The Datsun 1200 strut top is a rubber insulator for the the strut, and includes a bearing for easy rotation for the steering system.
Contents[hide] |
Also see
Stock 1200 strut tops stick up out of the tower:
54320-H1000 INSULATOR-STRUT MOUNTING (2) 08915-53810 WASHER-PLAIN M8 (6) 08915-13810 WASHER-SPRING M8 (6) 6 08911-10810 NUT-HEX M8X1.25 (6) 6 54325-H1000 BEARING-STRUT MOUNTING (2)
Comparison
Strut tops: B210 (left) vs B110 (right)
The B110 strut tops are different from B210 & B310 tops. They latter have a higher profile and raise the car up, so use the B110 tops. If there is nothing poking up through the hole in the strut tower,then it's "wrong" for a 1200.
Covers
TIP: You can use rubber covers from an early 90's Mazda 323 w/ electric adjustable suspension. Thse covers sits perfectly over a 1200 strut tower, even with large 1200 strut tops or camber-adjustable strut tops.
