<-- back to Sedan badges
Grille #Center Ornament and #Grille Left Side Badge (trim badge)
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Early grille center badge 62312-H1626 ('D') and 62312-H1026 ('S')
- 1970-1973 Sedan & Van (wagon)
- 1971-1978 Truck (ute)
1972 Center Ornament
62312-H3125 ORNAMENT KIT-radiator grille [1972 JDM intricate "S" emblem]
Paint color: some look Red, some Yellow, some in-between, but all have the 62312-H3100 cast number.
It is a plastic casting. This one has all the chrome finish worn off
08915-43410 WASHER-plain M4 08915-13410 WASHER-lock M4 08911-10410 NUT M4
fitted to Sedan facelift grille
62330-H2325 Early GX
GX early (1970-1971) COUPE, SEDAN grille badge
Compare to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX flat badge
This modern GX badge has no pins. It has a design like the early GX front trim badge (with the same black background) but is designed for stick-on applications so won't easily fit the 1200 sedan or coupe grilles. Has sticky tape on the flat back of the emblem.
62330-H2026 Early GL
62330-H2026 EMBLEM-'GL' (1970-1971). Used by #sedan and coupe
background-color: blue, but the paint has usually disappeared after 30 to 50 years in the weather
bolt-on type (rear GL badge looks similar, but is the push-in type)
62330-H3125 1972 Deluxe
NOTE: 1970-1971 DX did not come with a trim badge on the grille
EMBLEM SET-radiator grille "DELUXE" [1972]
compare to rear badge 84823-H1000
62330-H3425 1972 GX
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX" SEDAN, COUPE
Grille 'GX' has long bolts and a bracket, in order bolt it to the grill. The similar rear 'GX' badge has short pins.
Late badge has narrow font (approximately 71mm wide)
compare to early 1970-1971 'GX' expanded font grille emblem
compare to rear see-through badge (short pins) and ~100mm wide
Long bolts for the grille badge
#Early GL and Late GX
62330-H3325 1972 GL
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe)
compare to EARLY rectangular GL badge #62330-H2026
factory placement on 1972 sedan grille
placement on Coupe Grille
Grille badge has long studs for mounting through the grille with cast mark "62330-H3300"
Backing plate is either simple flat or the stronger ridged type
original white paint | with paint faded away
62330-H7225 GX 5 SPEED
The 1972-only GX5 came with this badge, used on both sedan and coupe
