<-- back to Steering Column
The steering column shell finishes the steering column, covering the turn signal switch and provides a mounting surface for the Hazards switch.
NOTE:
- 32 mm diameter steering column
- 26.5 mm diameter steering column
The covers encloses the hazards switch and the turn signal switch. It does not cover the steering lock and key lock.
48470-H1010 COVER SET-STEERING COLUMN [cut for 25.6 mm diameter shaft]
JDM
* 48471-H1150 SET-SHELL,steering 3-speed * 48471-H1170 SET-SHELL,steering 4-speed * 85-10412-12 SCREW (4)
* 48471-H1950 SET-SHELL STEERING WITHOUT PARK LIGHT S 1 4 SPEED - 48471-H1650 superceded ** 48471-H1650 SET-SHELL STEERING 1 4 SPEED AUTO. - superceded ** 48470-H4650 SET-SHELL STEERING WITHOUT PARK LIGHT S 1 EXC OKINAWA 0172- 48471-H1950 $23.68 * 08530-42012 SCREW-TAPPING M4 3 [Tapping screw, Oval head] * 08330-41410 SCREW-MACHINE M4 1 [Machine screw, Oval head]
B120
Early (Black) * 48470-G1150 COVER SET-STEERING COLUMN [Black] 7510-7803 * 48477-C0400 PLATE-CAUTION
Facelift (Dark Brown) * 48472-G1160 COVER STEERING COLUMN DARK BROWN LOWER 7804-8910 * 48471-G1160 COVER STEERING COLUMN DARK BROWN UPPER W/LABEL 7804-8608 * 48471-G1900 COVER STEERING COLUMN DARK BROWN UPPER 8608-8910 * 48474-G1270 PLUG-SHIFT LEVER 8608-8910 * 96920-89900 PLATE-CAUTION 8110-8306 * 96920-89910 PLATE-CAUTION 8307-8910
Late Model (Gray) * 48471-95W00 COVER-STEERING COLUMN GRAY UPPER 8910- * 48472-95W00 COVER-STEERING COLUMN GRAY LOWER 8910- * 48470-H1015 COVER SET-STEERING COLUMN * 48474-95W00 PLUG-SHIFT LEVER 8910- * 48477-C0400 [99072] PLATE-CAUTION 8910-
Hardware * 08540-41212 [54=Tapping Screw, truss head 04 mm diameter,12mm length] 10mm diameter head * 08530-42012 [53=Tapping Screw, oval head 04 mm diameter,20mm length] 8mm diameter head
NOTE: It seems the Nissan Catalog has the last two reversed. You need three of the 20mm oval head and one of the 12mm truss head. The 12mm fixes the Cover to the Column. The other three hold the two halves together.
