Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibily (instead of turn signals) they are made larger to be more visible, and are fitted front and rear. USA B110 markers are approximately the same size as B210 worldwide markers.
Variations
1200 global![]()
1200 Canada/USA![]()
North America (Canada/USA): large lenses for running lights/reflectors * front and rearalbum
All other countries: long thin ORANGE lenses for turn signal (blinkers) * front onlyalbum
Global
'IKI 5002 JAPAN' used as winker/blinker (indicator) lamp
full
18 mm long, marked 'B-110 45 TOKYO'
full
26160-H1001 LAMP ASS'Y-side flasher 26160-G1060 LAMP ASS'Y-side flasher 7804- TRUCK * integrated two-wire harness (bulb 12V + earth/ground) 26161-H1001 LENS [marked 'IKI 5002 JAPAN] 26162-H1001 RIM26164-H1001 PACKING 26164-G1060 PACKING 7804- TRUCK 01451-00071 SCREW 08964-10410 NUT-spring 26715-89900 BULB-6W
North America
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged. Australia moved to the same-sized large lights with the 1974 120Y.
* 2-wire (12V + Ground) * individual wires (one female bullet, one male bullet) * right and left differ * front and back differ * sedan and coupe differ
See Side Lighting Parts Numbers
COMMON [4 of each per vehicle] * 26182-H1900 RIM * 26715-89902 BULB 12V-8W (ICHIKHO) * 08964-10410 NUT-SPRING (ICHIKHO) [8 per vehicle]
ORANGE, FRONT
* 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO) * 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH (ICHIKHO) * 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772- * 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772- * 26181-H1900 LENS, FRONT [amber] ** 01451-00041 SCREW (2 per lens) * 26184-H1900 PACKING RH * 26189-H1900 PACKING LH
RED, REAR
COMMON * 26191-H1900 LENS, REAR [red]
* 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE * 26195-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE ** 26194-H1910 PACKING RH(ICHIKHO) COUPE ** 26199-H1910 PACKING LH(ICHIKHO) COUPE ** 01451-00061 SCREW(ICHIKHO) COUPE
* 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN * 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) SEDAN ** 26194-H1900 PACKING RH(ICHIKHO) SEDAN ** 26199-H1900 PACKING LH(ICHIKHO) SEDAN ** 01451-00041 SCREW(ICHIKHO) SEDAN [same as front]
Only the 1200 lights interchange.
620
In USA, the early 620 lamp assembly looks identical, however it uses a highly-angled plastic piece in the rear.
Pointed Lens
Pointed lens is used by B210 and 240Z and (late USA) 510. B110 is rectangular, compared to the slightly pointed rectangle type.
1200 North America![]()
Pointed type![]()
B210 side lamp is different from B110 lamp, and uses a different connector style
See main article: B210 side lamp
S30 240Z bullet wire connectors S30 260Z/280Z rectangular connector B210 (120Y) rectangular connector 510 late
The USA late 510 units 1970-1972 uses the 240Z pointed lens, though the assembly differs somehow
S30
240Z has individual wires 260Z has the rectangular connector
Lamp assembly differs from B210 somehow
North America (Canada and USA) used amber front side lamp and red rear side reflector
Datsun 1000
See main article: Datsun 1000
B140
South Africa B140 bakkie from 1982-2004 used the global indicator. From 2005 used a unique small lamp.
From 2005-2008 used this small indicator:
Clear aftermarket from Autostyle
Clear Lense
Datsun 1000 clear lense - will it fit the 1200?
26121-27700 Lens [clear]
Custom
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ
