Rear Brakes
Revision as of 02:31, 13 December 2012; view current revision
Category: Brake System
Rear brakes are traditional twin-shoe type.
[hide]
The same rear brake drum was used 1967-1994. It is an 8" diameter cast iron drum, that fits 1-3/8 wide brake shoes. Sunny Trucks started using a different brake shoe from Oct 1989.
Specs
  • Linings (shoes)
    • 35 x 4.8 x 195 mm (width x height x thickness)
    • 1.378 x 0.189 x 7.68 inch (W x H x T)
    • 1-3/8 x ~3/16 x ~7-11/16 inch (W x H x T)
  • Total breaking area: 273 cm² (42.3 sq. in.)
  • B110: (manual adjusting)
    • Cylinder: 11/16" with front discs
    • Cylinder: 13/16" with front drums
  • B310: Drum LT-20 (auto adjusting)
    • Cylinder: 13/16" (20.64 mm)
1978-1989 B120 ute used rear type Drum-LT20 with front type Drum2L20.
Finned Alloy Brake Drums
  • The fins look like structural type, not cooling type.
quote
Datsun Competition Dept supplied it's favoured teams with many experimental parts that were never sold over the counter. 1200s had alloy drums and calipers fitted as wellas the alloy diff heads from the wagons.
  • Finned drums like these were offered by Datsun Competition in Japan.
Rear Brake Shoe
set (8 x 1-3/8, fits B110, B210 and B310)
  • RAYBESTOS 371PG $15.36
  • WAGNER PAB371 $16.52
  • ACDELCO 17371B $19.02
  • WAGNER BD60368 $39.89
B110 rear brake parts
Rear Drum Brake
  • 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
  • 44060-G0325 7612-8910
  • 43206-18000 DRUM BRAKE-REAR
  • 44060-G1225 8910-
1980 10 and newer Sunny Truck feature auto-adjust rear brakes:
Adjusters
B110 adjusters (manual, square adjustment nut)
44200-18000
B310 A14/A15 adjuster assembly (automatic with star wheel)
44209-W5210 ADJUSTER LEVER ASSY RH
44210-25210 ADJUSTER LEVER ASSY LH
1200 late star aduster (self-adjusting with star wheel)
44200-W5211 ADJUSTER ASSY-REAR BRAKE, RH
44201-W5211 ADJUSTER ASSY-REAR BRAKE, LH
B310 small H83 (automatic with star wheel)
44200-H8300 ADJUST. ASS'Y RH
44201-H8300 ADJUST. ASS'Y LH
B310 star adjuster (A14/A15 models)
44202-W5210 SCREW RH
44203-W5210 SCREW LH
To 7302
  • 13/16" diameter
    • 44100-18000 ASS'Y-CYLINDER-rear wheel (13/16") B10, B110 to 7302
    • Fits early B110 with front drum brakes
RockAuto $13
  • 11/16" diameter
    • 44100-H0500 CYLINDER ASS'Y-rear wheel (11/16")
    • Fits early B110 with front disc brakes
RockAuto $30
From 7303
  • 44100-H3100 CYLINDER ASS'Y-rear wheel (13/16")
    • for late B110 with front drum brakes
  • 44100-H3300 CYLINDER ASS'Y-rear wheel (11/16")
    • for late B110 with front disc brakes
