Datsun 1200 Competition Suspension Manual
Revision as of 12:05, 3 February 2016; view current revision
Categories: Documentation | Racing
Download: Datsun 1200 Competition Suspension Manual
[hide]
Foreward
page 1
page 2
Front Suspension Modifications
For road racing, the front suspension of the race car must be modified to improve handling and maneuverability. This is done by: lowering the car (thereby lowering the center of gravity); reducing body roll by increasing roll stiffness; and, by improving high speed stability.
Along with the above improvements, the Datsun 1200 is further modified to allow the use of superior brake components and is also converted to a fully adjustable suspension system.
The Datsun 1200 suspension, modified following the procedure in this manual, will provide the following features:
1. Camber Adjustment — the front strut tower is modified to allow the camber to be adjusted as needed.
2. Increased Caster — the tension rods are altered to provide an optimum increase in caster of 4° over stock.
3. Adjustable Ride Height — A threaded collar is added to the strut assembly to allow the height of the car to be varied depending on track conditions.
4. Lower Center of Gravity — The stock front springs are replaced with stiff, lower competition units that reduce front car height by 2 inches.
5. Improved Brakes — The stock 1200 brakes are discard and the competition strut assembly is modified to accept the more efficient 240-Z disc brake components.
6. Roll Stiffness — Replacing the stock springs with stiffer units and adding a heavier sway bar increases suspension stiffness and reduces body roll.
th_03.png Page 3
Front Camber Adjustment
See main article: Camber
page 4
page 5
page 6
Modified Strut Caliper Mount
page 7
full
Front Hub
page 8
full
240-Z Caliper Modification
page 9
full
page 10
Front Springs
page 11
full
Lower Link and Steering Gear
The complete lower suspension link can be left stock. The inner chassis mount rubber bushing may also be left stock since it is very rigid and deflects a minimal amount while cornering.
The complete steering linkage assembly is adequate for competition purposes. This includes the steering gear box, tie rods, tie rod ends, all steering arms, idler arm assembly and the lower ball joint.
Tension Rod and Bushing Modification
Page 11
Sway Bar Assembly
page 12
page 13
Front Competition Suspension Assembly
page 14
full
full
page 15
full
page 16
page 17
Sway Bar Installation
page 18
Sway Bar Adjustment
page 18
page 19
page 20 (blank page)
Rear Suspension Modifications
page 21
page 22
full
Rear Spring Modification
page 23
Front Spring Eye Bushing
page 23
Shocks and Reworks Lower Mount
page 24
Rear Traction Bar Mount
page 25
page 26
Front Spring Hanger Mount Chassis Bushing
page 27
Front Spring Hanger Assembly
page 27
Traction Arm Assembly
page 28
page 29
Rear Shackle
page 30
Rear Sway Bar Assembly
page 31
page 32
full
Rear Competition Suspension Assembly
page 33
page 34
Final Adjustments
page 36
General Handling
page 37
Parts Lists
Competition Parts Lists
page 38
Front Suspension
page 39
Rear Suspension
page 40
