Side Lamps
Revision as of 04:17, 8 October 2017; view current revision
Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibily (instead of turn signals) they are made larger to be more visible, and are fitted front and rear. USA B110 markers are approximately the same size as B210 worldwide markers.
Variations
1200 #global
1200 #North America
* front and rear lamps/reflector
#Worldwide all other countries
* long thin ORANGE lenses for turn signal (blinkers)
* front only
Global
'IKI 5002 JAPAN' used as winker/blinker (indicator) lamp
18 mm long, marked 'B-110 45 TOKYO'
20764.jpgAlbum 20764 20763.jpgAlbum 20763 12063.jpgAlbum 12063
8456.jpgAlbum 8456 3812.jpgAlbum 3812 4099.jpgAlbum 4099 4457.jpgAlbum 4457
26160-H1001 LAMP ASS'Y-side flasher
26160-G1060 LAMP ASS'Y-side flasher 7804- TRUCK
* integrated two-wire harness (bulb 12V + earth/ground)
26161-H1001 LENS [marked 'IKI 5002 JAPAN]
26162-H1001 RIM
20765.jpgAlbum 20765
26164-H1001 PACKING
26164-G1060 PACKING 7804- TRUCK
01451-00071 SCREW
08964-10410 NUT-spring
26715-89900 BULB-6W
9516.jpgAlbum 9516 16407.jpgAlbum 16407
sla.jpg slb.jpg slc.jpg sld.jpg sle.jpg slf.jpg slg.jpg slg.jpg slh.jpg sli.jpg slj.jpg slk.jpg slm.jpg sln.jpg slo.jpg slp.jpg slq.jpg slr.jpg
North America
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged. Australia moved to the same-sized large lights with the 1974 120Y.
* 2-wire (12V + Ground)
* individual wires (one female bullet, one male bullet)
* right and left differ
* front and back differ
* sedan and coupe differ
See Side Lighting Parts Numbers
COMMON [4 of each per vehicle]
* 26182-H1900 RIM
* 26715-89902 BULB 12V-8W (ICHIKHO)
* 08964-10410 NUT-SPRING (ICHIKHO) [8 per vehicle]
ORANGE, FRONT
20761.jpgAlbum 20761
* 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
* 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH (ICHIKHO)
* 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772-
* 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772-
* 26181-H1900 LENS, FRONT [amber]
** 01451-00041 SCREW (2 per lens)
* 26184-H1900 PACKING RH
* 26189-H1900 PACKING LH
RED, REAR
20760.jpgAlbum 20760
COMMON
* 26191-H1900 LENS, REAR [red]
COUPE
10023.jpgAlbum 10023 4185.jpgAlbum 4185 5035.jpgAlbum 5035 6603.jpgAlbum 6603
* 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
* 26195-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
** 26194-H1910 PACKING RH(ICHIKHO) COUPE
** 26199-H1910 PACKING LH(ICHIKHO) COUPE
** 01451-00061 SCREW(ICHIKHO) COUPE
SEDAN
1479.jpgAlbum 1479 3636.jpgAlbum 3636 4643.jpgAlbum 4643
* 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
* 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) SEDAN
** 26194-H1900 PACKING RH(ICHIKHO) SEDAN
** 26199-H1900 PACKING LH(ICHIKHO) SEDAN
** 01451-00041 SCREW(ICHIKHO) SEDAN [same as front]
740.jpgAlbum 740
Wiring connectors differ between early, late 1200s and differ for various countries. Early 1200 lamps use bullet connectors.
Only the 1200 lights interchange.
620
In USA, the early 620 lamp assembly looks identical, however it uses a highly-angled plastic piece in the rear.
Pointed Lens
Pointed lens is used by B210 and 240Z and (late USA) 510. B110 is rectangular, compared to the slightly pointed rectangle type.
1200 North America
Pointed type
{{Photo|26161-E4100_IKI_5005-.jpg}
B210 side lamp is different from B110 lamp, and uses a different connector style
th_B210_side-marker-lamp_AUS.jpg See main article: B210 side lamp
S30 240Z bullet wire connectors
S30 260Z/280Z rectangular connector
B210 (120Y)   rectangular connector
510 late
The USA late 510 units 1970-1972 uses the 240Z pointed lens, though the assembly differs somehow
[1972_datsun_510-pic-42842.jpg [1] 1972_datsun_510-pic-42842_.jpg]]
S30
240Z has individual wires
260Z has the rectangular connector
Lamp assembly differs from B210 somehow
North America (Canada and USA) used amber front side lamp and red rear side reflector
IKI 5005 & 5004
26160-E4100 & 26165-E4100
26160-E4100
26190-E4600 & 26195-E4600
LENS 26161-E4100 IKI 5005
26161-E4100_IKI_5005_.jpg 26161-E4100_IKI_5005.jpg 26161-E4100_IKI_5005-.jpg
PB110
See Main Article: PB110#Side_Lights
Datsun 1000
See main article: Datsun 1000
B140
South Africa B140 bakkie from 1982-2004 used the global indicator. From 2005 used a unique small lamp.
From 2005-2008 used this small indicator:
26051.jpgAlbum 26051
26054.jpgAlbum 26054
Clear aftermarket from Autostyle
16080.jpgAlbum 16080 17089.jpgAlbum 17089
Clear Lense
Datsun 1000 clear lense - will it fit the 1200?
26121-27700 Lens [clear]
20759.jpgAlbum 20759 1850.jpgAlbum 1850 20379.jpgAlbum 20379 20381.jpgAlbum 20381
Custom
14605.jpgAlbum 14605 14930.jpgAlbum 14930 15474.jpgAlbum 15474 15803.jpgAlbum 15803 17152.jpgAlbum 17152 17552.jpgAlbum 17552
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ
