The B110 uses a steering gearbox integral (one unit) with the steering column. Optionally available was a collapsible-column unit for safety in case of a crash. The collapsible column was standard for USA models. The gearbox is a relatively fast 15:1 ratio with only 3.3 turns lock to lock, and used a quality recirculating-ball type system. The only problem was a bit of play, as is common to boxes of this type, but as the years have gone by many boxes are worn out. Unfortunately no other gearbox fits. New ones may be available from Nissan South Africa.
Also see Steering Column
For modification-required swaps, see Steering Gearbox Swaps
The B210 and B310 units both have a seperate gearbox and column, joined by a flexible coupling. But these gearboxes will not bolt to the B110 subframe connection.
- B120: Type RB41N, 15.0:1 3.3 turns
- Available in standard or collapsible column types
- B210: 15.0:1 3.38+ turns
- B310 A12: Type RB43N 16.4:1 3.5 turns
- B310 A14/A15: Type BR45L 15.0:1 3.2 turns
- B310 Australia uses 16.4:1 model for all engine (per Gregory's)
The steering arm is fastened to the gear by an M16 nut, with 24mm hex.
Gear
Datsun 1200 uses RB41N (Recirculating Ball) steering gear, a type which is also known as Worm and Sector. RB type is still used by fullsize cars and trucks as it is stronger/more durable than rack & pinion gearboxes.
Generic recirculating ball diagram
Datsun 1200 RB gearbox. Normally the ball-nut block is not removed from the shaft.
Datsun 1200 uses 60 ball bearings (7/32 in. size). 38 are rolling in the ball nut at any given time, while the other 22 are moving in the ball nut tubes. Ball grades 10 (best) to 50 (OK) are probably acceptible, with Grade 25 being recommended (these are about $5 per 100). Maximum axial play is 0.0031 inch -- if greater play is measured then oversize balls should be fitted.
RHD - Japan B110 & B120 48805-H1033 GEAR ASS'Y-steering impact (collapsible) GL, GX 48010-H1002 GEAR ASS'Y-steering 3-speed 48010-H1005 GEAR ASS'Y-steering 4-speed, A-all
LHD - North America 48805-H1951 ASSY-GEAR,STEERING, COLLAPSIBLE NLA
Seal
Steering Gear Pitman Shaft Seal * Oil Seal: Nitrile * Shaft Size=0.984" * Housing Bore=1.496" * Outer Diameter=1.505" * Width=0.276" National 222535 SKF 10173
Alternate Part Numbers: 013-8340-2, 052-3346, 089-409-085, 089-409-085B, 089409085C, 0928326016, 10171, 10173CHR, 10A-0143, 145810171, 145810173, 194740-55620, 222630, 26X38X5T, 26X38X6DG, 26X38X6R21P, 26X38X8HMS, 26X38X8HMSA, 26X38X8MHS, 26X38X8MHSA, 314360-4232-00, 3436454M1, 48137H1002, 65551A, 67453-00117, 67477, 70-7565, 71-10171, 8734980, 965810173, AB1463E0, AB1464E0, AE1306K, AE1306K0, AE1463E, CFW226X38X6, CH14736, CH14765, CHR 10173, CR10173, MHS26X38X8, N10171, N10173, NJ849, SBA334290180, SBA334290181, SBA334292001, W26X38X6R21P, ZAR10171, ZAR10173
Shaft Bearings
Two ball bearing assemblies hold the column/worm shaft in place.
48025-18000 BEARING-WORM $40 USD
Only Datsun 1200 gearbox interchanges. Made in Japan through 1994, and in South Africa through 2007.
B110 mounts with one front bolt, two rear bolts. PB110, B210, B310, 510 mount with two front bolts, single rear bolt. Cherry uses Rack & Pinion, so it does not interchange.
Some parts inside the gearbox, including seal and bearings, interchange between B110 RB41N and the smaller B210 (early RHD) box and the smaller B310 box -- type RB43N. B210/B310 BR45L boxes share zero parts with the B110 box.
Service
Also see: Steering Gearbox Adjustment Also see: Steering Column#Bushing Repair
Up to 1" play is normal and does not indicate a worn box. Check to see if it is worn out. Wiggle the steering wheel back and forth with your pinky. Look under the car at the same time to ensure the steering box gear arm is not moving -- if it is then you are applying too much force to the wheel for this test.
If the steering wheel moves up/down, that is the column bushing, easily replaceable new from Nissan.
If the steering wheel moves in/out it indicates the Steering Wheel needs to be tightened down.
Steering Column
The steering column is integrated with the gearbox; they do not come apart.
See main article: Steering Column
Steering Column Bush
U-joints
Datsun 1200 does not use a separate steering column; it has the column as one piece (integral) with the steering gearbox.
B210 and B310 use a separate column with a rag joint.
