Datsun 1200 and Truck variants were fitted with a variety of steering wheels. They are 15 inch diameter wheels (overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
Variations
DX, GL, and GX comparo![]()
STD/DX (1-spoke)![]()
GL (3-spoke)![]()
GX (3-spoke metal)![]()
Sunny Truck![]()
SSS See main article: SSS![]()
PB110 used the same steering wheels as B110 (at least with early PB110)
PB110 GX
B10
The Datsun 1000 (B10) wheels were different:
See main article: B10 Steering Wheel
B310
B310 steering wheels are not supposed to fit B110 or B210 steering column. But you can modify the steering column.
JDM B310 DX single spoke GL tri-spoke GX leather-like & stainless OPT black wood & stainless brown wood & stainless leather-like & stainless
B310 GX leather-like vinyl with stainless spokes
full
B310 GX in B110
B310 GX in B110 (with B110 GX horn button)
B310 DX in B210
Nismo 10th Anniversary
Removal and Installation
Be sure to use a wheel puller:
Occasionally you can remove the nut and "pop" it off by hitting it from behind with your fists, but you risk the chance of having it hit you in the face when it pops loose. Discussion
Be safe, don't worry. Only about $15 new.
To remove the horn button, remove the two screws from behind the wheel (B110 normal) or push in and twist for GX type.
Other wheels fit the hub but may not match the trim. The B110 steering wheel hub uses the same bolt pattern as:
45mm between bolts (1-15/16 inch) * 1970-1976 B110 (Sunny/1200) * 1974-1978 B210 (Sunny/120Y) * 1977-1979 S10 (Silvia/SX200) * 1976-1977 F10 (Cherry) * 1979-1982 N10 (Pulsar/210)
Only three Datsun models used the small diameter steering column shaft, those models being the B10, B110 & B210. The B10 used blinker canceling pins that were reasonanly close together & this made it unique, The B110 & B210 share the same specs so the hub/boss is interchangeable between these two models.
All other Datsun models [at least those from the mid 60's], including the B310, used a larger diameter shaft & the boss for any of these will be too big in the hole.
B110 and PB110 (at least early PB110)
- 48498-H1000 EMBLEM 'S' MARK DX
- 48498-H1100 EMBLEM 'D' MARK DX
- 48400-H1000,48400-H1001 ASS'Y-WHEEL-steering Std, Dx
- 48400-H2300,48400-H2301 ASS'Y-WHEEL-steering GX
OPTIONAL - There were two Optional Steering Wheels
- 48400-H1200 ASS'Y-WHEEL-steering (wood) OPTION ALL (per JDM catalog)
- metal three-spoke, one-slot spokes covered with plastic trim
- 48400-H2310 ASS'Y-WHEEL-steering (foam skin) OPTION ALL (per JDM catalog)
These wheels were derived directly from the B10 option wheel. They made a new hub (boss) to suit the 1200 column & a new horn button to 'update' them but are otherwise the same.
The optional wheels are different from the B10 mainly in the horn button and the hub part (the wheels themselves appear to be the same, but were only sold as an assembly).
- The 1200 horn button is wider at the top, and narrower where it bolts to the wheel
- The 1000 horn button is the opposite (narrower at the top)
Also, the 1200 hub part where it meet the steering column is bigger diameter. So the 1200 hub flares out slightly to this larger diameter. The 1000 hub is completely cylindrical.
Note that the 1000 hub on the right is cylindrical & has closely spaced blinker pins, while the 1200 hub on the left is conical, or bell shaped & has pins more widely spaced.
The wheel & the complete horn switch assembly are identical between the B10 OPTION wheel and the B110 OPTION wheel.
Sunny Truck
Center Emblem
- 48498-H1000 -7803 NLA
- 48409-H5002 7804-7907
- 48409-G1660 7908-
48400-H5000, 48400-H5001 STD, DX, PB210 DX * two-spoke![]()
full
48400-H5100, 48400-H5103 black (wood-like) GL * three-spoke![]()
48400-H5102,H5105 black (wood-like) PB210 GL, op. PB210 DX![]()
48400-H5101,H5104 brown (wood-like) PB210 GL, op. PB210 DX * three-spoke * 48400-H5104 brown (wood-like) L16 GL * 48400-H5105 black (wood-like) L16 GL
48400-H5200 (leather-like) GX, op. ALL *![]()
48400-H5202 < 48400-H5203 (leather-like) GX, op. ALL * three-spoke, five rectangular holes in each spoke![]()
48400-H7210 ASSY-STEERING WHEEL 3 SPOPK LEATHERETTE OP.COUPE FROM 0875 USA![]()
48400-H5600, 48400-H5800, 48400-H5802 (wood) OPTION ALL, PB210 OPTION ALL * three-spoke, five rectangular holes in each spoke48400-H6000, 48400-H6001, 48400-H6002 (leather-like) PB210 GX, L16 GX, L16 GL
48400-H7509 A14T:GX-T
48400-H7800 Van Super Deluxe (black wood-like)
GX center pad removal: Push in hard and and slowly gently twist it counterclockwise and it should just turn and plop off.
B210 GX
B210 GX handle, OPTION for non-GX * Black Spokes, spiral-pattern emblem * Chrome Spokes, wood-pattern emblem (from 1973 October)
This variation has chrome spokes (black is more common) and an unusual wood-grain center emblem without a horn mark
Spiral-pattern center with horn logo
S10
1977-1979 Datsun 200SX (Silvia) used a steering wheel that looks like the B210 GX wheel.
- Black 48400-N5810/48400-N5815
- Brown 48400-N5811/48400-N5816
- Brown, light 48400-N7800 1979
- Green 48400-N5812/48400-N5817
- Blue 48400-N7801 1979 only
Does this fit small shaft (B110/B210) or large shaft (B310)?
Aftermarket Adapter Hubs
See main article: Steering wheel boss kit
Cherry
E10 Nissan Cherry wheel in B110
E10 Cherry - see main article: X-1R
Unidentified
Datsun B10 OPTiON wheel with aftermarket (Nismo?) 'GT' horn button
post
