Side Lamps
Revision as of 02:12, 5 September 2018; view current revision
<-- Back to: Lighting System
Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibily (instead of turn signals) they are made larger to be more visible, and are fitted front and rear. USA B110 markers are approximately the same size as B210 worldwide markers.
[hide]
Variations
1200 #global
* long thin ORANGE lenses for turn signal (blinkers)
* front only
1200 #North America
* front and rear lamps/reflector
* Yellow front marker (non-flashing)
* Red rear reflector
* both are taller (more squarish)
Global
107 x 24 mm side lights are used as winker/blinker (indicator) lamp in worldwide (non-North America) markets, including Japan, Europe and Oceania.
'IKI 5002 JAPAN'
'B-110 45 TOKYO'
20764.jpgAlbum 20764 20763.jpgAlbum 20763 12063.jpgAlbum 12063
4099.jpgAlbum 4099 3812.jpgAlbum 3812 8456.jpgAlbum 8456 4457.jpgAlbum 4457
26160-H1001 LAMP ASS'Y-side flasher
26160-G1060 LAMP ASS'Y-side flasher 7804- TRUCK
* integrated two-wire harness (bulb 12V + earth/ground)
26161-H1001 LENS [marked 'IKI 5002 JAPAN]
26162-H1001 RIM
20765.jpgAlbum 20765
26164-H1001 PACKING
26164-G1060 PACKING 7804- TRUCK
01451-00071 SCREW
08964-10410 NUT-spring
26715-89900 BULB-6W
9516.jpgAlbum 9516 16407.jpgAlbum 16407
sla.jpg slb.jpg slc.jpg sld.jpg sle.jpg slf.jpg slg.jpg slg.jpg slh.jpg sli.jpg slj.jpg slk.jpg slm.jpg sln.jpg slo.jpg slp.jpg slq.jpg slr.jpg
North America
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged. Australia moved to the same-sized large lights with the 1974 120Y.
1479.jpgAlbum 1479
* 2-wire (12V + Ground) for side marker lamp (non-flashing)
* individual wires (one female bullet, one male bullet)
* right and left differ
* front and back differ
  * front has longer wires with a grommet
  * lenses amber FRONT, red REAR
* Both RH and LH lenses are marked IKI 5003 as well as IKI 7007
* Lenses marked SAE P169 and SAE A69
SAE PI69 and A69 are found on many cars and indicate meeting the 1969 standards.
COMMON [4 of each per vehicle]
* 26182-H1900 RIM
* 26715-89902 BULB 12V-8W (ICHIKHO)
* 08964-10410 NUT-SPRING (ICHIKHO) [8 per vehicle]
NOTE: The lamp packing wraps around the housing and thus acts as a gasket between body panel and housing and between housing and rim/lens.
SAE lighting standards codes (SAE J759)
174_5b4587336916a.jpgPost 488883
SAEPI69
SAE = Society of Automotive Engineers (SAE International)
P = Parking Lamps
I = Turn signal lamps
A = Reflex reflectors
69 = 1969
Although marked 'I' (Indicators/Turn Signals), these North America side lamps are only parking lamps (no indicators/blinkers).
ORANGE, FRONT
Orange/Amber front lamps are same coupe and sedan
20761.jpgAlbum 20761
* 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
* 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH (ICHIKHO)
* 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772-
* 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772-
* 26184-H1900 PACKING RH
* 26189-H1900 PACKING LH
* 26181-H1900 LENS, FRONT [amber]
* 01451-00041 SCREW (2 per lens)
front
740.jpgAlbum 740 10023.jpgAlbum 10023 1479.jpgAlbum 1479 3636.jpgAlbum 3636
Okinawa?
26794.jpgAlbum 26794
R and L lens is the same. They are marked 'TOP' on both edges so they can be turned over for correct bevel for the intended side (Lens is thicker at front edge matching the curvature of the fender).
IKI 5003 JAPAN SAE PI69 SAE A69 IKI 7007
174_5b45742bcc2dd.jpgPost 488880 174_5b4574580d799.jpgPost 488880 174_5b457473219b7.jpgPost 488880 174_5b457482c8950.jpgPost 488880 174_5b45749575cf7.jpgPost 488880
MADE IN JAPAN
174_5b45748b17d45.jpgPost 488880
RED, REAR
rear lamps sedan and coupe differ. Lenses are the same but the housing differs.
