Some manual transmissions were fitted with an electrical Neutral Switch to signal when the gearbox is not in gear. All Automatic Transmissions are fitted with a an Inhibitor Switch which also signals when the automatic is in Neutral.
Neutral Switch was first used in 1973 USA models.
Neutral Switch was used for:
* EGR (some years e.g. 1990 1200, 1975 B210) * Fuel Shut-Off System on B310 * Starter interlock on automatic cars * Throttle Opener used the Inhibitor Switch to detect neutral * TCVAS spark control used the Top Switch to detect neutral
Neutral Switch is near top of 4-speed 56-Series Transmission
Reverse Switch is on bottom
Top Switch
Top Switch detects 4th gear AND neutral:
Also See: * Inhibitor Switch for automatics * 63-Series_Transmission#Switches
32130, 32006
32005-21101 SWITCH ASSY-REVERSE LAMP 32006-G6200 NEUTRAL POSITION SWITCH
NOTE: Sometimes misspelled as 'Nuetral Switch'