Datsun 510 and 240Z use a U-joint
S30 * 28 spline * ~14 mm diameter 48080-E4155 ASSY-JOINT STEERING -0773 * superceded 48080-E4150 48080-N3150 ASSY-JOINT STEERING 2+2 0873-1076 48080-N3151 ASSY-JOINT STEERING 2+2 1176-
510 48085-23125 KIT-U/JOINT STG * superceded 48095-23100
See main article: Steering Specifications
Collapsible Gearbox & Column
LHD
LHD drive gearbox - North America Catalog
NOTE: no parts interchange with B210 LHD gearbox/column
48805-H1951 ASSY-GEAR,STEERING, COLLAPSIBLE 1 OP. - NLA 48850-H1900 ASSY-TUBE,JACKET 1 OP. - NLA 48011-H1601 ASSY-HOUSING,GEAR 1 OP. - NLA 48820-H1900 ASSY-SHAFT,COLUMN 1 OP. - NLA 48025-18000 BEARING-WORM 1 OP. - $33.94 48103-H1002 SHAFT-SECTOR 1 OP. - $170.32 48137-H1002 SEAL-OIL 1 OP. - $5.87 48135-66000 SCREW-ADJUSTING 1 OP. - NLA 08911-3401A NUT 1 OP. - 08911-34010 $0.11 08911-34010 NUT 1 OP. - superceded 48133-66000 SHIM-SCREW,T=1.62 0 OP. - NLA 48134-66000 SHIM-SCREW,T=1.65 0 OP. - NLA 48131-66000 SHIM-SCREW,T=1.56 0 OP. - 48130-66000 SHIM-SCREW,T=1.53 0 OP. - 48132-66000 SHIM-SCREW,T=1.59 0 OP. - 48201-18000 COVER-SIDE 1 OP. - 48204-18000 PACKING-SIDE COVER 1 OP. - NLA 08931-10410 PLUG 1 OP. - 08120-82010 BOLT 8 OP. - 08915-13810 WASHER-SPRING 8 OP. - 08911-24610 NUT 1 OP. - 08915-14610 WASHER-LOCK 1 OP. - 48031-18000 SHIM-COVER,T=0.05 0 OP. - NLA 48032-18000 SHIM-COVER,T=0.07 0 OP. - 48033-18000 SHIM-COVER,T=0.08 0 OP. - NLA 48034-18000 SHIM-COVER,T=0.10 0 OP. - 48035-18000 SHIM-COVER,T=0.12 0 OP. - 48910-H1020 BUSH-COLUMN 1 OP. - superceded 48910-H1021 BUSH-COLUMN 1 OP. - 2 48910-H1020 $35.58 48931-H1020 WASHER-PLAIN 1 OP. - 00922-11700 RING-SNAP 1 OP. - 08110-81210 BOLT 4 OP. - 08915-13810 WASHER 4 OP. - 48960-H1020 ASSY-CLAMP,STEERING POST 1 OP. - 08915-13810 WASHER-LOCK 4 OP. - 08110-81210 BOLT 4 OP. - 08120-83010 BOLT 2 OP. - 08915-53810 WASHER-PLAIN 3 OP. - 48361-H1000 BOLT 3 OP. - 48366-H1000 NUT 3 OP. - 48502-H1600 ARM-STEERING GEAR 1 OP. - $36.79
RHD
RHD collapsible drive gearbox - JDM GL & GX trims
NOTE: Some parts interchange with early B210 gearbox
Only showing parts that differ from LHD:
48805-H1033 GEAR ASS'Y-steering impact (collapsible) 48820-H1021 COLUMN ASS'Y-steering 08931-10410 PLUG 08915-13810 WASHER-lock (8) 48011-H1002 HOUSING ASS'Y-gear 08915-14610 WASHER-lock (fixing sector shaft) 48850-H1021 JACKET ASS'Y-column 48932-H1020 SHIM (t0.05) as req. 48932-H1021 SHIM (t0.01) as req.
Standard Gearbox & Column
RHD drive gearbox - JDM STD & DX trims
rigid (non-safety, not collapsible) column
Only showing parts that differ from JDM Collapsible Column
48010-H1002 GEAR ASS'Y-steering 3-speed 48010-H1005 GEAR ASS'Y-steering 4-speed, A-all 48150-H1002 COLUMN ASS'Y-steering 08140-82010 BOLT (8) 08931-10400 PLUG 24210-89913 CLIP 48250-H1002 JACKET ASS'Y-column 3-speed 48250-H1005 JACKET ASS'Y-column 4-speed, A-all 48054-H1002 BUSH-steering column 48502-H1000 ARM-steering gear 48324-H1005 CLAMP-upper 48326-H1005 CLAMP-lower 40325-04100 PACKING 08915-43810 WASHER-plain (fixing steering post) (2) 08120-82510 BOLT (fixing steering post) (2)
PB110
48010-H2551 GEAR ASS'Y-steering [rigid] DX * 48011-21000 HOUSING 48010-26510 GEAR ASS'Y-steering COLLAPSIBLE GL,GX * 48011-21000 HOUSING
48011-21000 HOUSING is used by the larger Datsuns including 510/610/710.
B210 RHD 48010-H5000 GEAR ASS'Y-steering A12, A14(HB210) * 48011-M5000 HOUSING 48010-H5800 GEAR ASS'Y-steering L14(PB210), L16(GB210) * 48010-H5850 alternate * 48011-21000 HOUSING 48010-H5500 GEAR ASS'Y-steering Van-rigid type 48010-H5510 GEAR ASS'Y-steering Van-for collapsible
PB210 gearbox uses the same housing as Datsun 510, same input and output shafts so likely it will interchange with 510(1600) or 610(180B) gearboxes, though ratio may differ.
Steering Box Brace
See: Steering System#Gearbox Brace
