24 W/VENT * 22100-33M01,22100-33M02 HITACHI D4R82-12 * 22100-33M03,22100-33M04 HITACHI D4R82-12 W/VENT * 22100-34M01,22100-34M02 HITACHI D4R82-13 * 22100-34M03,22100-34M04 HITACHI D4R82-13 W/VENT
22162-15M01 CAP ASSY-DISTRIBUTOR 22162-15M02 CAP ASSY-DISTRIBUTOR 22162-15M03 CAP ASSY-DISTRIBUTOR 22162-15M04 CAP ASSY-DISTRIBUTOR 22162-52A01 CAP ASSY-DISTRIBUTOR
22157-03A00 ROTOR-HEAD 22157-H9560 ROTOR-HEAD 22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-D4700 PLATE ASSY-BREAKER (22173)22159-11M00,22159-11M03,22159-11M05,22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00, 22108-11M03 SHAFT ASSY [weight & spring shaft] 22020-15M20 TRANSISTOR IGNITION UNIT
22132-33M00 CAM SET 22132-33M03 CAM SET 22132-34M00 CAM SET
D4R83
D4R83 is a great Hitachi distributor, used on 1980s Nissans and Hondas. The austin boys swap them into A-series engines too.
