Turn signal or flashers, blinkers
Also see:
Switch Assembly
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
- 25540-H1007 SWITCH COMP-turn signal & dimmer STD, B120 -7803 $155.78 USD
- superceded 25540-H1006
- 25540-H1100 SWITCH COMP-turn signal & dimmer
- OPTION DX, GL, GX
- Optional on B120 -7803
- Standard on B120 7804-
Hazard & Parking Light Switch
- 25290-H4600 COMP-SWITCH HAZARD 0172-
- replaced 25290-H1900 COMP-SWITCH HAZARD
- 08513-30812 SCREW FIXING HAZARD SWITCH (3)
- 08915-13310 WASHER-SPRING (3)
JDM
- 25290-H1001 SWITCH ASSY-hazard & parking B110 [also used by B120 -7803]
- 85-13308-12 SCREW (3)
- 89-15133-1 WASHER-lock (3)
B120 Pickup
Early
- 25290-H1001 SWITCH ASSY-HAZARD & PARKING -7803 [also used by sedan/coupe/van]
- 08513-30812 Screw, fixing
Facelift (brown?)
- 25290-G1060 SWITCH ASSY-HAZARD & PARKING 7804-8608
- 25290-G1260 SWITCH ASSY-HAZARD & PARKING 8608-8910
Late Model (gray)
- 25290-95W00 SWITCH ASSY-HAZARD & PARKING 8910-
- Single Hazard button (no parking light buttons, as in earlier JDM switches)
Light Switch
- 25160-H1101 SWITCH COMP-lighting B110 (also B120)
- 25160-H1110 SWITCH COMP-lighting, with fog lamp switch (op.)
- 25160-H2510 SWITCH COMP-lighting, w/o fog (op.)
- 25160-H2511 SWITCH COMP-lighting, with fog (op.)
- 25165-H1000 KNOB ASSY-lighting
- 25165-E7500 KNOB ASSY-lighting, with illumination, w/o fog (op.)
- 25170-H2510 LAMP ASSY-illumination (op.)
Custom
Also here's a custom update: Add a Bluebird multi-switch. Bolts to the 1200 column:
- T/S switch
- Light switch
- Wiper switch
