Nismo N10 Catalog
Revision as of 23:01, 27 July 2015; view current revision
Categories: Nismo | Racing
The Nissan/Datsun Sports Option Parts, Model YN10, HN10 Series publication No. EC-058 is dated August 20, 1982. This article includes parts from the catalog that apply or can be used with Datsun 1200. N10-specific parts are not listed here. Datsun Model N10 was a front wheel drive car marketed as "Pular", "Cherry" or "310". For model years 1978-1982. HN10 indicates A14 engine, while N10 indicates A12A engine. FIA Group No. 1 recognitions 5763, 5767, 5815 are granted.
Engine Tune Up Parts
A12A
Primary specs: 1270 cc; Secondary specs: 1298 cc. Two types of specification are available for use on the basic A12A engine. One type is the primary specifications for a cylinder bore diameter of 0.1 mm oversize (76ø x 70) and the other is the secondary specifications for a cylinder bore diameter of 1.8 mm oversize (76.8ø x 70). Use of the former specifications make it possible to provide engine power of more than 145 PS; use of the latter makes it possible to provide power of more than 150 PS.
  • 11041-H5720 HEAD ASSY-cylinder (w/o valve inserts & guides)
  • 11044-M0821 GASKET-cyl head t=0.8, d=79ø [t(std.)=1.2]
  • 12010-M0820 PISTON SET-W/Pin (Pin dia.: 17.4ø) d=76ø (w/three piston rings) Forging parts
  • 12032-M0820 CLIP-Piston (Total piston displacement: 1,270 cc... Primary specs.)
A14
Primary specs: 1397 cc; Secondary specs: 1428 cc. Two types of specification are available for use on the basic A14 engine. One type is the primary specifications for a cylinder bore diameter of standard size (76ø x 77) and the other is the secondary specifications for a cylinder bore diameter of 0.8 mm oversize (76.8ø x 70). Use of the former specifications make it possible to provide engine power of more than 150 PS; use of the latter makes it possible to provide power of more than 155 PS.
Engine Mounting Parts
  • 11415-A1200 BUFFER ASSY-Eng A LH
  • 11405-A1200 BUFFER ASSY-Eng A RH
Carburetor Parts
Primary spec: Solex 44 PHH; Secondary spec: Solex 40 PHH.
Use of a Solex PHH carburetor increases intake efficiency, resulting in higher output. The proper carburetor setting is dependent on engine tuneup conditions.
Solex 40PHH
  • 1 16010-H2310 CARBURETOR SET-Twin SOLEX 40PHH IV (BIJET type)
    • Main jet #120, Air jet #180, Pilot jet #50, Starter jet #120, Outer venturi 33ø, Inner venturi 10.5ø Air funnel 40ø x 25 mm.
  • 2 16174-M0820 INSULATOR-Carburetor (4 needed)
  • 3 16176-H2310 GASKET-Insulator Carb (8 needed)
  • 4 14002-H2310 MANIFOLD ASSY-Intake
    • 16362-25720 BUSH-Throttle Shaft (2 needed)
  • 5 14035-H2310 GASKET-Manifold
  • 6 16360-H2310 LINKAGE KIT-Throttle
  • 7 18200-M7001 WIRE ASSY-Acc, same as standard part
  • 8 14330-M0820 PLATE-Heat Shield Carb (2 needed)
Solex 44PHH
Exhaust Parts
The exhaust manifold has a dual design which features low resistance to exhaust gases. Exhaust tubes are not performed [sic] and may be fabricated as desired for installation.
  • 1 14060-M0820 MANIFOLD ASSY-Exhaust
  • 2 20711-21001 GASKET-Exhaust
Electric Parts
Primary Specification
The distributor features revised advance angle characteristics to increase durability during high speed operation and high tension cables have copper core conductors to strengthen spark ignition.
1 17010-A7600 PUMP ASSY-Fuel Electric
* 2 16404-29900 ELEMENT-Fuel Pump
* 3 17103-A0220 CONNECTOR-Elbow Fuel (2 needed)
* 4 16420-E0100 COVER-Fuel Pump
* 5 22100-M0819 DISTRIBUTOR ASSY
** 6 22145-27720 POINT SET-Contact, same as std. part
* 7 22433-U3110 COIL ASSY-Ignition,  same as std. part
* 8 22460-14615 RESISTER ASSY
9 Use V plugs selectively
* 22401-N3120 PLUG-Spark BP7EV
* 22401-N3121 PLUG-Spark BP8EV (T4097A)
* 22401-N3122 PLUG-Spark BP9EV (T4097B)
* 22401-N3123 PLUG-Spark BP10EV (T4097C)
10 Copper core cables
* 22450-M0810 CABLE ASSY-Coil to Dis, l=720
* 22453-25720 CABLE ASSY-High Tension No. 1, l=300
* 22452-25720 CABLE ASSY-High Tension No. 2, l=250
* 22451-25720 CABLE ASSY-High Tension No. 3, l=190
* 22454-25720 CABLE ASSY-High Tension No. 4, l=390
High tension cables Nos. 1 and 3 should be interchanged as shown in the table above so that they can be used on the E10 model.
Full Transistor Kit
See main article: 22020-A0211
Secondary specification: This ignition unit is fully transistorized to accomodate high speed engine performance and features stabilized spark performance over all speed ranges. The tachometer, which is designed for the 6-cylinder engine, requires some modifications to match the 6-cylinder engine. Use the same fuel pump, spark plugs, high tension cables as those designated as the primary specification parts.
