Exhaust Manifold
Revision as of 06:37, 3 February 2013; view current revision
Categories: Engine Mechanical | Manifold
Datsun 1200 uses a single-outlet cast-iron exhaust manifold. It has a two-bolt flange to the exhaust piping. They can be replaced with tubular headers.
Single Outlet
Early A12s used a two-bolt exhaust pipe flange. A14/A15 and late A12 have three-bolt exhaust pipe flange.
Datsun 1200
B110 manifold has heat riser for bottom of intake manifold.
  • 3-bolt stove gasket
  • Datsun 1000 manifold is similar, but with a smaller 30mm outlet. A12 engine has 34mm outlet. Also the exhaust pipe joint is reshaped for performance increase.
14004-H1030 MANIFOLD-EXHAUST 1 A12 CRANK -273 USA,JDM NLA
14004-H1930 MANIFOLD-EXHAUST 1 A12 EXHAUST USA - superceded
14004-H3950 MANIFOLD-EXHAUST 1 A12 0671 USA - superceded
14004-H3930 MANIFOLD-EXHAUST 1 A12 -273 USA 14004-H3950 superceded
14004-H3931 MANIFOLD-EXHAUST 1 A12 0373- USA 14004-H3930 $203.14
14004-H1031 MANIFOLD-exhaust, with heat control (from '73-3) JDM, also B120 -7908
08213-82810 STUD (fixing manifold to exhaust tube and cylinder head) (11)
14064-H5001 STUD B120 7510-8910
14005-18000 GASKET (fixing intake manifold to to exhaust manifold)
08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST 2
14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD 14005-18000
14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD
08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 2
01111-00032 BOLT
08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 3
08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
08915-13810 WASHER-LOCK 5
14037-32200 YOKE-MANIFOLD 4
14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD 14035-18000
14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD
14022-18000 SPRING-HEAT CONTROL THERMS
14025-85061 KEY-HEAT CONTROL VALVE
14026-18001 WEIGHT-COUNTER VALVE
14027-36700 WASHER-HEAT CONTROL
14047-36700 SPRING-STOPPER HEAT CONTROL
The optional heated-air cleaner duct clamps on:
th_exhaust-manifold-2.jpg th_exhaust-manifold-1.jpg th_exhaust-manifold-3.jpg
1972 manifolds used a bolt-on heated air duct.
Datsun 1000
B10 manifold look like the larger 1200 manifold, but the heat riser area is smooth, without the two vertical standups of the 1200 exmani.
Heat Riser flap was used starting in mid-1967.
1000 Coupe used a dual-outlet exhaust manifold (see Double-Outlet section below)
14000-18000 ASS'Y-MANIFOLD, intake & exhaust (up to E/# A10-200838)
14000-25700 ASS'Y-MANIFOLD, intake & exhaust Coupe
14003-18000 MANIFOLD-intake
14003-18001 MANIFOLD-intake (from E/# A10-200839) (exc. Coupe)
14004-18000 MANIFOLD-exhaust
14004-18050 ASS'Y-MANIFOLD, exhaust [has heat riser flap]
* 82-16828 STUD (fixing manifold to exhaust tube) 2
* 82-13828 STUD (fixing manifold to exhaust tube) 2 (from E/# A10-59060)
14004-25700 MANIFOLD-exhaust Coupe
* 82-16822 STUD (fixing manifold to exhaust tube) 3 Coupe
14035-18000 GASKET-manifold to cylinder head
B210 JDM
14064-H5000 STUD (2)
14064-H5001 STUD (from '74-1) (2)
14004-H1031 MANIFOLD-exhaust [same as 1973 B110] A12 1974/1975 & A12 Van
 14005-18000 GASKET-INT to EXT manifold
14004-H7431 MANIFOLD-EXHAUST A14S Van
14004-H8231 MANIFOLD-EXHAUST A12,A14S Coupe,Sedan
 14097-U9500 GASKET-STOVE
14064-U6700 STUD-EXHAUST TUBE (3)
1974 A13
Larger passages
EGR port
4-bolt square heat riser (stove) gasket
14004-H6230 MANIFOLD-EXHAUST
14004-H6232 MANIFOLD-EXHAUST code-5
Mid B120
B120 7907-8910 2-bolt outlet, similar to the old B10 manifold.
