Andrew Denniss' 1972 Datsun 1200 Coupe was one of the early documented CA18DET builds -- and one of the finest.
Contents[hide] |
2005 May: first tune - 202 kw @ 20 psi
230 rear-wheel KW Coil pack Autronic ECU HKS GTRS turbo with 0.64 AR (Garrett GT2871R but with a 52Trim wheel) nitrided balanced crank ARP 2000 bolts MLS gaskets with ARP stud kit good for 25+ psi Sard fuel pressure regulator 800cc Sard injectors Tomei procams 260 8.8mm Tomei adjustable pulleys Gates timing belt Argo conrods
2002 DATA:
- Induction: 400HP GT25 Turbo, Microtech M8 Aftermarket ECU, Turbosmart boost controller, Custom front mount intercooler
- Head: Worked/ported DOHC 16-valve
- Transmission: Skyline stumpy 5 speed
- Differential: Mitsubishi scorpion : 4.6 for racing and 3.3 for speed events
- Brakes: Front 10" vented with hilux 4spot calipers, Rear 9" solid with standard Mitsubishi calipers
- Exhaust: Custom made exhaust manifold, Single 3" resonator into a 3" S type muffler then reduced into 2.5" mandrel bends over the diff to a 3" dump pipe
- Suspension: Front, 2.5" lowered 275lbs, 3" King Springs on imported stanza struts with adjustable height platforms running custom inserts. Standard swaybar, strut brace. Rear, reverse eye springs 3" lowered with Pedders sports gas shocks.
- Additional Info: The car has ran a 12.0@113mph, and since then the car has seen a massive increase of horsepower, in fact an estimate of close to 300 horses!
Zoom Magazine
Mighty Mouse in Zoom 31
See Main Article: Mighty Mouse
Another little daily driver that moonlights as a successful hillclimber and a sub-12 second dragster!
Body
120fly/Steve Draeme overfender flares
15x8 Performance#Superlite rear 225/50R15, 15x7 front 205/50R15
Side exhaust outlet (aft of the door)
Racing
EFI
Autronics ECU with filter on the MAP line
MSD CDI 4 channel ignition (good for 30 psi boost)
Gearbox
71C gearbox from S13 in 1200 manual tunnel
Cooling System
PWR Radiator and 300mm SPAL fan
PWR intercooler and engine oil cooler
CA18DET
120Y drag link has factory kink that drops it down ~25mm
Engine bay with 10mm firewall-to-engine clearance
Argo conrods. Stock rods (race-prepped) are good for around the 400hp mark as long as revs are kept under 8000
Interior
Front Suspension and Brakes
R32 front brakes require 15" rims
* R32 GTS-T 280x30mm discs (DBA4909SL) * Z32 300zx calipers (same as R32 GTR) * A10 Stanza struts
Rear Suspension and Brakes
* H190 alloy diff * Rear Disc Brakes * Adjustable shocks * LSD
H190 alloy center with 4.625 gearset, rear discs
Mitsubishi Scorpion 10" rear discs
Chassis Strengthening
It was showing signs of body stress with the alloy 6 point cage just holding it together.Rollcage
Now with the steel cage welded in I feel it should cope a bit better with the punishment of racing
