The Rocker Cover covers the top of the Cylinder Head including the Rocker arms and valvesprings. The rocker cover is painted Datsun Blue, which is a darker blue than the air cleaner. The rocker cover is also known as a valve cover or tappet cover.
Also see: Oil cap
B10 (A10 engine): Black 'Datsun' label on top
Datsun 1200 A12: Embossed 'Datsun', single threaded boss on right side for fuel rail
B210 A14: No threaded bosses on side (fuel rail does not bolt to rocker cover)
B310: Embossed 'Nissan'
Factory EFI - Gold Top for A14E and A15E EGI engines
GX Cover
For the twin-carb 1200GX Engine#Rocker Cover:
- fuel-rail mounting brackets are in different place
- choke cable bracket is in different place
Breather
See: PCV System
Also see: Oil cap
B110
13264-H1000 ASSY-COVER VALVE ROCKER 1 A12 - NLA 13264-H7000 ASSY-COVER,VALVE ROCKER 1 A12 0772- 0 13264-H1000 NLA 08915-13610 WASHER-LOCK FIXING ROCKER COVER 6 A12 - $1.06 08360-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12 - 08310-61612 $0.65 08310-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12 - superceded 13270-18001 PACKING-ROCKER COVER 1 A12 - NLA
Customizing
Polishing
Chrome Plated
Painting
Alloy Covers
Aluminum light-alloy covers were never shipped on a Datsun 1200, but newer engine covers and aftermarket covers are available.
Nissan Pulsar OEM cover
Armbrust
Nippon Armbrust
Tomei
Tomei 1300
Tomei (plain)
Morris Minor World
http://datsun1200.com/modules/myalbum/photos/thumbs/6307.jpe http://datsun1200.com/modules/myalbum/photos/thumbs/6308.jpe
CP Products
CP70511, wrinkle black finish
http://www.revheads.com.au/performance_engine.html
Others
GASKET-ROCKER COVER
- 13270-18000, 13270-18001 B10, B110, B210 to '74-5
- BECK/ARNLEY Part # 0360669
- FEL-PRO Part # VS26049R RockAuto.com
- 13270-H1000 B210 from '74-6, B310 all
- 13270-H1010 B310 [select use?]
COVER ASS'Y-valve rocker
- 13264-18001 B10
- 13264-18002 B10 from engine A10-173620
- 13264-18003 B10
- 13264-H0100 B10
- 13264-H1000 'Datsun' B110 exc. GX
- 13264-H2300 B110 GX
- 13264-H7800 'Datsun' B120 7510-7907
- 13264-W8501 'Nissan' B120 7908-8910
- 13264-95W00 'Nissan' B120 8910-
- 13264-H5001 'Datsun' B210 A12S
- 13264-H5702 B210 A12T
- 13264-H7200 B210 A14S Van
- 13264-H7800 B210 Van
- 13264-H8200 B210 A12S Sedan, Coupe
- 13264-H8400 B210 A14T
- 13264-H7800 B310 Van to 7909
- 13264-W8501 B310 Van from 7910
- 13264-H8500 B310 A12S, A14S Sedan, Coupe
- 13264-H9200 B310 A14E to 7909
- 13264-H9201 B310 A14E 7910-8010, A15E 8011-
- 13264-G3400 B310 A13S, A15S 8011-
B310 USA
13264-H7201 B310 A12A USA -0780 13264-H9500 B310 A12A USA 0880- 13264-H7201 A14 FED (KFU), A14 CAN 13264-H7260 A14,A15 FED (EXC KFU) A14,A15 CAL 13264-H9500 A14,A15 USA 0880- 13264-H7260
USA RAW LIST
B110 13264-H1000 ASSY-COVER VALVE ROCKER A12 13264-H7000 ASSY-COVER,VALVE ROCKER A12 0772- 0 13264-H1000 08915-13610 WASHER-LOCK FIXING ROCKER COVER 6 A12 08360-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12 08310-61612 08310-61612 SCREW-MACHINE FIXING ROCKER COVER 6 A12
タペット カバー
