Engine mounting xmember x-member cross-member
Also see: Engine Mounts (for rubber insulators and engine brackets)
Front Crossmember
Rear: Late 1200 crossmember
Front: Early 1200 crossmember
The engine crossmember for the Datsun 1200 fits the 1971-1973 A12 engine. The A10 engine from the earlier Datsun 1000 will also bolt in. To fit a newer engine -- a 1974-up A12 or A13, A14 or A15, a newer crossmember may be used (or an adaptation of motor mounts may be fabricated). The newer crossmember is from the 1974-up Datsun 1200 truck. Note that B210 or other crossmembers do not fit the 1200.
For engine types other than A-series, see: Engine Swaps
Early A12 ute vs. Late A12 ute
Suitable for 1974-up A12, A13, A14 or A15
B210 vs B110
B210 is slighty wider, and of course has late style mounts.
フロント サスペンシヨン メンバー
B110 & early B120
- 54401-H3900 MEMBER ASS'Y-front suspension
- 08194-06510 BOLT (4)
- 32886-22000 WASHER-body bolt (8)
- 08915-14010 WASHER-lock (4)
- 08911-54010 NUT (4)
- 54401-H1000 [early part, interchangable with -H3900]
- 81-94065-1 BOLT (4)
- 89-15140-1 WASHER-lock (4)
- 89-11540-1 NUT (4)
Late B120
- 54401-G1601 MEMBER ASSY-FRONT SUSPENSION 8504-
- replaced 54401-G1600 MEMBER ASSY-FRONT SUSPENSION 7510-8503
Measurements
Front engine crossmember bolts
- 11 mm holes
- 8 mm forward of strut centerline
- 60 mm front-to-rear spacing
- 656 mm left-to-right
- 405 mm from rear bolt to Front core support mounting hole
Strut Tower to Strut Tower centers
- 936 mm width
Rear Crossmember
See main article: Gearbox Mount
The transmission crossmember (gearbox crossmember) is also called the rear engine crossmember.
- 11322-H1002 MEMBER-engine mounting, rear
