Production in Japan ended March 1994. Common equipment includes:
- A12 Engine
- F4W56 Transmission
- 4.11 diff ratio
- 4Jx12 wheels
- 35 amp Alternator
- Clock optional
- No Tachometer
- Package Tray optional
- Automatic-style Console
- No automatic transmission offered
Chassis ID Numbers
Applied Model code: G16
- B120T to 7907
- GB120T to 7907 Long Body (long bed)
- B121T 7908-8109
- GB121T 7908-8109 Long Body
- B122T 8110-
- GB122T 8110- Long Body
1970-1977
B120
Same as Datsun 1200 Standard trim cars:
- Black interior
- H145 rear axle assembly
- Front Drum brakes
- Stainless grille (same as sedan/wagon)
- EVAPO Flow Guide Valve (same as USA models)
- Gray wheels
- 'Sunny' sedan-style rear quarter badges (to 8102)
- Disc Wheel Caps (dog-dish hubcaps)
from 1974:
- H165 rear axle assembly
1978 - 1988
B120 to 7903, B122 from 7908
- Aero mirrors
- Round gauges
- Dark Brown interior (7804-7907)
- Brown interior (7908-8110)
- Hi-back seats (no headrests)
- B210-style steering wheel
- Intermittent wiper switch
- black rubber ends on front bumper
- from 7804: Coupe-style plastic grille -- but with silver surrounds and rectangular center emblem
From 7901
- Silver TOPY wheels
From 7908
- B122 designation
- New-style intake manifold bolt pattern (dry manifold)
- EGR added
- Disk wheel ornaments (Center wheel caps replacing dog-dish)
from 8103
- * Rear label: "Sunny", "Sunny Long Body" block-style
from 8110
- emergency signal holder on passenger side kick panel
- door pocket
- New-style VIN plate
- IC alternator (some)
From 8504 "Minor Change"
- Cold Air duct for air cleaner
- Hood insulator
- Exhaust Resonator added
- Silver Nissan wheels
1989- 1994
B122 from 8910
- Nissan front emblem
- Front disk brakes
- Single-reservoir, tandem master cylinder
- Brake booster
- New rear brake design (still using B10 brake drum)
- Gray interior
- Rear label: "Nissan"
- Integrated seat/shoulder belt standard (previously optional)
- Square headlights
- Electronic ignition
- Fuse box with rectangular fuses
- Wet intake manifold
- Oxygen Sensor 22690-F5300
- Superceded by 22690-17B00
- Same as Sentra, E16i eng 1984 - 1986
- Engine Control Module 220604-95W00
- Catalyst (catalytic convertor). 3-way type.
- Heated air-cleaner motor
- Fuel tank with return line
- Larger muffler and resonator
- EVAPO Charcoal Cannister replaces Flow Guide valve. Rocker cover has right-angle breather outlet
- Revised F4W56 transmission with Neutral switch
- 19T gear up from 18T
Trim Code
For 1989-up
Trim code: K (Gray ???)
Body Color
- #002 White ????
- #EH3 Dark Yellow ????????
- #544 Blue????
- #BG9 Greenish Blue metallic ????????????????
Options
- Passing light switch & relay
- Low horn
- Clock
- Package tray
- Carpet floor
- ? heater
- side visor set
From 7804
- ELR 3-point seatbelts
- Cooler (air conditioning)
- hard ??leafspring
- hard ? starter
- Guard frame (rear window bars)
Long Body
The Long Body (LB) has these differences from standard short body (SB):
- Wheelbase is longer
- Cargo box (bed) is longer
- Has two-piece drive shaft with Center Bearing (carrier bearing)
- Front exahust pipe is longer up to 8909
- longer exhaust system from 8910
- no resonator from 8910
Parts
- 90500-01W00 Back Door Lock Ass'y (tailgate handle) available in USA $27.34
- 96321-95W00 Inside Mirror $26.43
