The A12 engine in the Datsun 1200 uses traditional coil springs for each valve. The A12GX Engine uses dual springs on each valve.
Datsun dual springs are installed a special direction
Specs and Testing
* Free Length: 46.5 mm (1.831 in) * Valve Closed: 38.7 mm at 23.9 kg (1.524 in at 52.7 lb) * Valve Open: 30.2 mm at 58.5 kg (1.19 in at 129 lb)
- Measure the free length and the tension of each spring. If the measured value exceeds the specified limit, replace the spring.
- Check each spring for deformation with a square. Any springs with excess deflection must be replaced.
* Squareness deformation limit: 1.6 mm (1.3 for dual springs)
Nissan Part Numbers * 13203-H1000 SPRING-valve, outer ALL except GX * 13205-18000 SEAT-valve spring ALL except GX * 13209-H2301 RETAINER-valve spring ALL [all after 1973] * 13210-73400 COLLET-valve * 13210-H1000 COLLET-valve (from 72-2) * 13210-U0100 COLLET-valve (from 71-10) ** All three collet PNs interchange * 13219-H1000 SHROUD-valve, inner ALL except GX
GX-specific * 13203-H2300 SPRING-valve, outer GX * 13203-H2301 SPRING-valve, inner GX * 13205-H2300 SEAT-valve spring GX![]()
Valves & Seals
See main article: Valves
Racing Valve Springs
For RPMs in excess of stock (higher than 6400 RPM) use racing valve springs
* Stock springs are good to 6000 rpm * Factory GX springs are good to 6400 rpm * Tomei * Iskenderian 455-JA-006 needs dual spring retainers, MAX RPM 10,000
