Swapping a wikipedia:Nissan CA engine into a Datsun 1200 is perhaps the most common swap. It provides abundant horsepower (up to 400 hp) in a small, lightweight package. The CA18DE is a dual overhead cam engine, while the CA18DET if a factory turbo engine. It will fit into the 1200 without cutting the firewall or body. You will additionally need a stronger rear axle assembly to cope with the extra torque that the CA-series puts out. On the down side, quote: "It does unbalance the car...lets not try to lie to ourselves."
For information on choosing a rear axle, see Rear Axle Swaps.
Cost
Good used CA engines cost $400+ USD
Front-cut cost $1500-$2500 USD
Entire package with CA18DET and intercooler, fitted by a professional shop cost $20,000 AUD
See:
CA16DE DOHC (Only available in FWD format)![]()
CA18E SOHC (Single Overhead Cam)
CA18ET SOHC Turbo![]()
CA18DE DOHC
CA18DET DOHC Turbo![]()
CA20E SOHC * See main article: CA20![]()
2-valve vs 4-valve
4-valve: * CA16DE * CA18DE * CA18DET
2-valve * CA16S * CA16I * CA18S (Single carb) * CA18I (single point EFI) * CA18P (LPG) * CA18E (EGI/port injection) * CA18ET * CA20S * CA20E * CA20ET
CA20 and CA18 SOHC
CA18S/CA18E, CA18ET, and CA20S/CA20E are 2-valves per cylinder (8 valve head), so not as complicated as the DE models. However a CA20E with stock rods will suffice for 300 HP if not taken beyond 6500rpm with 12psi. CA20 have around 9:1 compression. The USA CAs have better made-in-Japan casted alloy heads; the made-in-Australia castings are reportedly not as good. Also CA20 twin sparks are so economical for a 2 liter they really are underrated -- the CA20-powered Stanza got 43 mpg with NAPS-X.
Inexpensive factory Mitsubishi 4G63 conrods are easy to mod and fit for 300-450hp.
11041-D0202 HEAD ASSY-CYLINDER * GC22.CA20S, C22.CA20 * C32.CA18I * C33.CA18I * M10.(CA18S+CA20S) * R30.CA18S * R31.CA18S * R32.CA18I * S12.CA18S * T11.CA18
GC22 JAPAN TRANSISTOR IGNITION UNIT 22020-D0210 MITSUBISHI * E24.Z20/WE24.Z20 * C22/GC22.CA20 * U12.CA16S * 910.CA18 * M10.CA18S * R30.CA18 * R31.CA18S * S12.CA18 * T11/T12.CA16S * U11.CA16+CA18S/CA18E 22020-V5400 HITACHI <> 22020-V5401 Hitachi D4N
CAP ASSY-DISTRIBUTOR 22612-D0110 <> 22162-D0113 MITSUBISHI * GC22.CA20S 8605- 22162-D3302 <> 22162-D3303 HITACHI * GC22.CA20S 8605-8906
8-Plug Distributor Cap interchange CA16/CA18/CA20 SOHC Bosch 03183 Standard Motor Products JH186 * 22162-03E00/22162-03E01 * 22162-11C00/22162-11C01 * 22162-21R00 * 22162-D0200/22162-D2200/22162-D2201/22162-D2202 * 22162-11001 * 22162-21800 * 22162-D3300/22162-D3302/22162-D3303/22162-D3304 * 22162-D3501/22162-D3502
4-valve CA20
It is possible to put a DE/DET head on a on CA20. See http://club-s12.org/v3/index.php?topic=23985.0
269 HP 85.55 mm cast pistons stock CA20 rods, shot-peened drill out the head bolt holes, re-tap for the larger CA18DE bolts Turbo: Lancer EVO III TD05H-16G timing belt: extensive mods
8-port
USA and JDM CA16DE/CA18DE/CA18DET uses 8-port heads:
click
There are two kinds of these heads:
click
4-port
Global right-hand drive market (Europe and Australia) use siamesed intake port (4-port) heads:
Inlet Butterflies
The butterflies are important for torque below 4500rpms:
- If you are running after market ECU, and not programming the butterfly function in, then you may as well remove them.
- If you are running a light flywheel and are only interested in power between 5000-8000rpm, then pulling out the butterflies is a good idea.
