Hitachi D4A distributor debuted circa 1973 and features a larger cap than the D40/D41 used in Datsun 1200.
Starting with the A14 engines, the Hitachi D4A points-type distributor replaced the older D4n type (D40/D41). The D4A features a larger cap for improved spark isolation and resistance to crossfiring. The same body casting was later used for the D4F and D4K Electronic Ignition versions.
D4A superseded the early 1960s design Hitachi Distributors, and was used in the following:
- L-series engines
- A-series engines
It has the larger 75mm I.D. cap.
Larger cap -- less chance to crossfire (important in humid climates)
On the side of the distributor is the 10-digit Nissan part number which will positively identify the make, model and year of the distributor.
Maintenance Parts
Cap & Rotor
The Hitachi D4A cap & rotor also fits Hitachi D4F electronic ignition and Hitachi D4K electronic ignition. A-series, L-series and Z-series four-plug distributors use the same cap. Also fits Subaru, Honda and Isuzu with one of the above Hitachi types.
Cap
Part Number and aftermarket caps interchange, but differ by color, type of terminals (brass vs aluminum), cap finish material, presence or abscence of anti-tracking bosses inside, resistor type, vent/no vent, etc.
- Nissan 22162-19M01 CAP ASSY $36.48 USD
- superceded 22162-19M00, 22162-U6004, 22162-U6003, 22162-U6002, 22162-U6001
- Standard Motor Products JH-63X/JH-63T/JH-63
- Standard Motor Products JH-63/JH97 (aluminum terminals)
- Standard Motor Products JH-63X (Blue?)
- Standard Motor Products JH-63T/JH97T
- Bosch 03107 (resistor type) (or cap & rotor set: Bosch 06054) F2010-13140
- Bosch 1235999104
- Niehoff WA435CS
- Beck/Arnley 1743145/1746544
- BWD C561/C561P
- AC/Delco E386(12321929)/E374
- Mighty 6343
- Nissan 22162-AA020
- 30102657005
- JA918
- AirTex/Wells 5D1172
- Master Pro 2-4825
Fits Nissan:
- 1977-1979 with L20B
- 1980 200SX with Z20E
- 1974-1979 620 PICKUP
- 1979-1982 210
- 1974-1977 710
- 1979-1981 310
- 1980 720 PICKUP
- 1978-1980 510
- 1974-1978 B210
- 1974-1976 610
- 1976-1978 F10
Also Fits:
- Isuzu 1983 - 1986 IMPULSE
- Honda 1976 ACCORD
- Honda 1975 - 1976 CIVIC
- Subaru 1986 - 1987 GL
- Subaru 1986 - 1987 RX
- Subaru 1986 - 1987 GL-10
- Subaru 1986 - 1987 XT
Rotor
Nissan 22157-U6091 Rotor, Distributor $10.67 USD
Rotor is same as points ignition, 1974 up:
- Standard Motor Products JR-79X/JR-79/JR-79T
- Bosch 04095, F2020-13435, 1987234015
- Lucas DRJ102C
- Subaru 22157-AA030
Make | --- | Model | Year |
HONDA | --- | ACCORD | 1976 |
CIVIC | 1976-1975 | ||
NISSAN | --- | 200 SERIES | 1981-1977 |
210 | 1982-1979 | ||
260 SERIES | 1974 | ||
280 SERIES | 1978-1975 | ||
310 | 1982-1979 | ||
510 | 1980-1978 | ||
610 | 1977-1974 | ||
620 PICKUP | 1977-1974 | ||
710 | 1977-1974 | ||
810 | 1978-1977 | ||
B210 | 1978-1974 | ||
F10 | 1978-1976 | ||
