Door Cards
Revision as of 00:18, 1 May 2022; view current revision
Categories: Fibreglass | Interior
<-- back to Doors
Door cards (door interior trim panels) — which Nissan calls "door finishers" — for Datsun 1200 were available in different styles.
Datsun 1200 door panels
Door cards (or an American English, door panels) are the interior door covering. Sometimes called the door lining. Not to be confused with the door sheet metal.
Coupe door panels will fit on a 2dr sedan with some very minor mods. The panel may sit a bit higher than the original panel but basically it's just a matter of enlarging the window winder hole. Oh, and it's harder to fit but it works.
Early Truck door cards are the same as 4-dr sedan.
The factory visqueen protects the door cards from moisture. The original door panels are made out of fiberboard, the doors have polyethylene sheet applied with sealer before the door cards are fitted.
The black bead of rubber sealant is similar to RTV but stickier, thicker and never gets hard. Automotive grade.
174_56bdb0c634397.jpgPost 476263 174_56bdb1e3c84b7.jpgPost 476263
Details
Coupe
5039.jpgAlbum 5039
Coupe 1972
2-dr sedan
7569.jpgAlbum 7569
4-door Rear
3836.jpgAlbum 3836
Ute Early (1971-1978)
8812.jpgAlbum 8812
Ute Mid-model (1978-1989) Brown
Ute Late-model (1989-)
Gray
Do not confuse with B210 door cards, such as this early KB210 | late B211 Sedan
Patterns
See also: Upholstery
ドアトリム
STD/DX
GL/GX
#Sedan/Van/Truck simple ribbed design, shorter than door
7569.jpgAlbum 7569
#Sedan 1972 facelift swoosh design
7273.jpgAlbum 7273
#Coupe chrome enclosure
5039.jpgAlbum 5039
#Coupe 1972 facelift spear design
26319.jpgAlbum 26319
#PB110 sedan Sunny Excellent embossed crest
#PB110 coupe Sunny Excellent GL/GX double sweep with kicking plate
Australia local content (sedans) wide ribbed with single chrome
2517.jpgAlbum 2517
South Africa 1970s wide-ribbed with dual chrome strips
8353.jpgAlbum 8353
South Africa B140 1990s
174_589c2ca2e79c8.jpgPost 483812
South Africa B140 2000s
069c_20.jpgseats
Removal & Installation
28404.jpgAlbum 28404
To remove the door card:
  1. Coupe: unscrew the door lock pull knob
  2. using a table knife or putty knife, slip between card and door until a clip is located. then gently pull clip out of door
clip locations (sedan/van/truck front door)
28402.jpgAlbum 28402
coupe extra clip
CLIPS
3/door front door sedan/wagon/ute
4/door coupe
28403.jpgAlbum 28403
To install:
  1. re-align/center the #clips on the back of this finisher panel
  2. insert panel into door
    • Coupe: place card over top of door (centered over the lock pull), then push down
    • Sedan: fit card into upper channel
  3. flex card into bottom channel
  4. preliminarily line up clips with holes (get the clips started into the caps)
  5. gently — with the palm of your hand — pushing panel over each clip. Push fully into the clip cap receptables
Coupe
Coupe finishers cover the entire door (sedan finishers do not cover the top of the door)
5039.jpgAlbum 5039
FINISHER ASS'Y-door
80900 RH
80901 LH
JAPAN & North America
80900-H1800 RH BLACK #1742
80900-H1801 RH YELLOW 黄 (DX for JAPAN)
North American 1973 flame resistant
80900-H7101 RH BEIGE,LH-20 COUPE 0772-
80900-H7102 RH BLACK,LG-13 COUPE 0173-
80900-H7100 RH BLUE COUPE 0772-
26641.jpgAlbum 26641 26642.jpgAlbum 26642
Body Side Finisher
76900-H1800 DX/GL Black
76900-H1801 DX/GL Yellow
Yellow
174_5a5c496a6e47b.jpgPost 487255
Coupe 1973
1973 North America (Fire-resistant material)
76900-H7000 BLUE 0772-
76900-H7001 BEIGE,LH-20 0772-
76900-H7002 BLACK,LG-13 0173-
12908.jpgAlbum 12908 Beige 1973
174_50f6242ed52c4.jpgPost 427649
Blue 1973
174_5c88de21e113b.jpgPost 490864 174_5c88de2d427bd.jpgPost 490864
Coupe PB110
Datsun PB110 Sunny Excellent 1400
Coupe DX
* Same as B110 above (choice of black or yellow)
  PB110 Colors#Interior
80900-H2600 RH BLACK PB110
80900-H2601 RH BROWN PB110 GX
80900-H2602 RH BLUE PB110 GL
Coupe 1972
80900-H4000 Black
89000-H4001 Yellow
Facelift finishers have a swoosh design
0570589A30151217W00411.jpg 1972.jpgAlbum 1972 0570589A30151217W00406.jpg 0570589A30151217W00402.jpg
GX5 uses the same as all coupes
26320.jpgAlbum 26320
Body Side Finisher
76900-H4000 Black
76900-H4001 DX Yellow
Sedan
4-door
80900-H1000 STD black 5-rib style
80900-H1100 DX/GL/GX black chrome insert
80900-H1101 DX yellow
DX/GL/GX with chrome accent insert
26322.jpgAlbum 26322