Carburetors
Donor Vehicles
CA16
B12 CA16D B12L CA16D KN13 CA16D N13 CA16D N13P CA16D 910 CA16S T11 CA16S T12 CA16S T12Y CA16S U11 CA16S U12 CA16S
CA18DE
S13 CA18D T12 CA18D T12Y CA18D U12 CA18D
CA18DET
RS13 180SX 8903-9812 CA18DT 9803-9101 S12 SILVIA 8308-8805 CA18DT 8602-8805 S13 SILVIA 8805-9310 CA18DT 8805-9101 T12 AUSTER 8510-8911 CA18DT 8510- T12Y STANZA 8608-8911 CA18DT 8608- U11 BLUEBIRD 8310-9005 CA18DT 8508- U12 BLUEBIRD 8709-9108 CA18DT -8910
CA18 SOHC
910 CA18E R30 CA18E S12 CA18E T11 CA18E U11 CA18E C33 CA18I R32 CA18I T12 CA18I T12Y CA18I U12 CA18I C32 CA18P 910 CA18S C31 CA18S C32 CA18S M10 CA18S R30 CA18S R31 CA18S S12 CA18S T11 CA18S U11 CA18S
CA18 SOHC Turbo
GC22 CA18T S12 CA18T T12 CA18T T12Y CA18T U11 CA18T
CA20
C22 8509-9403 CA20S Vanette GC22 8605-9303 CA20S Vanette Largo M10 Prairie 8208-8809 CA20S M11 Prairie 8809-9811 CA20S U11 Bluebird 8310-9005 CA20S
North America
Vehicles
- 1982-1986 T11 Stanza CA20S, CA20E
- 1985-1989 T12 Stanza CA20E
- 1985-1988 M10 Stanza Wagon CA20E
- 1984-1988 S12 Nissan 200SX SE CA20E 104 hp
- 1984-1986 S12 200SX XE CA18ET 116 hp
- 1987-1988 S12 200SX XE CA18ET Canada
- 1986-1987 KN13 Nissan Pulsar NX SE CA16DE 113 hp
- 1988-1989 KN13 Nissan Pulsar NX SE CA18DE 125 hp
Engines
- CA16DE - 1986-1987 KN13 Nissan Pulsar NX SE
- CA18DE - 1988-1989 KN13 Nissan Pulsar NX SE
- CA18ET - 1984-1988 S12 200SX
- CA20S - 1982-1986 T11 Stanza
- CA20E
- 1984-1988 Nissan 200SX XE
T11 Stanza 43mpg USA (FWD)
- NAPS-X dual-plug engine (TwinSpark/Eight Plug)
- CA20S (carbureted) 2-valve dual-plug
- CA20E EFI 2-valve dual-plug
T11 Stanza USA (FWD & 4WD)
- CA20E EFI 2-valve dual-plug (8 spark plugs)
M10 Stanza USA (FWD)
S12 USA 200SX SOHC 8-valve, Twin Plug
- FS5W71B transmission 5-speed 1083-0186 (31.5" length)
- FS5W71C transmission 5-speed 0186- (33.9" length)
- CA20E (Coupe & Hatchback)
- 102 hp @ 5200 rpm, 116 ft.lb. @ 3200 rpm
- CA18ET (Hatchback 3-dr only)
- 120 hp @ 5200 rpm, 134 ft.lb. @ 3200 rpm
KN13 Nissan Pulsar NX SE - DOHC
- 1986-1987 CA16DE (FWD) 16-valve, single plug
- 1988-1989 CA18DE (FWD) 16-valve, single plug
CA16DE retro-fitted with carburetors
Intake Gasket
- 14035-D5710 GASKET-MANIFOLD
- 14035-D5711 GASKET-MANIFOLD [JDM/USA 8-port CA16DE/CA18DE/CA18DET]
- 14035-D5720 GASKET-MANIFOLD [Europe 4-port siamesed ports, CA18DE/CA18DET]
Choose a Transmission
- CA16 uses a smaller clutch & gearbox. E16 & GA16 use a different bell, but same transmission series
- CA18 & CA20 use a factory adapter plate & larger transmission
NOTE: RWD & FWD engine blocks are the same.
You can use the typical CA18 gearbox, but it is longer than a Datsun 1200 gearbox, so the shifter comes up about 4 inches aft of normal.
feral: The CA18DE and DET's use 71B boxes. Very late DET's in S12's use the 71C box same as SR20's. Box type is easily identifiable from the number cast into the casing.The main difference between 71B and 71C that has implications for front casing swaps is the bearing diameters and shift rail diameters.
In the 71C boxes the front bearings are bigger and the rails are larger as well.
Stumpy Transmission
Plus: fits stock shifter hole and uses stock 1200 driveshaft (automatic driveshaft)
You can modify an L-series "stumpy" gearbox to fit the CA series front case. Then it bolts right in, shifter in the stock location for a 1200, and stock 1200 automatic driveshaft works too.
