Oil cap
Revision as of 07:22, 14 June 2018; view current revision
Category: Engine Lubrication System
The stock Datsun 1200 Rocker cover uses a push-and-twist oil cap. It is a classic all-chrome cap and seals with a simple round gasket. Some other Datsuns use a threaded cap that will not work in a 1200. By the way, this is where you add oil to the engine.
[hide]
15092.jpgAlbum 15092
1204.jpgAlbum 1204
The timeless style of the 1200 cap looks good with customized engines
8125.jpgAlbum 8125 14133.jpgAlbum 14133
Custom
Machined aluminum version of original 1200 style oil cap
Buy at Bprojects: Billet Oil Filler Cap
25534.jpgAlbum 25534 25535.jpgAlbum 25535 20469.jpgAlbum 20469
Finish with Elephant applique
13080.jpgAlbum 13080 12859.jpgAlbum 12859 12988.jpgAlbum 12988 12989.jpgAlbum 12989
Color Caps from Bprojects
20471.jpgAlbum 20471 20470.jpgAlbum 20470
B110
15255-B3430 CAP-OIL FILLER 1 A12 - 15255-15953 $12.12
15255-15953 CAP-OIL FILLER 1 A12 - superceded
15270-B3400 PACKING-OIL FILLER CAP 1 A12 - 2 15270-11200 $1.40
15270-11200 PACKING-OIL FILLER CAP 1 A12 - superceded
2-3/4" Oil Filler Cap (1-13/32" x 1-19/64" Cam Twist) RockAuto.com
15255-B3430 Cap-oil Filler $12.35
* replaced 15255-15953 CAP-oil
* NOT BECK/ARNLEY Part # 0160048 screw-in cap (fits L-series)
* STANT Part # 10102
* GATES Part # 31088
Datsun 1000
B10 Datsun 1000 uses a vented oil cap, so it doesn't work with the 1200 (Datsun 1200 caps are sealed).
15099.jpgAlbum 15099
Datsun B10 Elephant Cap was used in some markets.
6547.jpgAlbum 6547 12872.jpgAlbum 12872
Nissan
Late Model Nissan replacement caps differ from the original style but work on all 1200 engines.
20649.jpgAlbum 20649
15255-B3430 is like the B110 cap but with writing applied
16410.jpgAlbum 16410 16411.jpgAlbum 16411
ニッサン モーター オイルを (For Nissan Motor Oil)
NISSAN
MOTOR OIL
注入して下さい (Fill Occasionally)
80s Nissan stamped-steel cap
25773.jpgAlbum 25773 12966.jpgAlbum 12966
The 80s cap was eventually replaced with a stylish sculpted version
15091.jpgAlbum 15091
15694.jpgAlbum 15694
15255-G8250 - latest version drops the text in favor of an international oil symbol
15090.jpgAlbum 15090 16713.jpgAlbum 16713
24442.jpgAlbum 24442 24443.jpgAlbum 24443 b82600578power_planning-img600x4-1.jpg b82600578power_planning-img600x4-2.jpg b82600578power_planning-img600x450-.jpg
