Australia-produced Bosch Electronic Ignition from the Bluebird Series 2 can be adapted to the A-series engine. It is not a bolt-in until machining has been done to the unit.
This distributor was fitted to L-series engines and unlike Japan-built distributors, did not use a separate Support base.
22100-V9610 U-PGFU 4 -> 349 520
Bosch distributor was used only on the 1983-1984 Series 2 Bluebird, in Australia
4-pin connector large cap cast metal ignitor box
To get the best from it, you will need to use the matching high energy type coil. That will really make those plugs throw a spark
DatRats of Victoria did conversions to A-series when they were still operating, and the workmanship was superb.
Modifications
Machine off the flange and lathe to proper diameter to fit into the A-series block.
- Lathe to appropriate diameter
- regraph
- test
- add A-series cog
The shaft is correct diameter and length for the A-series gear to fit. Drill a new hole for the gear pin.
NOTE: Although it looks different, both L-series and A-series distributors rotate anticlockwise when viewed from the top.
Clamp
After lathing the distributor shaft, a hold-down clamp must be fitted.
DatRats fitted a billet aluminum hold-down clamp:
But an Austin clamp possibly could be used
Just remove the ballast resistor, re-join the wires and voila! electronic distributor. Never renew them bloody points again!