20760.jpgAlbum 20760
rear COMMON COUPE+SEDAN
* 26191-H1900 LENS, REAR [red] (2)
PLUS the common parts (bulb, chrome rim, and spring nuts)
Lenses are marked same as fronts IKI 5003/IKI 7007 but of course the color differs. ICHIKO (IKI) was the company that sourced these parts for Nissan.
rear COUPE
* 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
* 26195-H1910 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) COUPE
* 26194-H1910 PACKING RH(ICHIKHO) COUPE
* 26199-H1910 PACKING LH(ICHIKHO) COUPE
 * 01451-00061 SCREW(ICHIKHO) COUPE (2 per lens)
rear SEDAN
* 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
* 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) SEDAN
* 26194-H1900 PACKING RH(ICHIKHO) SEDAN
* 26199-H1900 PACKING LH(ICHIKHO) SEDAN
 * 01451-00041 SCREW SEDAN (2 per lens)
What's the difference between Coupe and Sedan rear side light? They look the same, but since the coupe uses longer screws, perhaps the lamp housing is thicker?
rear
10023.jpgAlbum 10023 143.jpgAlbum 143 4643.jpgAlbum 4643 4185.jpgAlbum 4185 5035.jpgAlbum 5035 6603.jpgAlbum 6603 1605.jpgAlbum 1605
174_5b4576bc55c2b.jpgPost 488881 174_5b4576c360f48.jpgPost 488881 174_5b457665bceb3.jpgPost 488881 174_5b45768174e63.jpgPost 488881 174_5b45768ba51f9.jpgPost 488881 174_5b4576a819cd9.jpgPost 488881 174_5b4576ea8cb1c.jpgPost 488881 174_5b4576e3ce84d.jpgPost 488881 174_5b4576afa50fc.jpgPost 488881
Bullet connectors (see Lamp Wiring)
174_5b4576d850c66.jpgPost 488881 174_5b4576f1e2e70.jpgPost 488881
Wiring connectors differ between early, late 1200s and differ for various countries. Early 1200 lamps use bullet connectors.
Only the 1200 lights interchange. However, USA 620 lenses interchange with USA 1200.
620
In USA, the 620 side marker lenses look identical. The front lamp assembly looks nearly the same as the 1200, except the packing (gasket) may be beveled (?) The rear uses a highly-angled lamp housing.
USA 620 vs 1200
* lens & rim interchange
* front housing may interchange
* rear housing does not interchange
1974_620_rear.jpg markers-c.jpg markers-a.jpg markers-d.jpg markers-b.jpg markers-e.jpg
SAME AS B110 USA
* 26181-H1900 LENS-SIDE MARKER LAMP, FRONT (2)
* 26191-H1900 LENS-SIDE MARKER LAMP, REAR (2)
* 26182-H1900 RIM-SIDE MARKER LAMP (4)
* 01451-00041 SCREW, FRONT LAMP (4)
* 08964-10410 NUT-SPRING, FRONT LAMP (4)
The rear lamp technically takes:
01451-00051 SCREW (4)
08966-30410 NUT-SPRING (4)
Pointed Lens
Pointed lens is used by B210 and 240Z and (late USA) 510. B110 is rectangular, compared to the slightly pointed rectangle type.
1200 North America
Pointed type
B210 side lamp is different from B110 lamp, and uses a different connector style
See Main Article: B210#Side_Lights
S30 240Z bullet wire connectors
S30 260Z/280Z rectangular connector
B210 (120Y)   rectangular connector
510 late
The USA late 510 units 1970-1972 uses the 240Z pointed lens, though the assembly differs somehow
S30
240Z has individual wires
260Z has the rectangular connector
Lamp assembly differs from B210 somehow
North America (Canada and USA) used amber front side lamp and red rear side reflector
IKI 5005 & 5004
26160-E4100 & 26165-E4100
26160-E4100
26190-E4600 & 26195-E4600
LENS 26161-E4100 IKI 5005
26161-E4100_IKI_5005_.jpg 26161-E4100_IKI_5005.jpg 26161-E4100_IKI_5005-.jpg
PB110
See Main Article: PB110#Side_Lights
Datsun 1000
See main article: Datsun 1000
B140
South Africa B140 bakkie from 1982-2004 used the global indicator. From 2005 used a unique small lamp.
From 2005-2008 used this small indicator:
26051.jpgAlbum 26051
26054.jpgAlbum 26054
Clear aftermarket from Autostyle
16080.jpgAlbum 16080 17089.jpgAlbum 17089
Clear Lense
Datsun 1000 clear lense - will it fit the 1200?
26121-27700 Lens [clear]
20759.jpgAlbum 20759 1850.jpgAlbum 1850 20379.jpgAlbum 20379 20381.jpgAlbum 20381
Custom
14605.jpgAlbum 14605 14930.jpgAlbum 14930 15474.jpgAlbum 15474 15803.jpgAlbum 15803 17152.jpgAlbum 17152 17552.jpgAlbum 17552
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ
