1200 performance parts. MAD DAT does mail order, shipping to other countries.
1200 Parts
* GENUINE NISSAN PARTS (request)
Engine Swaps
* CA18/1200 Fitting Kit * 13BT into 1200 Engine Fitting Kit * SR20/1200 Fitting Kit see SR Crossmember * Plug & Play Wiring Loom * New Datsun 1200 Ute Engine X-Member * Clutch Reservoir Relocation Kit * Polyeurethane Engine Mounts * Underfloor Fuel Package
Suspension
* 1200 Conversion Sway Bar Kit * Ultimate Race Coilover Package * Lowered Front Strut Assembly Pair * Adjustable Rebuilt Front End (suit Stanza/200B strut) * Rebuilt Front End (suit 1200 strut) * Tie Rod & Ball Joint Kit 1200 * 1200 Adjustable Lower Control Arms * Caster Adjuster Bar Kit (1200) * New Bush Kit Suit 1200 Models (blue polyeurethane) * 1200 Genuine Nissan Rubbers * 1200 Non-Genuine Nissan Rubbers * Strut Brace (1200) * Strut Brace Tri-bar (1200) * Lowered Rear Springs * Adjustable Rear Koni Shocks (pair) * 1200 Steering Box Brace
Brakes
* Front Brake Conversion Kit (280mm rotors) * Front Brake Conversion Kit Alloy Hub * Brake Booster/Master/Bracket/Clutch * Heavy Duty Clutch Pedal * CA18/1200 Brake Bracket
Diff
* Mad Dat Diff ** Diff Housing & Rear Disc Brakes (Shortened R31 28 spline) ** Diff - Gears & LSD ** Diff - Minispool ** Diff - KAAZ LSD
Turbo
* Intercooler & Radiator * CA18/1200 Dump Pipe * SR20/1200 Dump Pipe
Body & Interior
* 1200 Dash pad, RHD, brown only * Short Throw Shifter (A-Series Gearbox) * Replacement Shifter Bushes * CA18/1200 Accelerator Cable * SR20/1200 Accelerator Cable * CA18 or SR20/1200 Speedo Cable * Transmission Tunnel * Universal Heater Box * Steering Column Bush * Hard Top Lid suit 1200 Ute * Front Bumper * Bonnet * Tail Gate Outer