14064-H5001 STUD (2)
14004-G2536 MANIFOLD-EXHAUST 7908-8109
 14005-18000 GASKET-INTAKE TO EXHAUST MANIFOLD 7908-8109
14004-G2561 MANIFOLD-EXHAUST 8110-8910
 14005-G2560 GASKET-INTAKE TO EXHAUST MANIFOLD 8110-8910
3-bolt Single Outlet
95W
A12 late style (8910-) 3-bolt with O2 sensor with heat shield
14004-95W00 MANIFOLD-EXHAUST SB B120
14004-95W01 MANIFOLD-EXHAUST LB B120
14064-11M00 STUD (3)
A14 USA
1975 A14
14004-H7230 MANIFOLD-EXHAUST -0775 B210 USA
14064-U6700 STUD FIXING EXHAUST MANIFOLDTO EXHAUST (3)
New heat riser (stove) design borrowed from 610/620/710
larger exhaust ports (?)
heat shield added
3 stud outlet
14097-U9500 GASKET-STOVE 0476-
superceded 14097-U6701
1976-1978
14004-H7330 MANIFOLD-EXHAUST A14(USA) 0875-0776
14004-H7235 MANIFOLD-EXHAUST A14(USA) 0876-
14004-H7330 MANIFOLD-EXHAUST A14(CAN) 0875-0777
14004-H7235 MANIFOLD-EXHAUST A14(CAN) 0877-
14004-H7239 MANIFOLD-EXHAUST A14(FED)(GFU) 1276- B210
B310 FED KFU
14004-H7239 MANIFOLD-EXHAUST A14 FED(KFU) -0779
14004-H9900 MANIFOLD-EXHAUST A14 FED(KFU) 0879-
14064-U6700 STUD-EXHAUST TUBE FIXING (3)
B310 except FED KFU
14004-H7235 MANIFOLD-EXHAUST A14/A15 -0779
14004-H7235 MANIFOLD-EXHAUST A14 CAN 0879-0780
14004-H99O0 MANIFOLD-EXHAUST A14,A15 FED 0879-0780
14004-H9910 MANIFOLD-EXHAUST A14,A15 CAL 0879-0780
14004-H9501 MANIFOLD-EXHAUST A14,A15 USA 0880-
A12A Canada
with heat riser
14004-H7239 MANIFOLD-EXHAUST A12A B310 CAN
A12A USA
without heat riser
14004-H9900 MANIFOLD-EXHAUST A12A B310 FED 0879-0780
14004-H9910 MANIFOLD-EXHAUST A12A B310 CAL 0879-0780
14004-H9501 MANIFOLD-EXHAUST A12A B310 USA 0880-
14064-U6700 STUD-EXHAUST TUBE FIX (3)
JDM
without heat riser
14004-H7431 MANIFOLD-EXHAUST A14S.V B210
with heat riser
14004-H8231 MANIFOLD-EXHAUST A14S,A12S Coupe,Sedan B210
B310
without heat riser
14004-H8501 MANIFOLD-EXHAUST A12S, A14S S,K+AT -8010 B310
14004-H8660 MANIFOLD-EXHAUST A13S, A15S 8011- B310
with 4-bolt heat riser
14004-H7431 MANIFOLD-EXHAUST A14S.V -7909 B310
with 3-bolt heat riser
14004-G2536 MANIFOLD-EXHAUST VAN 7910-
H84
H84 A14T twin-carb manifold without heat riser, 5-boss
14004-H8400 MANIFOLD-EXHAUST
H89
H89 A14/A15 manifold without heat riser
This is probably
A15
A15 Late without heat riser, with EGR port, with undrilled O2 boss, and additional undrilled boss to rear of Port 4
H92
14004-H9200 MANIFOLD-EXHAUST A14E
H92 is also used for the dual-outlet A15E manifold
Dual Outlet
Datsun 1000 Coupe
KB10 used a dual-outlet manifold with a standard heat riser to keep the bottom of the intake manifold warm.
82-16822 STUD (fixing manifold to exhaust tube) (3) Coupe
A12 GX
A12GX Engine used a dual-outlet manifold that is not connected to the intake manifold (has no heat riser).
14004-H2300 MANIFOLD-exhaust
08213-82800 STUD-fixing exhaust tube 3
GX manifold
3947.jpg 8995.jpg9261.jpg 9262.jpg 10728.jpg 11077.jpg 11086.jpg 21884.jpg 22132.jpg
A15E Manifold
A15E
14004-H9260 MANIFOLD-EXHAUST A15E
20711-H9200 GASKET-EXHAUST
Forklift Manifold
エキゾースト マニホールド エキマニ
