Starting with the A14 engines, the Hitachi D4A points-type distributor replaced the older D4n type (D40/D41). The D4A features a larger cap for improved spark isolation and resistance to crossfiring. The same body casting was later used for the D4F and D4K Electronic Ignition versions.
Models
These listings are cumulative.
NORTH AMERICA B210
COMMON PARTS
22403-H7200 ASSY-TERMINAL 0877- 2 22403-U6001 * 22403-U6001 ASSY-TERMINAL -0777
22119-H5000 SET-PINION [drive gear with pin & washer] 22157-B8900 ROTOR-HEAD 0876- 0 22157-U6001 $16.14 USD 22157-U6091 ROTOR-distributor -0776 $10.67 USD * superceded 22157-U6001 ROTOR-HEAD -0776
22162-19M01 Cap Dist $36.48 USD * superseded 22162-U6001 ASSY-CAP 22165-30101 ASSY-CARBON POINT
22130-A5500 PACKING [sealing rotor shaft screw] 08360-61226 BOLT DIST TO BLOCK-HEX WITH WASHER M6 22180-71200 O RING-DIST.SUPPORT [O-ring for block] $5.67 USD
22108-M5600 SET-SHAFT 22182-M5600 ASSY-EARTH WIRE 22160-M5600 SET-THRUST WASHER 22750-M5600 SCREW KIT 22167-N6005 SET-CAP CLAMP (2) 0377- 22309-M5600 EARTH TERMINAL 0877-
22109-A5500 GOVERNOR WEIGHT (2)
D4A POINTS PARTS
22145-89900 SET-CONTACT 1075- 2 22145-U6002 * 22145-U6002 SET-CONTACT 0875-0975 2 22145-U6001 ** 22145-U6001 SET-CONTACT -0775
22102-U6003 CONDENSER 0877- 2 22102-U6002 * 22102-U6002 CONDENSER -0777
22136-M5600 ASSY-BREAKER PLATE $68.42 USD * superseded 22136-U6001 ASSY-BRAKER PLATE 1974
D4A for 1974
A13 0673-0874 1974 Model year. Also uses COMMON PARTS except as listed below.
22100-H6201 ASSY-DISTRIBUTOR HITACHI D4A02-02 $348.88 USD 22108-H6200 SET-SHAFT 22160-M0800 SET-WASHER THRUST $3.53 USD 22109-U6001 GOVERNOR-WEIGHT (2) 22110-H6200 SET-SPRING GOVERNOR 22132-H6200 SET-CAM 22182-U6001 ASSY-WIRE,EARTH $4.15 USD 22301-H6200 ASSY-VACUUM CONTROL $62.77 USD 22750-U6001 KIT-SCREW $5.53 USD
D4A POINTS TYPE
For A14 1975-1978
22100-H7606 ASSY-DISTRIBUTOR (D4A7-03) A14 CAN(AUTO) 0877- 22100-H7601 ASSY-DISTRIBUTOR (D4A7-02) A14CAN(MANUAL) 0877- 22100-H7268 ASSY-DISTRIBUTOR (D4A6-05) A14 CAN(AUTO) 0876-0777 22100-H7263 ASSY-DISTRIBUTOR (D4A6-04) A14CAN(MANUAL) 0876-0777 22100-H7260 ASSY-DISTRIBUTOR (D4A5-13DS) A14FED(MANUAL) 0876-0777 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 CAN(AUTO) 0875-0776 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 FED(AUTO) 0875-0777 22100-H7205 ASSY-DISTRIBUTOR (D4A4-03) A14 FED(AUTO) -0775 22100-H7201 ASSY-DISTRIBUTOR (D4A5-04) A14FED(MANUAL) 0875-0776 22100-H7200 ASSY-DISTRIBUTOR (D4A4-02) A14FED(MANUAL) -0775
22110-H7601 SET-GOVERNOR SPRING A14CAN 0877- 22110-M5601 SET-GOVERNOR SPRING A14FED 0875-0777 22110-H7200 SET-GOVERNOR SPRING A14FED -0775
22132-H7601 SET-CAM 0877- 0 22132-M5600 22132-M5600 SET-CAM -0777
22301-M2361 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0877- 2 22301-H7201 22301-H7201 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0875-0777 22301-H7360 ASSY-VACUUM CONTROL A14FED(MANUAL) 0876- 22301-H7201 ASSY-VACUUM CONTROL A14FED(MANUAL) 0875-0776 22301-H7200 ASSY-VACUUM CONTROL A14FED(MANUAL) -0775 22301-H7205 ASSY-VACUUM CONTROL A14 FED(AUTO) 0974-0777
D4F EI TYPE
Electronic ignition distributor. Also uses COMMON PARTS except as listed below.