PICKUP | 1980-1976 | ||
PULSAR | 1985-1984 | ||
PULSAR NX | 1986 | ||
SENTRA | 1986-1982 | ||
SUBARU | --- | SEDAN, COUPE, WAGON | 1985 |
XT | 1985 |
Daiichi F2020-18361
Model | Year Range | Engine | Chassis | Transmission |
Accord 1.6 | 1976 | EF1 | SJ_ | 5MT,HMT |
Civic 1.5 2 Door/3 Door | 1975-1976 | ED_ | SG_ | |
Civic 1.5 Wagon | 1975-1976 | ED_ | WB_ | 4MT,HMT |
B210 1.3 | 1973-1974 | A13 | B210 | |
B210 1.4 | 1974-1978 | A14 | B210 | |
F10 1.4 | 1976-1978 | A14 | F10 | |
Pulsar and NX 1.6 | 1983-1986 | E16 | N12 | 5MT,3AT |
620 Pickup | 1973-1974 | L18 | 620 | 4MT,3AT |
620 Pickup | 1974-1979 | L20B | 620 | |
720 Pickup | 1979-1980 | L20B | 720 | |
Sentra 1.5 | 1982-1983 | E15 | B11 | |
Sentra 1.6 | 1983-1986 | E16 | B11 | |
200SX 2.0 | 1976-1979 | L20B | S10 | |
200SX 2.0 | 1979-1980 | Z20E | S110 | |
210 1.2 | 1979-1982 | A12 | B310 | |
210 1.4 | 1978-1982 | A14 | B310 | |
210 1.5 | 1978-1982 | A15 | B310 | |
260Z 2.6 | 1973-1974 | L26 | S30 | |
280Z 2.8 | 1974-1978 | L28E | S30 | |
310 1.4 | 1978-1980 | A14 | N10 | |
310 OHV | 1980-1981 | A15 | N10 | |
310 SOHC | 1981-1982 | E15 | N10 | |
510 2.0 | 1977-1979 | L20B | A10 | |
510 2.0 | 1979-1980 | Z20S | A10 | |
610 2.0 | 1973-1976 | L20B | 610 | |
710 1.8 | 1973-1974 | L18 | 710 | |
710 2.0 | 1974-1977 | L20B | 710 | |
810 2.4 | 1976-1978 | L24E | 810 | |
4WD Turbo exc. Brat | 1983-1984 | EA81T | AM5,AW5 | 3AT |
Brat Turbo | 1983-1984 | EA81T | AT55B | 3AT |
Loyale Turbo 4WD | 1985 | EA82T | A10/A11 |
Points Set
Contact Points Kit includes breaker points & condensor. Always replace at the same time.
Nissan 22145-89900 Ignition Point $8.68 USD 22102-U6004 Ignition Condensor $5.53 USD
NOT THIS D4n TYPE
CONDENSOR Aftermarket @ Rockauto.com * twin male slide terminals Kemparts W185/W185X Standard Motor Products SMP JC45/JC45T/JC45X Intermotor JC57 Guaranteed Parts 215028/215028V Airtex/Wells 5H1049 * 12351555 * Nissan 22102N6000/22102N6001 * Nissan 22102-N6094 * Nissan 22102-U6001/22102-U6002/22102-U6003/22102-U6004 * 30108657005 * JA509 * Beck/Arnley 1722107
Breaker Point AFTERMARKET Rockauto.com Auto-Tune E780D Guaranteed Parts 205010/205010V Kemparts W82 Standard Motor Parts Jp6/JP6T Airtex/Wells 4P1067 Beck/Arnley 1710391 AC/Delco E116Z/E179
Airtex/Wells 4P1067 replaces: * 029024314, 12323732 * Nissan 22145-16515, 22145-18005, 22145-18006, 22145-71300/22145-71301 * Nissan 22145-89900/22145-89994/22145-U6001/22145-U6002 * Nissan 22146-32200 * 30105634005, 30105657005, 30105679015, 8513902, 88922542, 891464111 * 894164111, 94022297, 9823115180, D27Z12171B, JA1, MD602103, MD607394 * SOA505000, SOA525505