See main article Stumpy
Minus: The stumpy uses the same cluster as the 280Z 5spd, and while those are known for their durability, they don't shift as nicely and don't shift easilty above 5,000 RPM.
S13 Silvia/180SX Transmission
- Manual tunnel needs pretty much all of tunnel replaced from 120Y, or 1200 Automatic tunnel.
- Most will need a box section cut into the shifter area to clear the shifter area on the gearbox.
910 5-Speed
Series 3 Bluebird (910) CA20E/CA20 5 Speed - This is a straight fit, and for low power applications this is a cheap alternative. Especially if you can find a low milage example.
Gearbox crossmembers
All gearbox options for the CA will need you to fabricate (or get someone to fabricate) a new gearbox crossmember to attach the gearbox to the floor of your car. In the case of a stumpy 5 speed just a piece of 40mm box steel will do the job. Bolt it to the rubber mount of the stumpy and then bolt it to the floor - add some spacers as required. Here a pic of a crossmember I made. (It only gets wider at the edges as I had some existing holes in the floor of the Datto I wanted to use.)
Engine Fitting
Any motor mount that is made for the KA24DE motor can be used on the CA18DET. If using the Nismo mounts your motor may sit slightly higher than stock but it will fit.
Flywheel
CA18/CA18DET uses a 6-bolt crankshaft. CA20 uses an 8-bolt crankshaft
Engine Plate
rear engine plate or adapter plate
11251 PLATE-ENGINE,REAR 30411-W4401 MT <> 30411-W4403 * 910 8210-8310 * C31 8210-8412 * C32 8410-8412 * R30 8210-8412 * S12 8308-8412
30411-V5500 MT * S13/RS13 * C22 8509-9106 * GC22 8605- * C32 8412- * C33 * R30 8412- * R31 * R32 * S12 8412-
Crossmember
Will 1200 crossmember modified for L-series work with CA18?
1200 crossmember modified for CA:
click
Mad Dat Kit
Maddat CA crossmember for 1200
Product No - FKCA1200 CA18/1200 Fitting Kit
Engine xmember has new platforms fitted & engine rubber mounts supplied. Gearbox xmember is a universal design that can be used with CA, R30 stumpy or Gazelle gearbox. For utes use the Stumpy R30 box with CA bellhousing fitted. For all fitments the standard gearbox mounts in the trans tunnel need to be removed and minor clearancing around the bellhousing is required. We recommend the fitment of our custom trans tunnel when doing this conversion, it allows much easier removal of the gearbox from under the car.
Fuel Line, Pumps and Tank
Use high flow rated Bosch EFI pumps, Walbro pumps (watch out for the Ebay fakes).
See main article: EFI Wiring
ca18de/det wiring info & discussion
Alternator
Ignitor
Transistor Ignition Unit S13 JDM 22020-50F00 SR20DET <> 22020-50F01 22020-53J20 SR20DE 22020-85W00 CA18DE, CA18DET <> 22020-85W10 <> 22020-85M10 22020-85M10 * JHG50/G50 VH45DE * RS13 CA18DET * G50 VH45DE * T12/T12Y CA18DET * KN13 CA18DE/CA16DE USA
Preparing the Engine before Installation
For a second hand CA18det, these are some pre-install activities:
- Get engine block water/oil galleries cleaned out professionally.
- Get radiator professionally cleaned and pressure tested.
- Remove MAFM and clean the hotwire on the Mass Air Flow Meter. Use carby cleaner and cotton bud.
- Make sure MAFM is not clogged with oil from sitting upside down in a container.
- Remove and clean out the idle control unit on side of plenum. Use Carby Cleaner.
- Remove and clean the cold idle valve underneath throttlebody. Use Carby Cleaner
- Remove and clean the CAM covers, soak them in Kero for 30-60mins to clean out the oil strainers.
- Remove/Clean and reseal the cam cover rubber seals.
- Check head bolt torque settings.
- Remove and clean the Throttle body. Use Carby cleaner. Make sure that the shaft bearings aren't worn.
- Clean out intake side crank breathers. They can be full of crystalline carbon crap, causing high rev oil retention in head.
- Timing belt tensioner bearings. Can be ordered from Nissan (expensive) or can press the bearings out of holders and order bearings from Bearing supplier using the numbers on bearing oil seal. Then repress the bearings into the Nissan holders.
- Front Camshaft lip seals ($15 for both), Half moon seals at back of cam covers ($20 for both).