CAL from 0974 FED GFU from 1276 (FU Engine) FED ALL from 0877 CAN - NONE, points type only
22100-H7265 DISTRIBUTOR ASSY(D4F6-03) FED(AUTO) 0877- 22100-H7360 DISTRIBUTOR ASSY(D4F5-03) FED(MANUAL) 0877- 22100-H7680 DISTRIBUTOR-ASSY (D4F7-01) FED(GFU) 0877- 22100-H7280 DISTRIBUTOR-ASSY (D4F6-01) FED(GFU) 1276-0777 22100-H7365 ASSY-DISTRIBUTOR (D4F5-05) CAL(AUTO) 0876- 22100-H7306 ASSY-DISTRIBUTOR (D4F4-02) CAL(AUTO) -0776 22100-H7360 ASSY-DISTRIBUTOR (D4F5-03) CAL(MANUAL) 0876- 22100-H7302 ASSY-DISTRIBUTOR (D4F5-01) CAL(MANUAL) 0875-0776 22100-H7301 ASSY-DISTRIBUTOR (D4F4-01) CAL(MANUAL) -0775
22110-H7301 SET GOVERNOR SPRING FED 0877- 22110-H7780 SET-GOVERNOR SPRING FED(GFU) 0877- 22110-H7280 SET-GOVERNOR SPRING FED(GFU) 1276-0777 22110-H7300 SET-GOVERNOR SPRING CAL -0775 22110-H7301 SET-COVERNOR SPRING CAL 0875-
22132-H7280 ROTOR SHAFT-ASSY FED(GFU) 1276-0777 22132-H7780 ROTOR SHAFT-ASSY FED(GFU) 0877- 22132-H7300 ASSY-ROTOR SHAFT FED 0877- 22132-H7300 ASSY-ROTOR SHAFT CAL
22301-H7205 VACUUM CONTROL ASSY FED(AUTO) 0877- 22301-H7360 VACUUM CONTROL ASSY FED(MANUAL) 0877- 22301-H7680 VACUUM CONTROL-ASSY FED(GFU) 0877- 22301-H8300 VACUUM CONTROL-ASSY FED(GFU) 1276-0777 22301-H7200 ASSY-VACUUM CONTROL CAL(MANUAL) -0775 22301-H7201 ASSY-VACUUM CONTROL CAL(MANUAL) 0875-0776 22301-H7360 ASSY-VACUUM CONTROL CAL(MANUAL) 0876- 22301-H7205 ASSY-VACUUM CONTROL CAL(AUTO) -0776 22301-H7365 ASSY-VACUUM CONTROL CAL(AUTO) 0876-
EI PARTS 22115-H7300 SET-RELUCTOR 22136-N4200 ASSY-BRAKER PLATE $52.72 USD 22229-N4302 SET-PICK UP 2 22229-N4301 22229-N4301 SET-PICK UP 22145-N4200 CONTACTOR 22116-N4200 CAP-SETTER 01211-00111 NUT-FOR TERMINAL 01211-00121 NUT-FOR TERMINAL 01321-00051 WASHER-LOCK 01321-00041 WASHER-LOCK
