Neutral Switch
Revision as of 08:35, 21 July 2016; view current revision
Category: Transmission
Some manual transmissions were fitted with an electrical Neutral Switch to signal when the gearbox is not in gear. All Automatic Transmissions are fitted with a an Inhibitor Switch which also signals when the automatic is in Neutral.
Neutral Switch was first used in 1973 USA models.
Neutral Switch was used for:
* EGR (some years e.g. 1990 1200, 1975 B210)
* Fuel Shut-Off System on B310
* Starter interlock on automatic cars
* Throttle Opener used the Inhibitor Switch to detect neutral
* TCVAS spark control used the Top Switch to detect neutral
Neutral Switch is near top of 4-speed 56-Series Transmission
19052.jpgAlbum 19052
Reverse Switch is on bottom or side (not near the top)
Neutral Switch (yellow arrows)
Reverse Switch (green arrows)
21404.jpgAlbum 21404
Reverse Switch
See main article: Reverse Lamp Switch
Reverse Switch is located on the shifter extension of tail housing very near the top of the housing.
Top Switch
Top Switch is used by the TCVAS system. It is in the middle portion of the gearbox case, unlike the other switches which are in the tailshaft case.
See Main Article: Top Switch
Also See:
* Inhibitor Switch for automatics
* 63-Series_Transmission#Switches
32130, 32006
32005-21101 SWITCH ASSY-REVERSE LAMP
32006-G6200 NEUTRAL POSITION SWITCH
B310 USA
A12 56-series 4-speed
* 32005-H5000 SWITCH COMP-REVERSE LAMP <> 32005-K1201 <> 32005-K1202
* 32006-K2400 SWITCH COMP-NEUTRAL <> 32006-K2401
  CAL 0879-
* 32006-K2000 SWITCH COMP-4TH <> 32006-D0120 <> 32006-D0102
A14/A15 60-series 4-speed
* Reverse same as 56-series 4-speed
* Neutral same as 56-series
  CAL 0879-
  CAN
* SWITCH COMP-TOP (0879-) - same as 56-series
  FED, CAN
A14/A15 FS5W60L & FS5W60A
 32005-K1000 SWITCH COMP-REVERSE LAMP <> 32005-K1001 <> 32005-K1002
 32006-D0102 SWITCH COMP-TOP <> 32006-D0120
 32006-K2000 SWITCH COMP-TOP
 32130-H9000
 32130-H9010
 32130-H9705
  CAL
  COUPE
NOTE: Sometimes misspelled as 'Nuetral Switch'
