The carburetor mixes air with gasoline in the proper ratio for all conditions. 14.7 to 1 by weight is the chemically correct ratio, but engines can work with 8:1 (very rich) to 22:1 (lean burn). For best power, it's about 12:1, but for best economy is is about 18:1. The stock Hitachi carburetor (when in good condition, i.e. not worn out) does an excellent job of providing superb economy but providing a rich power on demand. The Hitachi keeps within the appropriate range for all throttle openings, temperature and loads. No dyno tuning is necessary. Since it works on airflow, not engine size, the Datsun 1200 Hitachi works acceptably on engines from A10 to A15 without changing the jets. As the airflow changes, the carburetor meters the fuel accordingly. Changing the jets is necessary for fine tuning. If engine modifications (or if major modifications to the induction system are made such as a high-overlap camshaft), then jet tuning is a must.
Also See
GENERAL * Category:Fuel System for master article index * Carburetor Overview basic information
TUNE-UP/ADJUSTMENTS * Tune-up * Choke Operation and Adjustment * Float Level Adjustment
REPAIRS * Carburettor Diagnosis troubleshooting * Carburetor Adjustment testing & repair procedures * Carburetor Repair Rebuild kit * Carburetor Specifications stock jetting & settings info * Carburetor Parts * Fume Control * Vacuum Leaks
JET RE-TUNING * Carburetor Tuning * Jets & air bleeds for part Hitachi
AFTERMARKET CARBURETORS and SWAPS * Choosing A Carburetor * Carburetor Sizing * Carburetor Suppliers * Hitachi DCH340 * Weber DGV "32/36" * Weber DGAS carburetor "38/38"
SIDEDRAUGHTS * Weber DCOE carburetor * Dellorto DHLA carburetors * Mikuni PHH carburetors * Hitachi Twin Carb factory Datsun setup
DCG286
DCG286: 28 mm secondary bore/26mm primary bore - A10 engine
16010-18000 DCG286-1? B10 16010-18001 DCG286-1A B10 16010-18002 DCG286-2 B10 from E#/A10-27321 16010-18003 DCG286-2A 16010-18004 DCG286-3A B10 from E#/A10-211302 16010-18005 DCG286-3AK B10 ISO 16010-18006 DCG286-3B B10 16010-25701 DCG286-9 KB10 16010-25702 DCG286-9C KB10 16010-25704 DCG286-9CK KB10 ISO 16010-25705 DCG286-9D KB10 16010-20300 DCG286-7? B10 16010-20301 DCG286-8 B10 16010-20302 DCG286-8K B10 ISO 16010-20303 DCG286-8A B10 16010-25721 KB10A 16010-25703 KB10A 16010-H0100 NIKKI 210248-011 B10 16010-M0101 DCG286-4A E10 16010-M0102 DCG286-4B E10 (from '70-11) 16010-M0103 DCG286-4C E10 (from '71-6) 16010-M0104 DCG286-4D E10 (from '71-9) 16010-M0900 DCG286-6 E10 16010-M0901 DCG286-6 E10 (from '70-11) 16010-M0902 DCG286-6B E10 (from '71-9)
Has large round top which the air cleaner clamps to
DCG306
DCG306 for A12 (manual choke). All Hitachi DCG306 have barrel sizes of 26/30 mm.
1974 B120 Parts Catalog C-288 16010-H1001 DCG306-1A 16010-H1002 DCG306-1B (from 1970-11) 16010-H1003 DCG306-1C (from 1971-7) 16010-H1004 DCG306-1D (from 1971-9) 16010-H5000 DCG306-7 (from 1973-3)* 16010-H5001 DCG306-2 B210 A12 16010-H5002 DCG306-7A B120.A12 (from 1973-8) 16010-H5003 DCG306-2A B210.A12 (from 1973-8)
* DCG306-7 debut of Anti-diesel Valve
16010-M1500 DCG306-6 E10 16010-M1501 DCG306-6A E10 (from '71-9)
Timeline
B110 sedan/coupe/van 1970-1976 DCG306 manual choke 1972 USA DCH306 Auto-choke 1973 USA DCH306 Auto-choke w/anti-diesel
B120 truck/ute/pickup 1971-1975 DCG306 manual choke 7510-7803 16010-H7802 DCH306 auto-choke w/anti-diesel also capped idle screw begins 7804-7907 16010-G1660 7908-8109 16010-G1615 8110-8503 16010-G2600 removable sight glass (see DCR306) 8504-8910 16010-G1900 8910- 16010-95W00 DFC306 ECU carb
Nikki
In Taiwan and Malaysia Nikki carburetors were reportedly used on A12 engine. Nikkis are famous for use on bigger Datsuns like the 510.
