Fuel Pump Blank
Revision as of 08:29, 21 September 2021; view current revision
Category: Fuel System
For use with Electric Fuel Pump. Instead of leaving the stock mechanical Fuel Pump in place, it may be removed and the blanking-plate fitted. Also known as a delete plate, cover plate, block off plate or fuel+plate1200.
12705.jpgAlbum 12705
Nissan
Nissan fitted a blank-off plate to the A14/A15 fuel injected engines in Japan. The same plate was used in most countries for other Nissan engines.
find online 16420-E0100
Nissan 16420-E0100 COVER-FUEL PUMP HOLE $16.10 USD NLA
* 08915-13810 WASHER, spring lock medium M8 (2)
* 08120-81210 BOLT M8x12 (2)
* 17099-21002 GASKET-FUEL PUMP
* Fits A-series, L-series 4-cylinder, E-series, Z-series engines
When fitting the cover plate, unscrew the fuel pump studs from the block, then use two bolts to fasten the cover to the block.
174_614288ce2b51a.jpgUpload click to view
174_6143249ed2fd2.pngPost 495862
This diagram from the Parts Catalog appears to be in error. 1) The washer part number does not exist. 2) It shows M6 parts, however the studs for the fuel pump are M8 parts.
Right side of engine (from Introduction of Sunny GX-E)
Wrecking Yard
If sourcing from a wrecking yard, look for these EFI vehicles:
  • 1979-1982 Nissan B310 SGX-E/GX-E (Japan market)
  • 1979-1983 Nissan S110 200SX with Z20E/Z22E
  • 1980-1986 Nissan 720 Pickup with Z22
  • 1987-1989 Nissan N12 Pulsar NX XE with E16
  • 1987-1989 Nissan B12 Sentra with E16I
Datskool110
Show plates by POST Datskool110
Bluehands
info at Ratsun fuel pump block off plate
Bluehands Basic
174_61427b848d5cb.jpgPost 495858
Bluehands Premium
CAD file