Intermotor/SMP JP6 replaces: * 029024314, 0293500370, 12301067, 12323732 * Nissan 22145-U6001, 22145-16515, 22145-18005/22145-18006, 2214571300/22145-71301 * Nissan 22145-89900/22145-89901/22145-89905/22145-89994/ 22145-U6001/22145-U6002 * Nissan 22145-71311, 22146-32200, 27135-11000, 27135-11000K * 30103551004, 30105590075, 30105634005, 301056340051, 30105657005, 50A525505 * 8513902, 891464111, 891464821, 94022297, 94030637, 9823115150, 9823115180 * CS75, CS77, CS84, D27Z12171B, D27Z12171C, DPE128, DPE217, DPE340, E116 * E116Z, E149, J8513902, MD602103, MD602665, MD607394, SOA505000
Sources
Japan B210
1973-1975 used D411/D412 distributor A12 VAN used D411 distributor
B210 1976-1977 DISTRIBUTOR ASSY HITACHI (alternative fitted with Mitsubishi T3T or T4T) 22100-H8301 D4A5-06 A12.SK,K 22100-H8307 A14.AT -7604 22100-H8308 A14.AT 7605- 22100-M2360 D4A5-08 A14-AT,V -7604 22100-M2361 A14-AT,V 7605- 22100-H7860 A14S.V might be D4n or D4A type L-series engine 22100-N7400 D4A5-10 L16.MT 22100-N7405 D4A5-11 L16.ATM
Japan B310
all except VAN 22100-H8500 A12.S,K -8010 22100-M7200 A13S+A15S.MT 8011- 22100-H9200 A14E, A15E 22100-H8905 A14S.AT -8010 22100-H8900 A14S.S,K-AT -8010
NORTH AMERICA B210
For A13 1974 22100-H6201 ASSY-DISTRIBUTOR HITACHI D4A02-02 $348.88 USD
For A14 1975-1978 22100-H7606 ASSY-DISTRIBUTOR (D4A7-03) A14 CAN(AUTO) 0877- 22100-H7601 ASSY-DISTRIBUTOR (D4A7-02) A14CAN(MANUAL) 0877- 22100-H7268 ASSY-DISTRIBUTOR (D4A6-05) A14 CAN(AUTO) 0876-0777 22100-H7263 ASSY-DISTRIBUTOR (D4A6-04) A14CAN(MANUAL) 0876-0777 22100-H7260 ASSY-DISTRIBUTOR (D4A5-13DS) A14FED(MANUAL) 0876-0777 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 CAN(AUTO) 0875-0776 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 FED(AUTO) 0875-0777 22100-H7205 ASSY-DISTRIBUTOR (D4A4-03) A14 FED(AUTO) -0775 22100-H7201 ASSY-DISTRIBUTOR (D4A5-04) A14FED(MANUAL) 0875-0776 22100-H7200 ASSY-DISTRIBUTOR (D4A4-02) A14FED(MANUAL) -0775
COMMON PARTS
These listings are cumulative.
22403-H7200 ASSY-TERMINAL 0877- 2 22403-U6001 * 22403-U6001 ASSY-TERMINAL -0777
22119-H5000 SET-PINION [drive gear with pin & washer] 22157-B8900 ROTOR-HEAD 0876- 0 22157-U6001 $16.14 USD 22157-U6091 ROTOR-distributor -0776 $10.67 USD * superceded 22157-U6001 ROTOR-HEAD -0776
22162-19M01 Cap Dist $36.48 USD * superseded 22162-U6001 ASSY-CAP 22165-30101 ASSY-CARBON POINT
22130-A5500 PACKING [sealing rotor shaft screw] 08360-61226 BOLT DIST TO BLOCK-HEX WITH WASHER M6 22180-71200 O RING-DIST.SUPPORT [O-ring for block] $5.67 USD
22108-M5600 SET-SHAFT 22182-M5600 ASSY-EARTH WIRE 22160-M5600 SET-THRUST WASHER 22750-M5600 SCREW KIT 22167-N6005 SET-CAP CLAMP (2) 0377- 22309-M5600 EARTH TERMINAL 0877-
22109-A5500 GOVERNOR WEIGHT (2)
D4A POINTS PARTS
22145-89900 SET-CONTACT 1075- 2 22145-U6002 * 22145-U6002 SET-CONTACT 0875-0975 2 22145-U6001 ** 22145-U6001 SET-CONTACT -0775
22102-U6003 CONDENSER 0877- 2 22102-U6002 * 22102-U6002 CONDENSER -0777
22136-M5600 ASSY-BREAKER PLATE $68.42 USD * superseded 22136-U6001 ASSY-BRAKER PLATE 1974
D4A for 1974
A13 0673-0874 1974 Model year. Also uses COMMON PARTS except as listed below.