  • 1 22100-M0820 DISTRIBUTOR ASSY
  • Standard parts for Z432 unit
    • 2 22433-A0211 COIL ASSY-Ignition
    • 3 22020-A0211 UNIT-Transistor Ignition
    • 4 22460-A0212 RESISTOR ASSY-Transistor
      • 22460-A0213 RESISTOR ASSY-Transistor
  • 5 24855-E4200 TACHOMETE ASSY (For 6-cylinder engine) Modify to acommodate 4-cylinder engine
CD Ignitor Kit
Third specification: A CD ignitor kit is available for use to accomodate the trend toward further high-speed engine performance. It features stabilized spark performance over the entire speed range. Use the same fuel pump, spark plugs, high tension cables as those designated as the primary specification parts.
  • 2 22433-M0820 COIL ASSY-Ignition
  • 3 22020-M0820 UNIT-CD Ignition W/Harness
  • 4 24855-M0820 TACHOMETER ASSY
  • 5 24120-M0820 WIRE ASSY-Distributor No longer manufactured. Fabricate this part yourself.
Oil Cooler Parts
This engine oil cooler is designed to prevent any excessive temperature rise of engine oil during continued high-speed operation in a race. Since its component parts are the same as those used in the B310 model, the oil pump, cooler hose, engine mounting braket, etc. require some modification for use in N10 model.
  • 1 21305-H2310 COOLER ASSY-Eng Oil SIZE 220 x 278 x 40, Heat radiating area: 1.95 m²
  • 2 21355-H2310 HOSE ASSY-Flexible (Fabricate connector yourself)
  • 3 21356-H2310 HOSE ASSY-Flexible
  • 4 15010-25720 PUMP ASSY-Eng Oil (w/o element) Min. discharge flow: 30l/min.
    • 5 15025-25720 GASKET-Oil Pump t = 0.10 (blue)
    • 5 15025-25721 GASKET-Oil Pump t = 0.10 (yellow)
    • 5 15025-25720 GASKET-Oil Pump t = 0.14 (green)
    • 6 15242-25720 CONNECTOR-Elbow M20 x 1.5
    • 7 15242-25720 CONNECTOR-Straight M20 x 1.5
  • 8 15208-H8911 ELEMENT ASSY-Oil Filter Same as std. part
Oil Catch Tank Parts
  • 1 11125-K0475 TANK KIT-Oil Catch Capacity 2l, Resin
  • 2 11136-H2310 TANK ASSY-Breather Return
  • 3 11131-H2310 HOSE-Breather l=1,000, 9ø (ID), 22ø (OD)ø
  • 4 11132-H2310 HOSE-Breather l=1,000, 9ø (ID), 27ø (OD)ø
  • 5 11133-H2310 HOSE-Breather l=1,500, 25.4ø (ID), 34ø (OD)ø
Road Wheel Parts
  • 40300-M2221 ROAD WHEEL-FR 9J x 13 (Taper) Aluminum, Offset 10 [4 spoke minilight type]
  • 40300-M2220 ROAD WHEEL-RR 8J x 13 (Taper) Aluminum, Offset 10
  • 40222-A0220 BOLT-hub M12 x 1.25 x 50
  • 40224-R1120 NUT-Road Wheel (Taper) Zinc-plated
  • 40224-E7210 NUT-Road Wheel (Taper) Chrome-plated cap nut
  • 40209-A0220 SPACER-Road Wheel Aluminum, t = 5
Brakes
  • 41060-H1020 PAD ASSY-Brake FR DS11 AN18 caliper for Long distance driving
  • 41060-H1021 PAD ASSY-Brake FR M59S AN18 caliper for Short-medium distance driving
  • 44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4
  • 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4
  • 44100-M7000 CYL ASSY-Wheel 5/8" N10 standard
  • 44100-M4901 CYL ASSY-Wheel 11/16" Selective Use
  • 44100-G2800 CYL ASSY-Wheel 1/4" Selective Use
  • 44100-U9200 CYL ASSY-Wheel 13/16" Selective Use
ETC Parts
  • 21400-M7305 RADIATOR ASSY Std. part on HN10E model
  • 1 28455-H1075 TACHOMETER ASSY Max Indication: 10,000 rpm
  • 2 24880-14675 GAUGE-Oil Temperature Max. Indication: 150° C
  • 3 25071-12976 GAUGE-Oil Pressure Max. Indication: 10 kg/cm²
  • 4 25072-A9950 HOSE-Oil Pressure l = 2,000
  • 5 25080-12976 GAUGE-Water Temperature Max. Indication: 110° C
  • 6 25150-E8700 SWITCH ASSY-Ign & Starter
  • 7 25400-N3120 SWITCH ASSY-Cut Off
  • 8 25371-A7600 LABEL-Cut Off Switch [Triangular]
  • 9 25371-N3121 LABEL-Cut Off Switch [Round]
  • 10 26360-H1075 BLADE-Windshield Wiper l=400
  • 11 63882-H5275 MUD FLAP SIZE 300 x 210, t = 4 ['DATSUN']
    • 63824-27720 HANGER-Mud Flap 4 needed
    • 63826-27720 PLATE-Mud Flap 4 needed
  • 12 87000-U0175 SEAT ASSY-Driver Bucket Seat (Modify rails to use)
  • 13 96100-A1220 SAFETY BAR KIT (w/genuine NISSAN Mark) 4-door sedan, Hatchback, 4-point type (Not directly adaptable to coupe and requires modifications if used in coupe)