STD
11972.jpgAlbum 11972
STD
26321.jpgAlbum 26321
dattoparts018.jpgAlbum click to view dattoparts019.jpgAlbum click to view dattoparts020.jpgAlbum click to view dattoparts021.jpgAlbum click to view
Rear Door Finisher
82900-H1000 STD Black
82900-H1100 DX/GL/GX Black
82900-H1101 DX Yellow
DX
15944.jpgAlbum 15944
GL
13933_sedan.jpgAlbum click to view
rear door
11179.jpgAlbum 11179
Sedan 2-door
FINISHER ASS'Y-door
80900 RH
80901 LH
7569.jpgAlbum 7569
2-door
80900-H1200 STD black
80900-H1300 DX/GL black Japan
80900-H1301 DX yellow (USA: 1270-)
80900-H1900 DX black North America
Body Side Finisher
76900-H1200 STD Black #1742
76900-H1300 DX/GL Black
76900-H1301 DX/GL Yellow
Sedan 2-door 1973
80900-H7000 BLUE,LB-211 0772-
80900-H7001 BEIGE,LH-20 0772-
80900-H7002 BLACK,LG-13 0173-
80900-H1900 2-door North America
1915.jpgAlbum 1915
1973 North America
76900-H7000 BLUE,LB-211 0772-
Blue 1973 sedan
174_5778af7409278.jpgPost 479638
Body Side Finisher 76901-H1300 DX/GL, Black
20100.jpgAlbum 20100
Rear Side card has a distinctive upward sweep
Sedan PB110
Kicking Plate on bottom of door
80911-H2900 Sedan PB110
Sedan DX
* Same as B110 DX above (choice of black or yellow)
GL/GX
80900-H2900 RH BLACK PB110
80900-H2901 RH BROWN PB110 GX
80900-H2902 RH BLUE PB110 GL
Sedan 1972
4-door
80900-H3100 1972 STD black
80900-H3200 1972 DX black
80900-H3201 1972 DX yellow
2-door
80900-H3600 1972 STD black
80900-H3700 1972 DX black
80900-H3701 1972 DX yellow
Facelift Black STD
7273.jpgAlbum click to view
Truck
Sunny Truck door finishers came in two patterns:
  • 1971 sedan STD simple 5-rib pattern
  • 1972-1994 sedan facelift spear pattern
FINISHER ASS'Y-door
80900-H1000     -7111 BLACK same as early sedan
80900-H3100 7112-7803 BLACK same as 1972 sedan
80900-G1060 7804-7907 DARK BROWN
80900-G1660 7908-8104 BROWN
80900-G1901 8105-8910 BROWN
80900-95W00 9810-     GRAY
1971 Black
8812.jpgAlbum 8812
Dec 1971 - Apr 1978: Facelift Black
7273.jpgAlbum 7273
7804-7907 DARK BROWN spear pattern
7908-8104 BROWN sweep pattern
8105-8109 BROWN
8110-8910 BROWN with pocket (driver's side only)
dc1.jpg dc2.jpg 28404.jpgAlbum 28404
Oct 1989- Gray
1990_door_cards.jpg 19045.jpgAlbum 19045
1972-1978 Black facelift
26387.jpgAlbum 26387
1982-1989 Brown
0803323A30151121W00318.jpg 8805_interior.jpg 28405.jpgAlbum 28405 28406.jpgAlbum 28406 28407.jpgAlbum 28407
1989-1994 Grey, driver
1989-1994 Grey, assistant
Door Pocket
25605.jpgAlbum 25605 25606.jpgAlbum 25606
80801 POCKET-DOOR
80912-G1900 BROWN RH 8110-8910
80912-95W00 GRAY RH 8910-
ドア ポケット
Van
Wagon used the same front door cards as sedan. In the used the Sedan Standard card, except for Deluxe van which used a specific finisher panel.
DOOR FINISHER
H10 Van-Standard, Van-P
H11 Van Deluxe
H15 Van Deluxe Rear Door
Additionally, interior finishing panels were used in the rear cargo area.
H14 back door (tailgate)
H14 trunk side trim
Tailgate finisher 90903-H1400
20290.jpgAlbum 20290 20291.jpgAlbum 20291
trunk side trim 84911-H1400 RH
20289.jpgAlbum 20289 20292.jpgAlbum 20292
trunk side trim 84912-H1400 LH goes here
20293.jpgAlbum 20293
Van 1972
For the 1972 JDM Facelift, the door cards were updated.
H31 Front & Rear Door Standard, P
H32 Front Door Deluxe black
H36 2-door Van (new model for 1972)
H44 Front Door Deluxe green
H4400 Rear Door Deluxe black
H4401 Rear Door Deluxe green
H45 Front Body Side Trim 2-door Van
Rear trunk side & tailgate finishers remained the same as 1971.
Clips
Clips to hold the finishers in place and tubules to fit into the door sheet metal.
80919-89900 CLIP-door finisher
80929-32200 CAP-door finisher clip
28090.jpgAlbum 28090
These B310 plastic units can be used when the fibreboard is too torn to work with the metal clips
4929.jpgAlbum 4929
Custom
Roll-cage simulating interior door panel. Color matched.
25708.jpgAlbum 25708 25709.jpgAlbum 25709 25710.jpgAlbum 25710
door trims
22308.jpgAlbum 22308 6024.jpgAlbum 6024
Artistic
Lightning
18647.jpgAlbum 18647 18648.jpgAlbum 18648 18649.jpgAlbum 18649 18650.jpgAlbum 18650
10653.jpgAlbum 10653 12630.jpgAlbum 12630
Fibreglass
See also: Speakers
Bprojects carbon fibre
12756.jpgAlbum 12756
120fly fiberglass door cards
7390.jpgAlbum 7390 7327.jpgAlbum 7327 7317.jpgAlbum 7317 7315.jpgAlbum 7315 7287.jpgAlbum 7287 7286.jpgAlbum 7286 7272.jpgAlbum 7272 7271.jpgAlbum 7271
8801.jpgAlbum 8801 8802.jpgAlbum 8802 9148.jpgAlbum 9148
ドア フィニッシャー