22108-H6200 SET-SHAFT 22160-M0800 SET-WASHER THRUST $3.53 USD 22109-U6001 GOVERNOR-WEIGHT (2) 22110-H6200 SET-SPRING GOVERNOR 22132-H6200 SET-CAM 22182-U6001 ASSY-WIRE,EARTH $4.15 USD 22301-H6200 ASSY-VACUUM CONTROL $62.77 USD 22750-U6001 KIT-SCREW $5.53 USD
D4A POINTS TYPE
22110-H7601 SET-GOVERNOR SPRING A14CAN 0877- 22110-M5601 SET-GOVERNOR SPRING A14FED 0875-0777 22110-H7200 SET-GOVERNOR SPRING A14FED -0775
22132-H7601 SET-CAM 0877- 0 22132-M5600 22132-M5600 SET-CAM -0777
22301-M2361 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0877- 2 22301-H7201 22301-H7201 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0875-0777 22301-H7360 ASSY-VACUUM CONTROL A14FED(MANUAL) 0876- 22301-H7201 ASSY-VACUUM CONTROL A14FED(MANUAL) 0875-0776 22301-H7200 ASSY-VACUUM CONTROL A14FED(MANUAL) -0775 22301-H7205 ASSY-VACUUM CONTROL A14 FED(AUTO) 0974-0777
D4F EI TYPE
Electronic ignition distributor. Also uses COMMON PARTS except as listed below.
CAL from 0974 FED GFU from 1276 (FU Engine) FED ALL from 0877 CAN - NONE, points type only
22100-H7265 DISTRIBUTOR ASSY(D4F6-03) FED(AUTO) 0877- 22100-H7360 DISTRIBUTOR ASSY(D4F5-03) FED(MANUAL) 0877- 22100-H7680 DISTRIBUTOR-ASSY (D4F7-01) FED(GFU) 0877- 22100-H7280 DISTRIBUTOR-ASSY (D4F6-01) FED(GFU) 1276-0777 22100-H7365 ASSY-DISTRIBUTOR (D4F5-05) CAL(AUTO) 0876- 22100-H7306 ASSY-DISTRIBUTOR (D4F4-02) CAL(AUTO) -0776 22100-H7360 ASSY-DISTRIBUTOR (D4F5-03) CAL(MANUAL) 0876- 22100-H7302 ASSY-DISTRIBUTOR (D4F5-01) CAL(MANUAL) 0875-0776 22100-H7301 ASSY-DISTRIBUTOR (D4F4-01) CAL(MANUAL) -0775
22110-H7301 SET GOVERNOR SPRING FED 0877- 22110-H7780 SET-GOVERNOR SPRING FED(GFU) 0877- 22110-H7280 SET-GOVERNOR SPRING FED(GFU) 1276-0777 22110-H7300 SET-GOVERNOR SPRING CAL -0775 22110-H7301 SET-COVERNOR SPRING CAL 0875-
22132-H7280 ROTOR SHAFT-ASSY FED(GFU) 1276-0777 22132-H7780 ROTOR SHAFT-ASSY FED(GFU) 0877- 22132-H7300 ASSY-ROTOR SHAFT FED 0877- 22132-H7300 ASSY-ROTOR SHAFT CAL
22301-H7205 VACUUM CONTROL ASSY FED(AUTO) 0877- 22301-H7360 VACUUM CONTROL ASSY FED(MANUAL) 0877- 22301-H7680 VACUUM CONTROL-ASSY FED(GFU) 0877- 22301-H8300 VACUUM CONTROL-ASSY FED(GFU) 1276-0777 22301-H7200 ASSY-VACUUM CONTROL CAL(MANUAL) -0775 22301-H7201 ASSY-VACUUM CONTROL CAL(MANUAL) 0875-0776 22301-H7360 ASSY-VACUUM CONTROL CAL(MANUAL) 0876- 22301-H7205 ASSY-VACUUM CONTROL CAL(AUTO) -0776 22301-H7365 ASSY-VACUUM CONTROL CAL(AUTO) 0876-
EI PARTS 22115-H7300 SET-RELUCTOR 22136-N4200 ASSY-BRAKER PLATE $52.72 USD 22229-N4302 SET-PICK UP 2 22229-N4301 22229-N4301 SET-PICK UP 22145-N4200 CONTACTOR 22116-N4200 CAP-SETTER 01211-00111 NUT-FOR TERMINAL 01211-00121 NUT-FOR TERMINAL 01321-00051 WASHER-LOCK 01321-00041 WASHER-LOCK
22100-G2805 (Hitachi D4A81-01 1402)