- Breather hoses on intake side can go hard and split, causing oil leaks. If they are hard, try to replace them with silicon hose, or landcruiser heater hose (but be prepared to replace them every 2 years).
- Check water hoses used to heat plenum on front and back of plenum. Remove them if in above zero deg C climate.
- Be sure to install the plenum rear plate gasket with the locating hole oriented to the top of the plenum. It will start leaking within a couple of days if the hole is on the bottom.
- Check compression on all 4 cylinders (fuel/ignition disabled), should be within 10psi, and all over 170psi.
- If one cylinder has less compression, remove plug, add a tablespoon of oil, and recheck, if it goes up, it's rings. Otherwise headgasket or scored bore.
- Try to use factory waterpump, some aftermarket ones aren't real good. Mine had it's pulley/fan holes drilled off centre.
- Always use Nissan thermostat. Cheap ones (Ryco) from K-mart aren't good enough.
- Buy NGK platinums from Nissan at $18-20 each. They are fine up to 20 PSI boost, unless you have a bad tune which melts them...
Piping/Hose Connections
See: * What goes where? * The CA18DE & DET Q&A Thread[/url
Upgrading the CA engine
Injectors
Injector changes almost certain require a tune change, which needs either an aftermarket ECU, or a chip to be modified/burned and inserted into a modified factory ECU.
General recommendations for high powered CA18s require 440cc to 700c injectors to be used.
Stock injectors are yellow top OR green top (330cc vs 370 cc ???)
See Injectors
Turbo Choice
Sensible Street -> T28G, GT28 (s15 jdm), GT2810 -> GT2835. Drag Racing -> GT2840, Various large T3, HKS, Trust or GReddy offerrings.
Camshafts
Tomei offer: Hydraulic -> 256 deg to 270 deg duration at a nominal lift of 8.8mm Solid -> 264deg to 270 deg duration with 9.25 or 10.25 lift. Requires solid lifters and shims.
HKS: All discontinued, and no longer available new.
CAMSHAFT ASSY, INTAKE 13001/13020 13020-D4202 CA18DET * U11,U12.(A+SSSAL.MT+K) * S12 * T12, T12Y.CA18DT 13020-55W00 CA18D, CA18DT * U12.SSSR * T12Y.CA18D 13020-35F00 CA18DE, CA18DET * S13, RS13 13020-1E000 CA18DET * RS13 * U13
CAMSHAFT ASSY, EXHAUST 13020/13020M 13020-55W11 CAMSHAFT ASSY, EXHAUST CA18DE * S13 * U12.(CA18D+CA18DET.SSSR) * T12Y.CA18D 13020-D4211 CAMSHAFT ASSY, EXHAUST CA18DET * S12, S13, RS13 * U11, U12.CA18DT.(SSSAL.MT+K.MT+AT) * T12, T12Y.CA18DT
Lifters
CA18DE uses hydraulic bucket lifters SR20DE uses valve rockers & rocker Pivots with shims over the valve stems
Hydraulic Camshafts use the stock hydraulic lifters.
Hydraulic Lifters13231-79S00 LIFTER-VALVE <> 13231-58S12 <> 13231-59S00 * CA18DE,CA18DET * Z32.(VG30DE+VG30DETT) * KN13.(CA16DE+CA18DE)
Solid Lifters are used with Solid Lifter Camshafts, and allow for higher lift cams to be used.
Requires: * solid profile camshafts * adjustable pullies * solid lifters * heavy duty springs * shims, ground to fit * head modified to clear the high-lift lobes clear
Commonly used Solid lifters (bucket-over-shim): * Toyota 1ZZ * Aftermarket for Nissan VG30DE/VG30DETT, RB, VG, VQ) Z32 Nissan 300ZX 0289-0896 13231-79S00 * Tomei lifter kit $400 usd
B210 Swap Notes
The B210 is about 40mm wider than a B110, so crossmembers from Datsun 510/610/710 and A10/B310 fit -- more or less.
See slider\ratsun's build thread at Ratsun.net
You can use an S13 engine crossmember. It bolts right to the B210 chassis with minor slotting of the holes. Use the S13 front suspension too crossmember, arms, struts and brakes with 120Y springs. S13 swaybar does not fit with the width.
Crossmember had to be hammered in at the red circles in the picture to clear, and rearbolt-holes had to be movet 3mm each side.
NOTE: Track width is increased very much
120Y castor arms used. Just drill one or two new holes in the control arms. Basicly bolt-on.
Forum Discussions
See CA18 Photo Index
